Pun intended Long story short, I found my dream fiero, an 88 formula! I don't have room in the garage for it, so everything else 84-87 must go! I am starting things out at discounted prices and am open to offers on pretty much anything, as I want it all GONE ASAP! Unfortunately a lot of it is too big/heavy to ship, so local pickup only unless you really want to spend the $ for it.
Body panels. Not sure what car they're off of, the decklid shows 2m4. Decklid, $25. Gas cap, $5 Fenders, $25 each Hood with headlight covers, $25 (SOLD) Sunroofs, $25 each (1 SOLD) Headlight covers (separate from the hood+covers above), $15 for the pair (SOLD) Rear glass (with some tint on it), $25 Roof panel (SOLD) Rear panels, $25 each Aero nose off an 86 GT. Used in chumpcar, fair condition. $25 Falken Azenis RT615, 205/50/R15. Used. Two sets, one with wheels and one without. $35 each for the set with wheels, $25 each for the set without Scratch inside one wheel Wear on set with wheels Wear on set without wheels
More in the next post
[This message has been edited by kwagner (edited 05-22-2015).]
I do have some in one of the boxes of bolts. I'll see what I can dig up. In the meantime, on with the show!
Steering wheel, $10 Headlights. I believe I have 3 pair, should be all 1st gen. $30 for a set (foot and sandal not included ) Battery tray from summit (with box), $10 Various size racing seats. I can get better dimensions if anyone is interested. Make offer Pair of great condition seats, I believe out of an 86. No bolster rips or anything that I can see. (SOLD) Trunk carpet, $15 (SOLD) Front and rear set of HHP adjustable swaybars, competition level for 84-87. Never got around to installing, and now I can't with an 88 $500 for the pair! MSD 7AL-2 system, needs rebuilt. $5 Coilover perches, not sure what they fit. Set of 4 for $10 Exhaust manifold w/ o2 sensor. $10 Center console, $5 Misc parts, $5 each (SOLD) Getrag transmission. Don't remember what it came out of. $50 Heat shield, $5 84 4 speed, not sure econ or perf. $25 KMunson's flushmount headlights. Used but unpainted. $40 for the set (SOLD)
More to come
[This message has been edited by kwagner (edited 06-02-2015).]
Now the final two pieces (that I can dig out right now) in the collection. TWO fieros, $1000 for the pair! Bring a trailer Short history: I bought an 84 to race in chumpcar, which I did in a 14 hour race several years back. Last lap, engine caught fire. Plan was to replace and run again. In the meantime, I got married, moved a couple times, and now don't have time for it. Someone needs to take this car and get it on the track again! I've got a ridiculous price on it because I need the space and I want it to be racing again I'm "throwing in" a full spare running driving car (86 SE) that can be used to get it going again.
First, the 86. It now has just under 337k miles on it The interior looks a bit dusty as there was a fire extinguisher accidentally discharged inside Engine is from one of the_stickman2's old cars. You can read about it here: https://www.fiero.nl/cgi-bin...7028&style=printable It definitely has more get up and go than a typical iron duke! The water pump is leaking but just needs the gasket replaced. Haven't had time to drop the cradle. Clear title. Nearly brand new tires from inspection last year. Inspected through the end of this month. Aftermarket seat covers Manual mirror, the mirror control on the door pops out of place every so often NOT a super duty, but does have the SD4 valve cover due to larger rockers Hooker 'super competition' header, to a fairly short exhaust (which is actually taken from the 84 race car, so it would fit back on perfectly) Paint isn't great up close Map pocket I haven't seen before 5 speed Wing on the back is actually smaller than a GT wing Hood was originally red RPO sticker
Now for the 84. Some of you have probably seen it before in the chumpcar thread here: https://www.fiero.nl/forum/A...130314-1-085472.html A lot of work was done and documented that I didn't make time to put in that thread, but I do have pics from the whole process We raced at Pittsburgh Raceway Park (then BeaveRun) in a 14 hour race. Had a great time, learned a lot, and immediately started making plans for things to change for next year. Then life happened Now it sits in my garage, waiting to relive the glory on the track. Engine is out and all the old wiring was removed to make way for a fresh non-cobbled wiring harness. I put the original nose back on the car. Previously I only had a bill of sale for the car, as it was only ever going to be on the track. Recently my plan was to consolidate the above car and this one into one car and get it titled on the road. I was able to work with the previous owner to get a duplicate title and transferred to me. So it now has a clean transferrable title
Pics:
decklid and covers are just sitting in place, not bolted in, hence the odd angles new wiring harness and fuse box in place some of the roll cage long width mirror more cage hood has vent in it roof was cut into to fix roll cage welding seat belt buckle holds the window net in place driver's seat mounting brackets brake ducting was moved so the car could roll without stepping on it aftermarket brake balancer RPO sticker clean engine bay pretty rust free
Are they functional? Are they adjustable? Is this complete? Any damage? Put me first in line depending on answers.
They work, I've had them on a couple different cars over the years. Complete as far as I remember. They fit the original bolt locations and connect to the existing wiring harness with the same kind of headlamp connectors. They have some screws in them for adjustment. No damage aside from regular wear from installation/removal. You're second in line right now. Jedi is third, based on timestamps (sorry Jedi)
[This message has been edited by kwagner (edited 05-17-2015).]
Look at the timestamp on my PM... It was before any posts on the thread...
jedi's pm was sent 05-17-2015 2:28 PM while fieromonkey's post was 05-17-2015 02:27 PM, if I go by his first post. And there was a PM sent to me before either of those at 2:04 PM, which is first in line. I'm trying to go by timestamp across pm and post and be fair
Originally posted by Monkeyman: The forum needs to get together and decide what defines "1st", PM or post.
I've lost out when I sent a PM first, but didn't post first, AND when I posted first, but didn't PM first. The problem is, the forum is dynamic. Current/future members who don't see such an agreement may do things differently. Even on ebay, I've been the high bidder, and still lost out, somehow.
I assume you're referring to me. (There IS a user going by fieromonkey. )
I'm not mad at ya, kwagner. I'd like the lights but I'm usually a day late and a dollar short so I'm sort of used to it. I'll still take them if Mr. 2:04PM doesn't want them. It's past my bed time so I probably won't be on until the middle of the night. If I "win", PM me your Paypal info and the total and I'll send it to you tonight.
Interested in the roof panel you didn't single out, as seen in the back of your first picture. Is it available as well? I will be interested in more parts upon meeting up, with respect to those who have stated their interests (dibs) on here first. Also may be interested in the hood.
Originally posted by kwagner:
I'm in moon, near the airport. Bring a truck/trailer and take a load
Originally posted by Monkeyman: I assume you're referring to me. (There IS a user going by fieromonkey. )
Whoops, got my monkeys mixed up No problem, I'll let you know.
viperine: Sorry, I thought I posted a pic of it as well. Yes, the roof piece is for sale as well, same $25 as the other body panels. I had another person ask me about it as well via PM, so it might be spoken for. Hood is still available, as are most other panels.
What's the urgency on getting parts out of the way? I'm interested in the Getrag, but may not be able to get that way for a couple of weeks. Good excuse to go visit my dad though...
Any numbers on it?
[This message has been edited by Taijiguy (edited 05-18-2015).]
I could use those black rims badly for mine, but you are a 5 hour drive from me in DE. Anyone traveling to him passing by Newark, DE via 95? I'll pay for the transportation!
Taijiguy: My baby is due end of June and my wife is hardcore nesting, so the garage overflowing with fiero is not a good thing The sooner the better, but things can wait a week or two if I have solid buyers. I can check it for numbers and get back to you.
If it's possible to hold off on pick-up I'm happy to make payment to cement the deal pending any further available info on the specifics of the trans.
Updated the listings. Roof panel, one sunroof, and the seats are SOLD! Some are still pending, as listed above. I've received a lot of PMs so I'm trying to get to everyone. If I have not yet, bear with me Thanks!
Just received the trunk carpet. Looks great! Thanks! Bump for a nice member and GREAT service! + Feedback posted....
Thanks! Likewise
Originally posted by Racer_JT:
Aero nose/s? Skirts? Race seats? Status and can you ship?
ThomasJesse70@Gmail.com
I believe I have two aero noses. I have at least one. The other is a bit buried. I don't have any side skirts. I have the race seats mentioned above (3 different ones) The nose and race seats are not sold yet. They are very large items and it would take a lot to ship them. Not impossible, but it would take a bit to convince me to go through the effort
