  The Mall
  Need a new Front CrossMember/Steering Rack Mount
Need a new Front CrossMember/Steering Rack Mount by DKcustoms
Started on: 10-18-2014 07:40 PM
Replies: 7 (311 views)
Last post by: L.I. Fieros on 10-30-2014 08:53 AM
DKcustoms
Report this Post10-18-2014 07:40 PM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I will post pictures once my phone decides to function properly, but I am looking for the front Frame CrossMember.
I need the member that runs across underneath the car that the upper control arm and the front half of the lower bolt to, as well as the steering rack,
as well as the support arms that run off of this member to the frame ends.
Mine is usable, but I would much rather reassemble my suspension off the car, on a freshly painted and nonrusty crossmember instead of just having to dissassemble everything again in the spring to sandblast the crossmember anyway
the crossmember i'm referring to
support arms I need
Rust i'm fighting
[This message has been edited by DKcustoms (edited 10-18-2014).]
Shade Tree Fiero
Report this Post10-18-2014 08:17 PM Click Here to See the Profile for Shade Tree FieroSend a Private Message to Shade Tree FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
What year .
DKcustoms
Report this Post10-18-2014 08:19 PM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
86, my bad.
Was about to add that because I noted that the FieroStore carries new 88 crossmembers
L.I. Fieros
Report this Post10-19-2014 10:27 AM Click Here to See the Profile for L.I. FierosSend a Private Message to L.I. FierosEdit/Delete MessageReply w/QuoteDirect Link to This Post
It looks like yours is an early 86 crossmember, meaning it doesn't have the extra reinforcements that the later crossmembers had.
I have an early 86 crossmember here (same as yours) that I ended up not using. Pics are below if you're interested. It was in great condition and very clean to start with. I painted it with POR15 anyway to protect it even more. It hasn't been on a car since painting.
Drop me a PM if you're interested.
[This message has been edited by L.I. Fieros (edited 10-19-2014).]
DKcustoms
Report this Post10-19-2014 05:10 PM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
You should have a PM in a second
L.I. Fieros
Report this Post10-20-2014 08:34 AM Click Here to See the Profile for L.I. FierosSend a Private Message to L.I. FierosEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM replied to.
DKcustoms
Report this Post10-29-2014 07:51 PM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bought L. I. Fieros.
Thanks
L.I. Fieros
Report this Post10-30-2014 08:53 AM Click Here to See the Profile for L.I. FierosSend a Private Message to L.I. FierosEdit/Delete MessageReply w/QuoteDirect Link to This Post
Glad you could use it! Thanks again!
