  The Mall
  Getting out of Fieros - Car and Parts for sale
Getting out of Fieros - Car and Parts for sale by 88Ironduke
Started on: 10-03-2014 12:19 PM
Replies: 18 (1010 views)
Last post by: 88Ironduke on 10-08-2014 11:21 PM
88Ironduke
Report this Post10-03-2014 12:19 PM Click Here to See the Profile for 88IrondukeSend a Private Message to 88IrondukeEdit/Delete MessageReply w/QuoteDirect Link to This Post
It been a while since I posted on here. I retired from the USAF a few years back and now have my fathers 1972 C-10 pick up in work. The old Fiero I tinkered with has lost its fun for me and needs to go.
Up for sale is a 1988 Fiero with a junk yard Series 1 3800 n/a with a 4T60E transmission from a 94 Bonneville Vin L. The car started out as a base model coupe and I added the fast back section, nose and ground FX. I added power windows, power door locks and power mirrors, rear sway bar. Also has rear window defrost, Space Coast Fiero single piece tail light assembly, 17" Excel Rims (1 has road rash from my teen age driver). It has a Purple Reign dropped alternator bracket but I figured out it can be used a N/A motor with the alternator installed but it carries the belt very well It has saddle brown interior with the usual minor tear in the drivers seat, interior is ok but the stereo surround is unbroken... Come with Panasonic MP3/WMA cd player and rear wing/spoiler. Car runs and drives with valid NJ inspection. New alternator, new battery and new starter. I have put a 2000 miles on the drive train, its pretty solid. The car is in primer black but is actually a red coupe. Its not a show car and never would be, but its also a fun car to flog the snout out of, hooks up and drives straight. Two issues I haven't been able to resolve is low oil pressure after an hour or so of driving, never gets to below 10 psi at idle and also doesn't like to start when hot, acts like a dead battery. If it sits for 15 or 20 minutes starts fine. I lost the passenger side 1/4 window this winter, haven't wanted to spend any $$ on it. I need this gone. Starting the bidding out at 1800 or best offer.
Thanks
88Ironduke
[This message has been edited by 88Ironduke (edited 10-03-2014).]
88Ironduke
Report this Post10-03-2014 12:28 PM Click Here to See the Profile for 88IrondukeSend a Private Message to 88IrondukeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Also for sale is an 88 coupe front K member complete stock front suspension. Wheel bearing are old but roll, poly bushings and solid steering rack. 200 local pick up only.
Also a solid 88 rear cradle from automatic, 50 bucks local pick up.
I also have a set of rear Monroe struts, assembled with coupe springs free to a good home, rear trailing arm links for an 88, 50 dollars plus shipping and a couple of rear brake calipers with working slider bushings, 25 per caliper plus shipping.
Everything is subject to negotiation so please help me clean out some of this stuff.
Thanks.
88Ironduke
tshark
Total ratings: 68
Report this Post10-03-2014 12:59 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
So, the right mirror in the pic is gone?
Is the right 1/4 window broken/missing?
Did you convert the instrument cluster to 120MPH, or still the old one? Does it still have the original rack, or the upgraded rack?
Sorry you're getting out of Fieros, but glad you're letting someone else continue the fun.
88Ironduke
Report this Post10-03-2014 01:07 PM Click Here to See the Profile for 88IrondukeSend a Private Message to 88IrondukeEdit/Delete MessageReply w/QuoteDirect Link to This Post
the mirror on the right side is there, the 1/4 window went off when the roads were just horrible this winter. The dash cluster is from an 88GT that I pulled from a junk yard many years ago, the original cluster is long gone but the odometer is accurate at 122K.
edit: The steering rack in the car is original to my knowledge. I never had to R2 it.
Thanks for looking.
88Ironduke
Camel
Report this Post10-03-2014 01:19 PM Click Here to See the Profile for CamelClick Here to visit Camel's HomePageSend a Private Message to CamelEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
turbo86se
Report this Post10-03-2014 09:08 PM Click Here to See the Profile for turbo86seSend a Private Message to turbo86seEdit/Delete MessageReply w/QuoteDirect Link to This Post
I could really use the '88 cradle. I'm close enough to pick up on a day off. If we could meet in Lancaster, PA Monday would work. Any chance?
88Ironduke
Report this Post10-03-2014 10:27 PM Click Here to See the Profile for 88IrondukeSend a Private Message to 88IrondukeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry but I work a pretty long day and just don't have time to head to Lancaster. Thanks for looking.
Paul
bonaduce
Report this Post10-04-2014 09:10 AM Click Here to See the Profile for bonaduceSend a Private Message to bonaduceEdit/Delete MessageReply w/QuoteDirect Link to This Post
pm sent
88FIERO58
Report this Post10-04-2014 11:05 AM Click Here to See the Profile for 88FIERO58Send a Private Message to 88FIERO58Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
88Ironduke
Report this Post10-04-2014 11:21 AM Click Here to See the Profile for 88IrondukeSend a Private Message to 88IrondukeEdit/Delete MessageReply w/QuoteDirect Link to This Post
All PMs replied to.
88
88FIERO58
Report this Post10-04-2014 03:54 PM Click Here to See the Profile for 88FIERO58Send a Private Message to 88FIERO58Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent back
Thanks
ninjayogi
Report this Post10-04-2014 04:57 PM Click Here to See the Profile for ninjayogiSend a Private Message to ninjayogiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Where did you get those tail lights. I would like to get some exactly like them.
88Ironduke
Report this Post10-04-2014 06:53 PM Click Here to See the Profile for 88IrondukeSend a Private Message to 88IrondukeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Space coast fieros made them for me several years ago. Pricey at the time as I didn't have gobs to put into car. Thanks for looking.
turbo86se
Report this Post10-05-2014 09:43 AM Click Here to See the Profile for turbo86seSend a Private Message to turbo86seEdit/Delete MessageReply w/QuoteDirect Link to This Post
Paul
Thanks Paul, I'm outta town end of this week, going to Nebraska (PJ) but if you have it next week I'll swing out and pick it up. Thanks!
88Ironduke
Report this Post10-05-2014 12:29 PM Click Here to See the Profile for 88IrondukeSend a Private Message to 88IrondukeEdit/Delete MessageReply w/QuoteDirect Link to This Post
It will be here I suspect. Bump.
88FIERO58
Report this Post10-05-2014 03:56 PM Click Here to See the Profile for 88FIERO58Send a Private Message to 88FIERO58Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM Sent
WITH OFFER
THANKS
88Ironduke
Report this Post10-05-2014 10:09 PM Click Here to See the Profile for 88IrondukeSend a Private Message to 88IrondukeEdit/Delete MessageReply w/QuoteDirect Link to This Post
UPDATE: Brake calipers are sold and engine cradle are sold is sold to 88Fiero58.
Thanks guys for helping me move this stuff.
Paul
[This message has been edited by 88Ironduke (edited 10-05-2014).]
88FIERO58
Report this Post10-06-2014 09:20 PM Click Here to See the Profile for 88FIERO58Send a Private Message to 88FIERO58Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for your help and having items that I need and can use.
This will get another 88 coupe back on the road.
88Ironduke
Report this Post10-08-2014 11:21 PM Click Here to See the Profile for 88IrondukeSend a Private Message to 88IrondukeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Car still for sale, taking offers. Bump
