  The Mall
  Fiero and 3800 Parts (Page 1)
Fiero and 3800 Parts by Jfrost
Started on: 09-18-2014 01:04 AM
Replies: 83 (4037 views)
Last post by: fierogt455 on 10-21-2015 09:22 PM
Jfrost
Report this Post09-18-2014 01:04 AM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Up for sale are both Fiero and 3800 parts. The parts are from 3 different Fieros, 2 86 GT's and one 87 GT. I'm also parting out the 2.8 V6 from the 87 and have the parts listed first. Pictures available upon request. Payment via PayPal and prices do not incllude shipping or PayPal fees.
If you don't see the part listed I don't have it for sale so please don't ask.
Thanks for looking!
Middle intake manifold: $15
Plug wires: $8
EGR: $5
Cold start injector w/line: $5
Fuel injector harness: $10
Front exhaust manifold shield: $5
Front exhaust shield, believe its part of recall: $10
Ignition coil: $10
Ignition coil to distributor connector: $5
Spark plug and ignition coil wire: $15
Positive battery cable w/aux cable: $8
MAP sensor: $10
Dogbone brackets (3): $10
Alternator and mounting bracket. Top bolt is stuck and the head is starting to strip. Alternator was seized but freed up once engine removed. The plastic fin scrapes in one spot when spinning, could be used as a core: $10
Rear decklid torsion bars from GT: $40
Northstar Throttle body (3 available): $50
GT exhaust, no cat with a straight pipe in its place and has a small leak on the weld. No holes in muffler or other pipes. Pick-up preferred: $75
Pair of 86 headlight buckets and motors. Both motors need rebuilding: $45
Two 86 GT 4 spd PCM's and one 87 5 spd PCM: $25 each
Master cylinder and proportioning valve from 69k mile Fiero: $25
87 2.8 a/c compressor. Unknown working condition, a/c hoses not included: $10
86 GT 4 spd shifter assembly $40
4 Speed shifter trim, it is cracked on the bottom portion but can be glued together, doors not included: $5
Stock Manual Trans Shift Boot: one tiny tear, seen in pic, otherwise good. $7
Tan performance sound overhead console. The gray “performance badge” is loose: $20
Fastback heat vent attaching brackets. No bolts or hold down bolts included: $12 each set
86 GT Seat Belts: missing 1 anchor pin, no trim for top section $35
Air intake housing, filter included: $15
Drivers side heat vents, fastback only: $20 each
Washer fluid container with pump and cap, one left: $15
GT trunk latch: $5
86 GT trunk hinge brackets. One retainer strap broken, other in tact: $20
Front trunk gasket from 69k mile Fiero: $20
Rear Quarter Panels: $35 ea
Front Fender Panels $25 ea
86 GT Front Bumper: paint is faded and there are scrapes/hole on the bottom section, see pic $100 pick up only
Tire iron: $5
Intermediate steering shaft cover: $5
Fiero exhaust crossover heat shield: $7
Stock PCM tray: $5
Lower air intake box, only one has tube to connect to rear quarter panel: $5 each
Air intake tube, free with any other air intake part purchase:
Rear cooling fan motor: $5
Original factory fuel pump, aprox 66k miles, worked when removed: $10
Rear cooling tubes: $7 each set
3800SC SII Fuel Rail. Painted black, could use repaint as there are some chips: $30
3800 PCM tray, one left: $15
3800 front exhaust manifold, needs cleaning: $10
3800 exhaust crossover pipe. Heat shielding removed: $15
3800 rear exhaust manifold from an H-body car I believe. Has one bolt seized in crossover flange: $8
3800 ICM harness, one connector partially melted as seen in pick but should still work. Sold as is: $8
3800 NA valve covers, RTV was used by prior owner to seal, will need removed: $20
Stock 3.8in supercharger pulley from a GenV: $8
Sony Xpolde CD player, adapter trim and connector: $35
Viper Security alarm, removed from 87 GT. Main module included with misc wiring: $5
Moon Equipment universal floor mats, could use cleaning: $5
SOLD:
Rear decklid springs for factory spoiler: $40
Radio adapter harness for newer GM style radio to stock Fiero wiring harness: $30
3800 PCM tray: $15
3800 rear manifold stock heat shield. Missing one clamp: $5
Air intake tube: $10
Newer style GM radio however screen doesn’t fully light up: $10
Side quarter panel air scoop: $20
GT front license plate holder: $20
Intermediate steering shaft: $20
Stock thermostat housing with cap and tstat: $20
Automatic steering column: $20
Rear Control Arms: $50
Cruise control module: $10
5spd shift and select cables. Worked when installed but was "tight" when selecting/shifting, an oiling could fix them right up: $20 ea
EGR Tube w/stock heat cover and no visible cracks
Door Lock Trim: $5 ea
Fiero locking lug nuts with lock key: $20
Drivers/Passengers door gaskets from 69k mile Fiero. Good condition with a few nicks here and there: $20ea
87 V6 Engine
Project L67 Fiero
[This message has been edited by Jfrost (edited 09-10-2015).]
DKcustoms
Report this Post09-18-2014 07:04 AM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent about radio wiring harness
craigtbone
Report this Post09-18-2014 07:15 AM Click Here to See the Profile for craigtboneSend a Private Message to craigtboneEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent about Deck Lid springs.
Craig T.
Jfrost
Report this Post09-18-2014 09:13 AM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM's replied to.
GODFATHER
Report this Post09-18-2014 01:21 PM Click Here to See the Profile for GODFATHERSend a Private Message to GODFATHEREdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent about pcm tray and exhaust heat shield
Jfrost
Report this Post09-18-2014 08:39 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Decklid springs sold, 3800 PCM tray and rear exhaust sheilding pending payment.
Jfrost
Report this Post09-18-2014 09:17 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Jfrost
Member since Jul 2009
Radio adapter harness sold however radio is still available.
Princelad
Report this Post09-19-2014 04:54 PM Click Here to See the Profile for PrinceladSend a Private Message to PrinceladEdit/Delete MessageReply w/QuoteDirect Link to This Post
pm sent
Fiero Tom
Report this Post09-19-2014 05:40 PM Click Here to See the Profile for Fiero TomSend a Private Message to Fiero TomEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent on newer style GM radio .
Jfrost
Report this Post09-19-2014 06:25 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM's replied to.
3800 PCM tray, rear exhaust heat shield, air intake tube sold.
zmcdonal
Report this Post09-19-2014 10:19 PM Click Here to See the Profile for zmcdonalSend a Private Message to zmcdonalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are 3800 na valve covers any different than SC valve covers?
Jfrost
Report this Post09-19-2014 10:27 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
They are, they only fit on NA heads. They don't have the provisions for the injectors to go in the heads.
Jfrost
Report this Post09-23-2014 12:59 AM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Radio sold, bump.
Jfrost
Report this Post09-25-2014 12:47 AM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Jfrost
Report this Post09-29-2014 10:17 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Front license plate holder and air intake scoop both sold, all other parts available.
chrissin712
Report this Post09-30-2014 12:47 PM Click Here to See the Profile for chrissin712Send a Private Message to chrissin712Edit/Delete MessageReply w/QuoteDirect Link to This Post
Parts were as described. Great to meet you.
Thanks!
Jfrost
Report this Post10-02-2014 12:30 AM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks!
Thanks, nice meeting you as well!
Jfrost
Report this Post10-03-2014 10:17 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Jfrost
Report this Post10-16-2014 10:42 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
johnyrottin
Total ratings: 85
Report this Post10-16-2014 11:10 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
The fastback heat vent brackets...are they from an 88 GT If so I will take them.
Jfrost
Report this Post10-16-2014 11:35 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
They are not, it's from an 86 GT so I believe they are not the same.
Jfrost
Report this Post10-22-2014 10:34 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Jfrost
Report this Post10-27-2014 12:46 AM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Total ratings: 154
Report this Post11-11-2014 07:50 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Jfrost, you have a pm.
Jfrost
Report this Post12-01-2014 11:15 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
New items listed, old items still available if listed. Thanks for looking.
Jfrost
Report this Post12-04-2014 12:29 AM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
FIEROFLYER
Total ratings: 180
Report this Post12-04-2014 07:59 AM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
How much for the fast back heat vent brackets shipped to Ont Canada Postal code N0H 2L0
Jfrost
Report this Post12-04-2014 08:43 AM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll get a shipping quote and PM you the details.
[This message has been edited by Jfrost (edited 12-04-2014).]
Jfrost
Report this Post12-07-2014 08:24 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump, items still available.
Jfrost
Report this Post12-08-2014 09:29 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
New item added, more to come
Jfrost
Report this Post12-10-2014 09:50 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Jfrost
Report this Post12-16-2014 11:31 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
jaybug56
Report this Post12-24-2014 07:49 PM Click Here to See the Profile for jaybug56Send a Private Message to jaybug56Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am interested in these parts. Can't pick them up until Jan 3rd or 4th. Can you hold them until then?
Automatic steering column. Good for parts: $20
Thanks
Jay
DKcustoms
Report this Post12-25-2014 09:02 AM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent about the rear control arms
jaybug56
Report this Post12-25-2014 03:33 PM Click Here to See the Profile for jaybug56Send a Private Message to jaybug56Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hmm. Posted 3 months ago Now everybody wants the control arms
Jfrost
Report this Post12-26-2014 09:54 AM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM's replied to.
Jfrost
Report this Post12-30-2014 08:43 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump, more new items added
[This message has been edited by Jfrost (edited 12-30-2014).]
jaybug56
Report this Post01-03-2015 01:51 PM Click Here to See the Profile for jaybug56Send a Private Message to jaybug56Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the great parts. It's always a pleasure doing business with you
Jfrost
Report this Post01-03-2015 02:22 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Likewise, thanks for coming by!
Jfrost
Report this Post01-03-2015 02:32 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Jfrost
Parts list updated, open to offers.
