More stuff found while cleaning out my old 'instrument cluster project' box.. All prices plus actual shipping; can either do Priority or cheapest regular mail option..
One 120mph backlit speedometer. 97856 miles on the odometer. $10 (actually have a second one, but odometer holding plastic is broken off, needle is clear, missing pins.. Could be 85mph housing swap candidate? $5)
Two V6 backlit tachometers. One missing the stopper pin, other one has broken stopper pin... One V6 backlit tachometer, missing stopper pin - $5
One backlit water temp / gas gauge $5One center console-mounted battery voltage / oil pressure gauge. No outer housing or clear lens, and for some reason I removed the Fiero plug and soldered on a ribbon cable.. Must have been experimenting with a non-equipped car..? $5Clear instrument cluster cover, definitely needs a polish if you want it to look presentable. $ Free + shipping
Two metal instrument cluster plates - the ones with the 'idiot lights'.. Some rusting, one more so than the other - would need a re-paint to look presentable. Was going to say 'maybe for a project' if you wanted the idiot light plastic things, but even those have some scratches from storage... $ Free + shipping
Everything gone, thanks everyone!
[This message has been edited by Riceburner98 (edited 03-25-2015).]
