  The Mall
  Massive Parts Sale
Massive Parts Sale by gtxbullet
Started on: 08-03-2014 12:12 AM
Replies: 9 (1424 views)
Last post by: gtxbullet on 09-09-2014 06:00 PM
gtxbullet
Report this Post08-03-2014 12:12 AM Click Here to See the Profile for gtxbulletSend a Private Message to gtxbulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
http://s181.photobucket.com...0PARTS?sort=3&page=1
All parts can be viewed in my photobucket album.
Prices are listed in the album.
There are many more bins of parts plus my storage locker which I have to have cleared out by October as that is when the contract is over.
I will not sell "JUNK", however I don't sell "NOS" "MINT CONDITION" parts either. please look closely at pictures and understand I've priced everything CHEAP because everything is in good useable condition for daily drivers and projects, etc.
Prices - only negotiable if you pick parts up in person.
Shipping cost - you pay exact shipping
Here are other parts still available from previous parts sales.
Brake Proportioning valves (2 available) - $15 each
Heater Core aluminum undercar pipes - $20 for the set
AC optioned HVAC controls - $5 each (2 available)
Red HVAC cable for HOT-to-COLD slide control - $10
4-speed Shift and Select cables (from a rusty parts car, one cable works great, the other needs an oil soaking...forget which) - $25 for both
Gas Filler Tube - $25
1986 Interior Harness, AUTOMATIC with AC and Trunk Popper- $35.00
Spare wheels - $1.00 pick up only (must buy something else too )
Tan kick panel - $1.00
Fiero V6 Alternators good for core only - $20 each
Fiero LUG NUTS - $5.00 a set with other purchase
Rear Defrost Window (removed from an 88 GT I believe) - $30
now for parts with pictures: ---------------------------------------------
Grey 15 inch Lace GT wheels (I only have 3) - $50 for all 3 PICK UP ONLY (I will not ship these)
Sun Visors - good cores for recover $10
Tan/Brown Shifter Surrond, no cracks, could use gluing as most due - $9.00
Tan/Brown Dome Light - $5.00 as shown
Tan/Brown Dash Side Vents - $3.00 for the pair
2.5L 1987-1988 Remanufactured ECM - $20
1985-1988 NON-AC HVAC Controls - $5.00
(clean, sorry for the blurry picture..it's freezing outside...bhhhhrrrrr
NICE Horn Button - $5.00
turn signal/hazard clickers/chimes - $0.50 each, under dash mounting bracket - $1.00
WASHER MOTOR - $0.50
pretty sure this is the ignition part off the steering column - $1.00
Ignition Coil STAND OFF KIT - $2.00
Relay Mounting Brackets for headlight relays, fuel pump realy, AC relay, etc - $1.00 each
******All relays have been tested in fieros (84-86, and 87-88)
I dont know what you need, you find out the part numbers ;-)******
Relays - READ THE NUMBERS - $1.00 each
UNKOWN RELAY - $1.00
7033 RELAY - $1.00
7250 Relay - $1.00 each
6055 relays (6 available) - $1.00 each
6 prong relays - READ THE NUMBERS - $5.00 each
COLD START Sensor - $2.00
1984 fan relay? - $4.00
FAN RELAYS - $4.00 each
Relay - $4.00
AC sensors - FREE with other purchase
Fan switches - $2.00 each
MAP sensors - $1.00 each (BRACKETS NOT INCLUDED)
IAC sensor - $1.00
Interior Light Modules - $20 each
Trunk Popper plate with small crack in a screw hole as shown in picture - FREE WITH OTHER PURCHASE
popper/defrost optioned plates (with screws) - $4.00 each
Headlight Switches - $1.50 each
Power Window Switch Plate (with screws) - $4.00
damaged windows switches (both work but have obvious wear, maybe swap new buttons in, or use for parts) - $5.00 for both
window switch, has faded a bit but works good - $10.00
headlight switches, $5 for left one, $3 for middle, $1 for right. dimmers all $2.00 each
3800 series 2 AC compressor, clutch works, just has dirt on it - $15.00
front hood release lever - $3.00
MITSUBISHI STARION """"RECARO"""" Stock Leather Seats. I paid $200 for these last year and never used them. need leather repair to be perfect but can be used as is - $50 PICK UP
1985 GT Seat Cover - $30.00
Sunroof front compartment storage shelf (3 or 4 available) - $7.00 each
F.I.E.R.O. - Fantastically Imaginative Engineering Racing Object
I'm here to Help, just ask
www.fquick.com/GTXBULLET
Tech/Mechanic (Restorations, Modifications, and Service)
1988 Base Coupe (the show car ;-) )
2003 GTP Daily Driver
Size 13 Feet with Cracking Ankles and Tired Knees
[This message has been edited by gtxbullet (edited 08-13-2014).]
Shho13
Report this Post08-06-2014 12:28 PM Click Here to See the Profile for Shho13Send a Private Message to Shho13Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sending PM for HVAC control now.
BabyEating Dingo
Report this Post08-08-2014 12:05 PM Click Here to See the Profile for BabyEating DingoSend a Private Message to BabyEating DingoEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent!
dcarrd
Report this Post08-09-2014 05:28 AM Click Here to See the Profile for dcarrdSend a Private Message to dcarrdEdit/Delete MessageReply w/QuoteDirect Link to This Post
interested in the ac compressor shipped to 33765, no rush shipping... Do you have the lines too?
Thanks, dave
gtxbullet
Report this Post08-09-2014 03:40 PM Click Here to See the Profile for gtxbulletSend a Private Message to gtxbulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
I only have the compressor as shown.
Shipping would run no more than $14.00
I've pmd my paypal to you.
Shho13
Report this Post08-24-2014 10:02 PM Click Here to See the Profile for Shho13Send a Private Message to Shho13Edit/Delete MessageReply w/QuoteDirect Link to This Post
Free bump!!!
Just got my new HVAC controls, lookin' great!!!
Thanks man!!!
goofy8893
Report this Post09-04-2014 04:55 PM Click Here to See the Profile for goofy8893Send a Private Message to goofy8893Edit/Delete MessageReply w/QuoteDirect Link to This Post
I got my parts a few days ago. Great shape. Very nice guy Thanks again!!
Knight
Report this Post09-08-2014 08:12 PM Click Here to See the Profile for KnightSend a Private Message to KnightEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pm sent
Tbarsch
Report this Post09-09-2014 02:46 AM Click Here to See the Profile for TbarschSend a Private Message to TbarschEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have any stock seats?
gtxbullet
Report this Post09-09-2014 06:00 PM Click Here to See the Profile for gtxbulletSend a Private Message to gtxbulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
all pm's replied. parts that have been paid for up until today have all shipped out.
