Up for sale are both Fiero and 3800 parts. The parts are from 3 different Fieros, 2 86 GT's and one 87 GT. I'm also parting out the 2.8 V6 from the 87 and have the parts listed first. Pictures available upon request. Payment via PayPal and prices do not incllude shipping or PayPal fees.
If you don't see the part listed I don't have it for sale so please don't ask.
Thanks for looking!
Middle intake manifold: $15
Plug wires: $8
EGR: $5
Cold start injector w/line: $5
Fuel injector harness: $10
Front exhaust manifold shield: $5
Front exhaust shield, believe its part of recall: $10
Ignition coil: $10
Ignition coil to distributor connector: $5
Spark plug and ignition coil wire: $15
Positive battery cable w/aux cable: $8
MAP sensor: $10
Dogbone brackets (3): $10
Alternator and mounting bracket. Top bolt is stuck and the head is starting to strip. Alternator was seized but freed up once engine removed. The plastic fin scrapes in one spot when spinning, could be used as a core: $10
Rear decklid torsion bars from GT: $40
Northstar Throttle body (3 available): $50
GT exhaust, no cat with a straight pipe in its place and has a small leak on the weld. No holes in muffler or other pipes. Pick-up preferred: $75
Pair of 86 headlight buckets and motors. Both motors need rebuilding: $45
Two 86 GT 4 spd PCM's and one 87 5 spd PCM: $25 each
Master cylinder and proportioning valve from 69k mile Fiero: $25
87 2.8 a/c compressor. Unknown working condition, a/c hoses not included: $10
86 GT 4 spd shifter assembly $40
4 Speed shifter trim, it is cracked on the bottom portion but can be glued together, doors not included: $5
Stock Manual Trans Shift Boot: one tiny tear, seen in pic, otherwise good. $7
Tan performance sound overhead console. The gray “performance badge” is loose: $20
Fastback heat vent attaching brackets. No bolts or hold down bolts included: $12 each set
86 GT Seat Belts: missing 1 anchor pin, no trim for top section $35
Air intake housing, filter included: $15
Drivers side heat vents, fastback only: $20 each
Washer fluid container with pump and cap, one left: $15
GT trunk latch: $5
86 GT trunk hinge brackets. One retainer strap broken, other in tact: $20
Front trunk gasket from 69k mile Fiero: $20
Rear Quarter Panels: $35 ea
Front Fender Panels $25 ea
86 GT Front Bumper: paint is faded and there are scrapes/hole on the bottom section, see pic $100 pick up only
Tire iron: $5
Intermediate steering shaft cover: $5
Fiero exhaust crossover heat shield: $7
Stock PCM tray: $5
Lower air intake box, only one has tube to connect to rear quarter panel: $5 each
Air intake tube, free with any other air intake part purchase:
Rear cooling fan motor: $5
Original factory fuel pump, aprox 66k miles, worked when removed: $10
Rear cooling tubes: $7 each set
3800SC SII Fuel Rail. Painted black, could use repaint as there are some chips: $30
3800 PCM tray, one left: $15
3800 front exhaust manifold, needs cleaning: $10
3800 exhaust crossover pipe. Heat shielding removed: $15
3800 rear exhaust manifold from an H-body car I believe. Has one bolt seized in crossover flange: $8
3800 ICM harness, one connector partially melted as seen in pick but should still work. Sold as is: $8
3800 NA valve covers, RTV was used by prior owner to seal, will need removed: $20
Stock 3.8in supercharger pulley from a GenV: $8
Sony Xpolde CD player, adapter trim and connector: $35
Viper Security alarm, removed from 87 GT. Main module included with misc wiring: $5
Moon Equipment universal floor mats, could use cleaning: $5
SOLD:
Rear decklid springs for factory spoiler: $40
Radio adapter harness for newer GM style radio to stock Fiero wiring harness: $30
3800 PCM tray: $15
3800 rear manifold stock heat shield. Missing one clamp: $5
Air intake tube: $10
Newer style GM radio however screen doesn’t fully light up: $10
Side quarter panel air scoop: $20
GT front license plate holder: $20
Intermediate steering shaft: $20
Stock thermostat housing with cap and tstat: $20
Automatic steering column: $20
Rear Control Arms: $50
Cruise control module: $10
5spd shift and select cables. Worked when installed but was "tight" when selecting/shifting, an oiling could fix them right up: $20 ea
EGR Tube w/stock heat cover and no visible cracks
Door Lock Trim: $5 ea
Fiero locking lug nuts with lock key: $20
Drivers/Passengers door gaskets from 69k mile Fiero. Good condition with a few nicks here and there: $20ea
87 V6 Engine
Project L67 Fiero[This message has been edited by Jfrost (edited 09-10-2015).]
