  The Mall
  84-87 front hubs for brake conversion
84-87 front hubs for brake conversion by sluppy123
Started on: 04-08-2015 05:25 PM
Replies: 12 (1384 views)
Last post by: I FAR I on 02-18-2017 01:39 PM
sluppy123
Report this Post04-08-2015 05:25 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I made these for someone and they backed out. Brand new brakebest rotors were used to make them. New races installed along with the correct longer wheel studs. I turned them small enought for the grand am swap. Also turned the face back a little to increase the length of the centering ring. Will work with all other swaps also. Pics to follow.
Might have an additional set available also, I made a big run for some local guys.
$165 shipped.
Riddick85
Report this Post04-08-2015 07:54 PM Click Here to See the Profile for Riddick85Send a Private Message to Riddick85Edit/Delete MessageReply w/QuoteDirect Link to This Post
Pm sent
sluppy123
Report this Post04-08-2015 08:16 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
This was taken before I installed the longer wheel studs. They are boxed and ready to ship
1MohrFiero
Total ratings: 157
Report this Post04-09-2015 07:20 PM Click Here to See the Profile for 1MohrFieroSend a Private Message to 1MohrFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM me your Paypal if you still have a set available.
Thanks,
Dwayne
sluppy123
Report this Post04-13-2015 03:12 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I still have one set left if anyone wants them.
katatak
Total ratings: 82
Report this Post04-13-2015 10:59 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll take em Sluppy. PM your paypal info.
Thanks
Pat
sluppy123
Report this Post04-15-2015 03:52 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks
Pat
I sent you a PM a few days ago. If you want them let me know otherwise they are still available if anyone else is interested.
katatak
Total ratings: 82
Report this Post04-15-2015 07:34 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got it Brian, PM'd back - Paypal this evening.
sluppy123
Report this Post06-23-2015 12:12 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have one set of these available anybody need them?
darbysan
Report this Post06-24-2015 11:03 AM Click Here to See the Profile for darbysanSend a Private Message to darbysanEdit/Delete MessageReply w/QuoteDirect Link to This Post
i'll take them.
pm sent.
sluppy123
Report this Post09-25-2015 03:36 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have three sets available for immediate shipment. The ones I have now CANNOT be used on the grand am swap. For some reason I got 6 new brake best rotors in that use a wheel stud with a bigger knurl. This means I couldn't turn them small enough to fit inside the grand am rotor. They will work fine with any other swap. Because of the stud knurl issue I did not install longer studs, I turned the face off a little making the studs stick out more. Still have 100% thread engagement on the lug nut.
$120 for a pair shipped. If you need a set for the grand am swap just ask I can order another batch of rotors.
sluppy123
Report this Post09-28-2015 11:10 AM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have two sets left. These cannot be used on the grand am swap but will work for all others.
I FAR I
Report this Post02-18-2017 01:39 PM Click Here to See the Profile for I FAR ISend a Private Message to I FAR IEdit/Delete MessageReply w/QuoteDirect Link to This Post
Question: Greetings, are these still available for purchase?
Thanks
