  The Mall
  WTB - Distributor dummy plug for DIS
WTB - Distributor dummy plug for DIS by 1MohrFiero
Started on: 07-27-2014 06:48 PM
Replies: 9 (337 views)
Last post by: 84fiero123 on 08-01-2014 08:48 PM
1MohrFiero
Total ratings: 157
Report this Post07-27-2014 06:48 PM Click Here to See the Profile for 1MohrFieroSend a Private Message to 1MohrFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am looking for the dummy plug that replaces the distributor on the DIS V6 engines like the early 3.1 or 3.4s.
Thanks,
1MohrFiero
Total ratings: 157
Report this Post07-28-2014 08:35 PM Click Here to See the Profile for 1MohrFieroSend a Private Message to 1MohrFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Total ratings: 461
Report this Post07-28-2014 09:08 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
The newer 3.5s and 3.9s have a similar plug.
I don't know if it's the same or not, but if it is, it will give you a better chance of finding what you need.
1MohrFiero
Total ratings: 157
Report this Post07-28-2014 10:03 PM Click Here to See the Profile for 1MohrFieroSend a Private Message to 1MohrFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, Steve. There are very few pick n pull salvage yards here so I am hoping someone will have an extra.
carguy8t8
Report this Post07-28-2014 10:46 PM Click Here to See the Profile for carguy8t8Send a Private Message to carguy8t8Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have one. PM sent.
hookdonspeed
Total ratings: 131
Report this Post07-29-2014 09:25 AM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
just incase anyone ever needs one of these, EVERY pushrod DIS 60degree V6 has one of these..
2.8, 3.1, 3.4, 3100, 3400, 3500, 3900
1MohrFiero
Total ratings: 157
Report this Post07-29-2014 08:50 PM Click Here to See the Profile for 1MohrFieroSend a Private Message to 1MohrFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't need the hex rod to go with this do I. I am just replacing the distributor in a running 3.4 PR. Anyone?
Thanks,
hookdonspeed
Total ratings: 131
Report this Post07-31-2014 11:09 AM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks,
yes you do... its technically the oil pump drive... your cam turns the gear on the plug, that turns the hex rod that the other end of going into your oil pump.. no hex rod, no oil pump.
radrace19
Report this Post08-01-2014 03:43 PM Click Here to See the Profile for radrace19Send a Private Message to radrace19Edit/Delete MessageReply w/QuoteDirect Link to This Post
The GM part number is 01104072. Just pick one up from the dealer brand new or online at any of the online GM wholesale shops.
You should be able to find it for $50.00 or so if you can't find one here
-Greg
[This message has been edited by radrace19 (edited 08-01-2014).]
84fiero123
Total ratings: 325
Report this Post08-01-2014 08:48 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
To me it just looks like the lower shaft of the distributer and if you are swapping over from a regular early 80s with a distributer just cut the lower shaft section off and use that.
Have I got to be the only one who thinks outside the box?
Steve
