  The Mall
  Brake brackets for sale, C4 rotors on your 88 (Page 2)
Brake brackets for sale, C4 rotors on your 88 by sluppy123
Started on: 04-21-2015 03:04 PM
Replies: 126 (7451 views)
Last post by: sluppy123 on 08-06-2022 08:39 PM
sluppy123
Report this Post05-07-2015 03:55 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by blakeinspace:
I have several Sluppy parts on my Formula, including his 12" brackets, been running them for years with no issues.
I have lowering springs on all corners and had to grind a little bit on the drivers front... That was the only fitment issue at full lock. Nice to keep the e-brake cable too! Do yourself a favor and just buy the bolts from him. It is hardly cheaper than going to Fastenal and rooting around for the right stuff.
Thanks for the good words Blake! Glad to hear your brackets have held up in the long-term!! I'm slowly starring to make fiero parts again, planning on offering my version of the c5/c6 13" swap soon as well as the strut tower caps and hood strut kits.
fieroloco
Report this Post05-19-2015 01:49 PM Click Here to See the Profile for fierolocoClick Here to visit fieroloco's HomePageSend a Private Message to fierolocoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Paypal sent
oldschoolbilly
Report this Post05-26-2015 01:17 PM Click Here to See the Profile for oldschoolbillySend a Private Message to oldschoolbillyEdit/Delete MessageReply w/QuoteDirect Link to This Post
You have a PM
sluppy123
Report this Post05-28-2015 04:58 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have a few sets available, send me a PM if interested.
Also to those that have bought a set. Let me know if your centering rings don't fit, I may have shipped you pre 88 rings by mistake!
RMOR235
Report this Post05-28-2015 05:23 PM Click Here to See the Profile for RMOR235Send a Private Message to RMOR235Edit/Delete MessageReply w/QuoteDirect Link to This Post
can i use this if i do the c4 swap for an 84-87?
sluppy123
Report this Post05-29-2015 11:02 AM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
No, these only work on 88's
nosrac
Total ratings: 50
Report this Post05-29-2015 12:51 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you offer a 5x100 re drill on the corvette rotors?
I saw 2 front zinc plated C4 rotors on eBay for ~$80 shipped.
[This message has been edited by nosrac (edited 05-29-2015).]
sluppy123
Report this Post05-29-2015 03:58 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I can easily drill them but shipping costs would be a killer. Even with usps flat rate I can only get two rotors in a large box. And that's $13 for each box. Send me a PM and we can discuss.
Roberthetrucker
Report this Post06-01-2015 07:17 PM Click Here to See the Profile for RoberthetruckerSend a Private Message to RoberthetruckerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'd like a set of the 12" rotor adapters..front an rear...with the wheel studs please, if you have them
thanks robert
sluppy123
Report this Post06-01-2015 11:28 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
thanks robert
PM sent, nothing needs to be done to the wheel studs for this swap.
Tom Slick
Report this Post06-02-2015 08:35 AM Click Here to See the Profile for Tom SlickSend a Private Message to Tom SlickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a question, are these the same design you've sold in the past?
When I installed mine that I bought several years ago, I had to grind the
Inside of the caliper bridge for the rotor to not rub. Just wondering if these
new ones eliminate this problem.
Thanks
LostNotForgotton
Report this Post06-02-2015 01:31 PM Click Here to See the Profile for LostNotForgottonClick Here to visit LostNotForgotton's HomePageSend a Private Message to LostNotForgottonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll take a set for front and rears as well as the bolts to go along with them.
87 Fiero GT 3.4 Pushrod with 7730 ECM & DIS
88 MERA #8013
85 Fiero SE with 3.1 pushrod
86 Fiero SE 2.8 stock
http://www.youtube.com/LostNotForgotton
sluppy123
Report this Post06-02-2015 03:41 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Tom,
Same design as I sold before. Using 7075 aluminum now, used steel in the past. 7075 is stronger than steel and way lighter.
Some people need to grind some don't, really varies between cars. The c4 rotors need to be from 88-95 fronts as the hat design of other years rubs.
Riddick85
Report this Post06-03-2015 12:24 PM Click Here to See the Profile for Riddick85Send a Private Message to Riddick85Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got any pics behind 17" wheels?
I have some 17" wheels in mind but will go 18" if need be.
Thx 4 all your help.
I bought the brackets from sluppy123 but mine are for my 85 not an 88. Mine are also C6 brakes but they have a 12" rotor so the clearances should be similar.
Full picture of brakes with wheel
http://i.imgur.com/Gc99qcB.jpg
How close they are to the spoke
http://i.imgur.com/oQ7dD28.jpg
How close they are to the inside of rim
http://i.imgur.com/FyKGRAH.jpg
I could not get my wheels balanced the normal way due to the weights hitting the caliper. Whatever the width of a .25oz weight is is too thick to fit between, so they are very close. Net every set of 17' rims will fit more than likely, I got lucky that the ones I had work just fine. Unless you have the rim in front of you to measure things, I would just buy an 18" rim just to be good.
[This message has been edited by Riddick85 (edited 06-03-2015).]
sluppy123
Report this Post06-03-2015 02:24 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the pictures but thse brackets use the 12"c4 rotors and the stock 88 calipers. The brackets you have use the c5/c6 rotors and calipers. You said they were close but damn!! That looks tight!!
87convert
Report this Post06-04-2015 11:21 PM Click Here to See the Profile for 87convertSend a Private Message to 87convertEdit/Delete MessageReply w/QuoteDirect Link to This Post
pm sent.
fieroloco
Report this Post06-10-2015 09:43 AM Click Here to See the Profile for fierolocoClick Here to visit fieroloco's HomePageSend a Private Message to fierolocoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got my brackets .thanks
GOT2B GM
Report this Post06-10-2015 10:28 AM Click Here to See the Profile for GOT2B GMSend a Private Message to GOT2B GMEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm interested in a set with bolts. Please PM me. Thanks!
sluppy123
Report this Post06-11-2015 01:52 AM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just sold my last set I had machined. Ordered more material today. Will post here when I have them ready to ship.
sluppy123
Report this Post06-22-2015 09:24 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have mire of these machined if anybody is interested, send me a pm.
Roberthetrucker
Report this Post06-27-2015 04:27 AM Click Here to See the Profile for RoberthetruckerSend a Private Message to RoberthetruckerEdit/Delete MessageReply w/QuoteDirect Link to This Post
$13 a box for the shipping on two rotors is pretty good...I just had a machine shop punch my rotors and it cost me $160 FRICKIN BUCKS!!!
sluppy123
Report this Post07-15-2015 06:41 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bump to the top. I have several sets available if anyone is interested.
sluppy123
Report this Post09-01-2015 08:38 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have a few sets available, probably the last time I will have them.
2tone86gt
Report this Post09-02-2015 10:00 PM Click Here to See the Profile for 2tone86gtSend a Private Message to 2tone86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump because this is a cool setup
LostNotForgotton
Report this Post09-06-2015 02:19 PM Click Here to See the Profile for LostNotForgottonClick Here to visit LostNotForgotton's HomePageSend a Private Message to LostNotForgottonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll take another set. I just picked up an 88 Formula yesterday and I might as well give it more stopping power.
88 MERA #8013
Danyel
Total ratings: 169
Report this Post09-06-2015 07:03 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
rourke_87_T-Top
Report this Post09-08-2015 11:13 PM Click Here to See the Profile for rourke_87_T-TopSend a Private Message to rourke_87_T-TopEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can you run 16" wheels or is 17"+ a requirement?
Thx
These brackets look like the ones from FieroAddiction and if they are an exact copy, I was able to fit my 15" wheels. It only required removing about an 1/8" off the corner of the caliber bridges. No biggie !
Danyel
Total ratings: 169
Report this Post09-19-2015 12:40 AM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Brackets received.........work of art THX
My Build Thread
Tylers Toy
j bf1
Report this Post10-04-2015 09:17 AM Click Here to See the Profile for j bf1Send a Private Message to j bf1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by sluppy123:
These brackets are for 88 fieros. Use the stock calipers and C4 rotors front and rear. You will need the 88-95 front rotors from the corvette. These brackets rotate the caliper up so there are no problems when making a tight turn. 7075 Aluminum, powder coated black. Includes 4 centering rings and 2 left and 2 right brackets. You will also need four M12x1.75 bolts 30mm long. Use grade 10.9 or better. I can provide these bolts if need for another $5, most hardware stores carry them. Also on some cars the lower control arm my rub the rotor, a little work with an angle grinder will fix this.
$75 shipped
Are these still available?
Thanks ,
John
j bf1
Report this Post10-04-2015 11:00 AM Click Here to See the Profile for j bf1Send a Private Message to j bf1Edit/Delete MessageReply w/QuoteDirect Link to This Post
j bf1
Member since Dec 2011
$75 shipped
Thanks ,
John
sluppy123
Report this Post10-04-2015 12:49 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I always have several sets available.
j bf1
Report this Post10-05-2015 11:12 AM Click Here to See the Profile for j bf1Send a Private Message to j bf1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys! Good to hear you got them. Waiting on material to make more now, also working on 13" C5/6 rotors and caliper mounts now. They will be the same as these, 7075 high strength aluminum, one piece cnc cut and powder coated.
Hey there, are these available yet?
j bf1
Report this Post10-05-2015 11:13 AM Click Here to See the Profile for j bf1Send a Private Message to j bf1Edit/Delete MessageReply w/QuoteDirect Link to This Post
j bf1
sluppy123
Report this Post10-05-2015 11:21 AM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
The C5 stuff is here. https://www.fiero.nl/forum/Forum4/HTML/071924.html
Rear parts for the front c5 are coming this week.
Danyel
Total ratings: 169
Report this Post10-05-2015 11:21 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Will you be doing 13' for the 88 ??
regards
Danyel
Black Widow Build Thread 2007 - 2014
Tylers Toy
sluppy123
Report this Post10-06-2015 12:11 AM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
regards
Danyel
I will be getting my formula in my shop in the next few weeks, I may try and develop something to mount the c5 stuff on the front, I may also try the rear. I have most of the rear parts sitting around from when I tried to put the on the rear of pre 88 cars.
flustin
Report this Post10-08-2015 06:54 PM Click Here to See the Profile for flustinSend a Private Message to flustinEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent to get in line for a set as well, I hope you still have some or are making more. My car could sure use some more braking power.
sluppy123
Report this Post10-08-2015 08:15 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have several sets available, pm'd you back.
Danyel
Total ratings: 169
Report this Post10-24-2015 06:58 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fieroguru use to make the 13 inch using the fiero calipers without any mods just brackets .... these had a dog bone shape maybe look up this old sale thread ... many are wanting these ... me included. I do have your 12 inch kit but behind 18's they still look small .... let me know .
regards
Danyel
Tylers Toy
fireboss
Total ratings: 58
Report this Post10-24-2015 07:10 PM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
