  The Mall
  WANTED: Manual Tranny Fiero CV joint
WANTED: Manual Tranny Fiero CV joint by jokerb90
Started on: 08-27-2014 05:38 PM
Replies: 4 (208 views)
Last post by: DaveC on 08-29-2014 07:14 PM
jokerb90
Report this Post08-27-2014 05:38 PM Click Here to See the Profile for jokerb90Send a Private Message to jokerb90Edit/Delete MessageReply w/QuoteDirect Link to This Post
Building axles for my newest 4.9 swap, using this method:
https://www.fiero.nl/forum/A...090219-2-057038.html
Thanks jeffndebrus for the write up
Have all the parts execpt for the CV joint. Can pay via paypal. Please let me know, Mike
DaveC
Report this Post08-29-2014 01:39 PM Click Here to See the Profile for DaveCSend a Private Message to DaveCEdit/Delete MessageReply w/QuoteDirect Link to This Post
So you need the outer passenger side, correct? What condition do you desire/will accept?
Dave
jokerb90
Report this Post08-29-2014 06:51 PM Click Here to See the Profile for jokerb90Send a Private Message to jokerb90Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well, I bought a cv rebuild kit, thinking it was a whole one. So a used one would be fine. The build instructions say a manual tranny cv,
"The outer CV joint on this unit is too large to fit the Fiero hub/bearing assembly so it must be removed and exchanged for a Manual Tranny Fiero CV joint.
***Please Be Advised*** some axle remanufactureres are using smaller diameter axles so when you get your Fiero manual cv joint---make sure that the axle which it came off of is a 1.030in axle---NOT the smaller .85in which some are using.-the smaller cv joint will not fit on the minivan axle."
So instead of buying a whole new axle and just grabbing the end, I figured I would ask here. How much for what you have? I am still a ways out on this build but am trying to move forward.
ATH87fiero
Report this Post08-29-2014 06:58 PM Click Here to See the Profile for ATH87fieroSend a Private Message to ATH87fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pm sent
DaveC
Report this Post08-29-2014 07:14 PM Click Here to See the Profile for DaveCSend a Private Message to DaveCEdit/Delete MessageReply w/QuoteDirect Link to This Post
jokerb90, You have a PM.
Dave
