Im a little hesitant to sell these, but if somebody is interested please let me know.
I have an 88 cradle modified for a Northstar, relocated front crossmemeber, it is designed to use the stock front N* mount and a a tigged aluminum style torque strut from the head down to the cradle. I also have a flywheel set up to run an f40 on the northstar that uses a spec aluminum flywheel and "biscuit" spacer and a stock flex plate to get the required depth. And lastly I have a Delphi base M-EFI stand alone computer with wiring harness that has a tune on it for a 03-04 based northstar with a cable throttle set up. The harness is just the main connector and all the wires with plenty of length to have the end connectors either crimped on or cut and soldered with stock wiring.
Im really not sure what this is worth, but would consider letting it all go for $1500, let me know if you guys are interested, and I can possibly get some pictures of everything and you can go from there.
