  The Mall
  c5 Corvette rotors and calipers on you 84-87, mounting brackets (Page 1)
c5 Corvette rotors and calipers on you 84-87, mounting brackets by sluppy123
Started on: 05-08-2015 01:51 AM
Replies: 77 (5740 views)
Last post by: renderareason on 07-21-2020 10:07 AM
sluppy123
Report this Post05-08-2015 01:51 AM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I designed and machined these brackets for the front of 84-87 fieros. They mount C5 corvette 13" rotors and calipers on the front. The brackets are one piece machined from 7075 Aluminum and powder coated black. I will include the required grade 10.9 M14x2 caliper mounting bolts and grade 8 7/16" bracket bolts and nuts. I will also include the required centering ring turned from 6061 Aluminum.
These are the parts I used to complete the install. All were purchaced from rockauto.com The rotors are slotted and drilled and come with pads, the calipers are rebuilt and include the caliper mount.
Power stop rotor and pad kit, K1559-26
A-1 cardone caliper 18-B4702
A-1 cardone caliper 18-B4703
Dorman Banjo bolt 13912 2 needed
Price for 2 brackets, 4 caliper mounting bolts, 4 bracket mounting bolts and two centering rings $150 shipped
For an extra $150 I can provide new front hubs with the correct 2" long wheel studs installed. I use new fiero front rotors, Brake-Best brand. I turn off the rotor portion, turn the face of the hub back to compensate for the vette rotor thickenss and install Dorman 2" long wheel studs.
[This message has been edited by sluppy123 (edited 05-17-2017).]
Riddick85
Report this Post05-09-2015 02:01 PM Click Here to See the Profile for Riddick85Send a Private Message to Riddick85Edit/Delete MessageReply w/QuoteDirect Link to This Post
These will work on C6 Corvette brakes also correct?
sluppy123
Report this Post05-09-2015 09:13 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I don't see why they wouldn't, the c6 calipers have a slightly different design to stiffen them but they mount the same. C5 parts are cheaper.
Inferno
Report this Post05-10-2015 10:37 PM Click Here to See the Profile for InfernoSend a Private Message to InfernoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are those C5 Rotors? They have the same bolt pattern? 5x100?
sluppy123
Report this Post05-11-2015 01:16 AM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
No, the c5 rotors need the fiero 5x100 bolt pattern drilled into them.
ericjon262
Total ratings: 67
Report this Post05-15-2015 12:07 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent.
Fierofreak00
Total ratings: 170
Report this Post05-15-2015 10:19 AM Click Here to See the Profile for Fierofreak00Send a Private Message to Fierofreak00Edit/Delete MessageReply w/QuoteDirect Link to This Post
How about a set for the rear, are you still making parts? I'd like a complete set, I bought the corvette calipers years ago, and still haven't gotten anyone to make a set of brackets for all four wheels. -Jason
TXOPIE
Report this Post05-15-2015 10:24 AM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Howdy Fierofreak00...been a while!
I just PM's him the same question this morning....I need 2 sets as well!
sluppy123
Report this Post05-15-2015 11:13 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I would gladly design something that uses the c5 parts for the rear, but I don't have access to a 84-87 rear end. My 87GT has an 88 cradle and the other car I own is a 88 formula.
I have made brackets in the past to hold the c4 calipers on the rear. Looking for the files and prints now.
Fierofreak00
Total ratings: 170
Report this Post05-18-2015 08:27 AM Click Here to See the Profile for Fierofreak00Send a Private Message to Fierofreak00Edit/Delete MessageReply w/QuoteDirect Link to This Post
Splendid!
Fierofreak00
Total ratings: 170
Report this Post05-26-2015 01:21 PM Click Here to See the Profile for Fierofreak00Send a Private Message to Fierofreak00Edit/Delete MessageReply w/QuoteDirect Link to This Post
any luck?!
mugsman
Report this Post05-27-2015 12:01 PM Click Here to See the Profile for mugsmanSend a Private Message to mugsmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
sluppy123
Report this Post05-28-2015 04:31 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
If anyone is interested in the c5 front brackets or hubs send me a PM and I will cut you a deal. Parts are just sitting and I need to at least break even on them. I only have one set of hubs left and 6 sets of brackets. Letting them go cheap, so if yours thinking about doing this swap get the parts while I have them.
[This message has been edited by sluppy123 (edited 05-29-2015).]
Riddick85
Report this Post06-02-2015 11:24 AM Click Here to See the Profile for Riddick85Send a Private Message to Riddick85Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just posting as a happy customer who bought these. I used C6 brakes since they mount the same as C5 but both would work. Feels amazing with new brakes
http://i.imgur.com/JhPfV3M.jpg
sluppy123
Report this Post06-02-2015 04:25 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
They look great! Thanks for sharing a picture.
LostNotForgotton
Report this Post06-02-2015 05:22 PM Click Here to See the Profile for LostNotForgottonClick Here to visit LostNotForgotton's HomePageSend a Private Message to LostNotForgottonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice work! I'd defintitely like to pick up a set at some point especially if you can adapt the rears as well. I'd be all over it if you could make an all around set. Having just the front must create some crazy brake bias. Right now my budgets getting thin from buying up 3800 conversion parts otherwise I'd take a set as well as the hubs now.
87 Fiero GT 3.4 Pushrod with 7730 ECM & DIS
88 MERA #8013
85 Fiero SE with 3.1 pushrod
86 Fiero SE 2.8 stock
http://www.youtube.com/LostNotForgotton
sluppy123
Report this Post06-02-2015 08:46 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm looking for a cradle now to mock parts up on, I will need someone to test them when I get them done. I'm guessing about 3-4 weeks depending on how long it takes to find a cradle.
LostNotForgotton
Report this Post06-02-2015 10:05 PM Click Here to See the Profile for LostNotForgottonClick Here to visit LostNotForgotton's HomePageSend a Private Message to LostNotForgottonEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's a shame you don't live closer. I have a spare craddle with control arms and knuckles that I intend on using to build up my 3800. You could have used it until I was ready for it.
[This message has been edited by LostNotForgotton (edited 06-02-2015).]
sluppy123
Report this Post06-12-2015 08:45 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Dropped the price. I have three sets left. Need them gone before I can start designing the rear.
LostNotForgotton
Report this Post06-13-2015 02:54 PM Click Here to See the Profile for LostNotForgottonClick Here to visit LostNotForgotton's HomePageSend a Private Message to LostNotForgottonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I may be interested in a set if you have plans on creating a rear set. I may also be interested in hubs too. Lemme know a price and I'll see if it's within my budget.
fierogt455
Report this Post06-13-2015 10:22 PM Click Here to See the Profile for fierogt455Send a Private Message to fierogt455Edit/Delete MessageReply w/QuoteDirect Link to This Post
You have a PM.
fierogt455
Report this Post06-14-2015 09:42 PM Click Here to See the Profile for fierogt455Send a Private Message to fierogt455Edit/Delete MessageReply w/QuoteDirect Link to This Post
Payment sent.
weloveour86se
Total ratings: 75
Report this Post06-14-2015 10:42 PM Click Here to See the Profile for weloveour86seSend a Private Message to weloveour86seEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent.
Easy8
Report this Post06-15-2015 11:11 AM Click Here to See the Profile for Easy8Send a Private Message to Easy8Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
Easy8
Report this Post06-16-2015 08:01 PM Click Here to See the Profile for Easy8Send a Private Message to Easy8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Payment sent... think there are two more left, get em now while you can.
fierogt455
Report this Post06-26-2015 05:54 PM Click Here to See the Profile for fierogt455Send a Private Message to fierogt455Edit/Delete MessageReply w/QuoteDirect Link to This Post
Received parts today! Thanks
fierogt455
Report this Post08-16-2015 01:46 AM Click Here to See the Profile for fierogt455Send a Private Message to fierogt455Edit/Delete MessageReply w/QuoteDirect Link to This Post
sluppy123,
You have a pm.
lorennerol
Report this Post08-16-2015 10:14 AM Click Here to See the Profile for lorennerolSend a Private Message to lorennerolEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is the minimum inside diameter required for these to fit? I'm guessing they won't go on the stock GT lace wheels?
Very nice looking work, by the way.
sluppy123
Report this Post08-16-2015 04:25 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
These will definitely NOT work with 15" or 16" wheels.
sluppy123
Report this Post09-01-2015 08:25 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have several sets available. $120 shipped.
[This message has been edited by sluppy123 (edited 09-28-2015).]
fierogt455
Report this Post10-03-2015 12:44 AM Click Here to See the Profile for fierogt455Send a Private Message to fierogt455Edit/Delete MessageReply w/QuoteDirect Link to This Post
You have a pm.
sluppy123
Report this Post10-11-2015 04:24 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I now have a rear option that works very well with the C5 fronts.
These brackets allow the use of 88-95 Rear C4 12" rotors and 88 Fiero rear calipers. Using the 88 Fiero caliper allows you to have an e-brake, nothing needs to be done to the cables or the calipers. When you install the calipers you will need to swap sides, Driverside on the pass side and pass side on the driverside. This will put the bleeder facing down requiring you to bleed the calipers off the car, I have done it several times and it isn't hard to do. Also the Threaded holes that hold the bracket to the knuckle will need to be drilled out and tapped with a M12x1.75 tap, I will include the required drill bit and Tap with each set of brackets.
All parts are available from Rockauto-
Power Stop Drilled and slotted rotors, AR8241XPR $41.79 ea
Centric1988 Fiero Left Rear caliper, w/ all brackets and hardware- 14162533 $126.79ea That includes the $70 core
Centric1988 Fiero Right Rear caliper, w/ all brackets and hardware- 14162534 $126.79ea That includes the $70 core
$140 shipped will get you two brackets, milled from 7075 Aluminum and powder coated black, 2-6061 aluminum rotor centering rings, the required M12x1.75 mounting bolts and the Drill and M12x1.75mm tap. You can knock $10 off that price if you don't need the drill and tap.
fierogt455
Report this Post11-02-2015 08:31 PM Click Here to See the Profile for fierogt455Send a Private Message to fierogt455Edit/Delete MessageReply w/QuoteDirect Link to This Post
I finally finished my C5 front brake upgrade on my GT! This was an extremely easy swap; Sluppy123's parts are well designed. I will be doing the rear with his 12" kit utilizing the 88 calipers.
I did encounter one problem. I am running older 17" Azul Luz wheels, they scraped the caliper. I think I could resolve the problem by grinding the ribs off the caliper but this is a good excuse to upgrade the wheels on the GT.
I will probably use the Azul wheels on the SE after doing the front/rear upgrade using Sluppy123's 12" kit. I just need to find some time!
[This message has been edited by fierogt455 (edited 11-02-2015).]
DKcustoms
Report this Post11-03-2015 12:52 AM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
what would it take to make brackets for the 88s?
gtxbullet
Report this Post11-04-2015 07:46 PM Click Here to See the Profile for gtxbulletSend a Private Message to gtxbulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm waiting for this being available for an 88.
Danyel
Total ratings: 171
Report this Post11-04-2015 08:10 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Me too I'm waiting for an 88 kit ... I did buy his 12 in but rather wait for the 13 in version ...
Black Widow Build Thread 2007 - 2014
Tylers Toy
sluppy123
Report this Post11-05-2015 12:55 AM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just got an 88 formula into my shop. I will use it to mock up 13" c5/c6 parts on in the next few weeks. Need to order some calipers and rotors to play with.
DKcustoms
Report this Post11-05-2015 02:02 AM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Excellent.
Sign me up sir.
My 88's brakes are tired, so I'm looking for front and rear, always willing to be a guinea pig.
sluppy123
Report this Post11-11-2015 02:01 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bad news to those wanting to mount c5/c6 stuff on your 88's.After looking at things and trying to mount the caliper there is just no way to make it work easily. Definitely not with a simple mounting bracket. The stock caliper mount will not allow enough room to mount the bigger c5 caliper. It would need cut off to allow things to fit and that does no good in mounting another caliper.
Danyel
Total ratings: 171
Report this Post11-11-2015 06:16 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fieroguru used to make these 13'' swap .... using the OEM 88 calipers
[This message has been edited by Danyel (edited 11-11-2015).]
