  The Mall
  FS: 7730 DIS Swap Harness and ECM
FS: 7730 DIS Swap Harness and ECM by onesexyfiero
Started on: 09-01-2014 12:14 PM
Replies: 4 (344 views)
Last post by: onesexyfiero on 09-03-2014 12:23 PM
onesexyfiero
Report this Post09-01-2014 12:14 PM Click Here to See the Profile for onesexyfieroSend a Private Message to onesexyfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bought this setup from a forum member. Had it in the car and running, but decided I wanted it set up differently and ended up getting a custom harness & tune. I'll set it as a complete package, or separate.
Harness - No EGR, 88 style alternator plug, early style oil pressure, no ac, 7th injector delete, DIS, stock temp gauge sensor wiring, manual trans, no cruise. I have a 4 speed in a 5 speed car, so I had a custom wire to the shifter from connectors at the C500. I'm including the 5 speed plug and wire if that's what you're running.
ECM - Stock 3.1
Stuff that I'll keep as spares unless someone wants the complete package:
Coil packs - 1 bolt missing
Dummy distributor
Knock sensor
Crank position sensor
EGR block off plates - I made them out of steel and didn't paint them, so there's surface rust. One for the intake, one for the port on the Y.
Digital egr pigtail - If you want it
http://s1377.photobucket.co...evincdennis/library/
Basically everything you need except an 87/88 4 cyl. ECM tray. I paid $200 + shipping for the whole setup minus the block off plates, so I'll start there. Shipping should be ~$30 USPS priority.
Email is best to contact me.
1MohrFiero
Total ratings: 157
Report this Post09-01-2014 02:59 PM Click Here to See the Profile for 1MohrFieroSend a Private Message to 1MohrFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sending you a PM. and an email. I missed the line requesting emails the first time I read the post.
[This message has been edited by 1MohrFiero (edited 09-01-2014).]
1MohrFiero
Total ratings: 157
Report this Post09-01-2014 08:48 PM Click Here to See the Profile for 1MohrFieroSend a Private Message to 1MohrFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
1MohrFiero
Member since Apr 2003
Another PM with a few more questions.
gtxbullet
Report this Post09-02-2014 02:56 PM Click Here to See the Profile for gtxbulletSend a Private Message to gtxbulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
What was it meant for?
3100 or 3.1 mpfi?
Who made the harness?
Pm me details. Thanks!
onesexyfiero
Report this Post09-03-2014 12:23 PM Click Here to See the Profile for onesexyfieroSend a Private Message to onesexyfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks like its spoken for, but If he backs out, I'll let you know.
