  The Mall
  A little bit of everything for sale (Page 1)
A little bit of everything for sale by WickedFieroGTP
Started on: 06-14-2015 06:03 PM
Replies: 172 (7136 views)
Last post by: jasper on 09-30-2021 06:30 PM
WickedFieroGTP
Report this Post06-14-2015 06:03 PM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cleaning out my storage unit. I'll be adding more parts frequently, so please check back. Prices do not include shipping. I will take orders Monday thru Friday and ship on Saturdays. Thanks for looking.
Need to make room!!! Prices are negotiable!
Quarter Panels $25.00 each Sold Out
Drivers and passenger fenders $45.00 each Only a few left
Driver and passenger door glass (may have slight scratches in glass, nothing extreme) $55.00 each
Rear window glass $50.00 each with defrost. $40.00 each without defrost.
Sunroofs $40.00
Headlight assemblies $30.00 each (no motors)
Firewall covers $30.00 each Sold Out
Driver and passenger door panels $35.00 each Sold Out
A pillars $25.00 each Only a few left
B pillars $25.00 each Only a few left
Interior door trim $20.00 each Only a few left
Console surround $35.00 each
Center arm rest $45.00 each TAN ARM REST NOT AVAILABLE
Gauge cluster upper panel $30.00 each
Guage cluster lower panel $15.00 each
Wiper fluid bottles (good mounting tabs) $20.00 each
4 cylinder distributors $25.00 each
6 cylinder distributors $25.00 each
4 cylinder intakes $40.00 each
Exhaust tips $25.00 each
Seat belts $50.00 a set
front hood supports $15.00 each
4 cylinder exhaust manifolds $40.00 each
Spare tire trays $25.00 each
Heater controls $25.00 each Black button controls are sold out
Map lights (may or may not have bulb covers) $25.00 each
Arm rests $15.00 each
Front turn signals $15.00 a set
6 cylinder alternator brackets $50.00 each
Head light controls $30.00 each
Rear view mirrors $20.00 each
Hood release lever $10.00 each
Lighter face plate (solid mounting holes) $10.00 each
Dashboard trim caps $15.00 a set
4 cylinder and 6 cylinder dog bones $15.00 each
Drivers and passenger door hinges $25.00 per side
Door handles $5.00 each
4 cylinder air filter canisters $25.00 each
Notch Back tail lights $100.00 a set Only a few left
88 front sway bar 75.00
GT engine vents $50.00 a set
Fuel door package (Latch, cable and door assembly) $25.00 a set
Upper radiator support $25.00 each Only a few left
Lower radiator support $25.00 each Only a few left
Rear fascia (round molding/local pick up) $75.00 each
V6 intakes- Engraved $50.00 each, Non engraved $40.00 each (intakes only)
Valve covers $45.00 a set (I'll clean them up before shipping)
Lower intakes $25.00 each
Front compartment trim $25.00 each
Quarter panel vents $10.00 each
Dash vents $20.00 a set
Misc vents $5.00 each
Seat belt receptacles $20.00 a set
Gauge cluster bezels $20.00 each
Clutch master and slave cylinders $20.00 each
Gauge clusters 80 and 85 mph (sold out of 120) $55.00 and $65.00 respectively
Mirrors (manual) $25.00 each, (power) $40.00 each Only a few left
Pre 1988 crossover pipes $45.00 each (heat shield, o2 and egr not included)
Fuel filler neck $55.00
Air dams (nice condition) $50.00 Sold Out
Brake booster and Master cylinder $35.00
Battery cables $15.00 a set
Bezel $25.00
Battery trays (surface rust, still solid) $25.00 each
Sold Out
Rear deck lid springs $25.00
Rear ribbed molding $10.00 each
Ribbed marker lights $15.00 each
Rear round molding $10.00 each
Rear marker lights $15.00 each Sold Out
Rocker panel rivet covers $27.00 a set, shipped.
Right side seat rail $25.00 a set
Speaker covers $20.00 a set
Notch back filler panels $20.00 a set
Notch back engine vent mounts $15.00 a set
Misc ac line $10.00
87 GT rack (no play) $150.00
2.8 Exhaust manifold (cracked, NTB welded, see pic, will not separate) $40.00 for the set
Door lock actuators(tested good, rubber boots are rough) $10.00 each
4 speed shift bezels $30.00 each
Power window plates; blank $10.00SOLD, w/switches $20.00
Door handle cover w/power locks $35.00 set
Door handle cover w/o power locks $25.00 set
88 Front cross-member (slight surface rust) $125.00 (local pickup)
88 Cradle (slight surface rust) $250.00 (local pickup) Sold Out
Automatic shifters $25.00 each
Shift levers $15.00 each
Center caps $10.00 each
Jack and lug wrench $25.00 set
Injector harness $10.00 each
Solid engine vent covers $40.00 a set
A/C compressors $10.00 each
87 GT front springs $75.00 set
87 GT front and rear springs $125.00 set Sold Out
86 GT interior harness uncut w/ pwr windows, door locks and mirrors $100.00
85 GT 4 speed engine harness, uncut $50.00
Clean fuel tank (does not include fuel sender) $125.00 (local pickup)
86 GT throttle cable $25.00
86 GT auto shift cable $75.00
4 speed pulled form an 85 GT, 47,000 miles $225.00 (local pick up)
clutch and flywheel pulled form an 85 GT, 47,000 miles $50.00
Exhaust with cat $75.00 (local pick up)
Complete front suspension pulled form an 87 GT, 51,000 miles (super clean) $350.00 (local pick up)
Radiator pulled form an 87 GT, 51,000 miles $50.00
Cooling fans $35.00
Various steering columns w/ keys, no slop $75.00 (does not include wheel)
Cruise control Servos $50.00
Cruise control Vacuum tanks $10.00
Trunk blower motors $35.00
Trunk blower tubing $25.00 a set
Front Mount Battery Cables $65.00 a setSold Out
Stay Tuned More To Come!!!!
[This message has been edited by WickedFieroGTP (edited 09-04-2017).]
lorennerol
Report this Post06-14-2015 08:25 PM Click Here to See the Profile for lorennerolSend a Private Message to lorennerolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm interested in a medium-gray armrest/waterfall/glove compartment section if you have one in excellent shape (minimal swelling, no broken tabs). Also hunting for an excellent condition automatic shifter surround.
QCMANAGER
Report this Post06-14-2015 09:08 PM Click Here to See the Profile for QCMANAGERSend a Private Message to QCMANAGEREdit/Delete MessageReply w/QuoteDirect Link to This Post
I am interested in a rear view mirror for an 85 GT. If you could email me a photo of the nicest one
you have I would like to see it. If it is nice, I will request your paypal account name so that I can
send you the money. The shipping will be to 07631 so please let me know the total amount with
shipping. My email address is gsmcoins@yahoo.com.
Thanks
[This message has been edited by QCMANAGER (edited 06-14-2015).]
Robertzep2
Report this Post06-14-2015 09:27 PM Click Here to See the Profile for Robertzep2Send a Private Message to Robertzep2Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am interested in a pair of dark grey A Pillars. Do you have a dark grey set will the plastic tabs and metal clip holders intact?
I would like a set of Interior door trim panels, I couldn't tell from picture... but the darkest grey you have.
I would like one of your black knob and buttons heater control panels.
I would like one of your Light Switch and Dimmer panels ( with the black dimmer wheel)
Do you take PayPal? If so, quote me total with shipping to Akron, Ohio 44314
Thanks,
-Robert
WickedFieroGTP
Report this Post06-14-2015 09:41 PM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Will work on the above request and get back to everyone via pm within 24 hours.
Larryinkc
Report this Post06-14-2015 09:57 PM Click Here to See the Profile for LarryinkcSend a Private Message to LarryinkcEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
h.d.fire
Report this Post06-14-2015 10:19 PM Click Here to See the Profile for h.d.fireSend a Private Message to h.d.fireEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
WickedFieroGTP
Report this Post06-14-2015 10:33 PM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Above pm's replied to.
canfirst
Report this Post06-15-2015 12:05 AM Click Here to See the Profile for canfirstSend a Private Message to canfirstEdit/Delete MessageReply w/QuoteDirect Link to This Post
Would you have a drivers side wing stand and gasket for an 88 GT?
DKcustoms
Report this Post06-15-2015 12:27 AM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well I wanted the 88 control arms.
And then I saw the price.
FieroCat
Report this Post06-15-2015 12:17 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice collection! I noticed some of the dome lights have a button in the center, but not the performance sound switch... does that control the courtesy lights? Haven't seen it before.
My Fiero: 1986 Pontiac Fiero GT, V6, 4-speed manual
WickedFieroGTP
Report this Post06-15-2015 09:31 PM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
I do but it may be a while before they get dug out. I'll Pm you if I come across them anytime soon.
Sorry they are out of your price range. Shoot me a Pm, maybe we can work something out.
Thanks for the compliment. There are many more parts to come. The storage unit I have is becoming expensive. Seems every other month the price goes up. As to your question about the light. I do believe the third button is for the courtesy light, but I am not 100% positive. It may only illuminate the two center lights when pushed. Maybe someone else can chime in on the matter.
mr_corean
Report this Post06-16-2015 12:25 AM Click Here to See the Profile for mr_coreanSend a Private Message to mr_coreanEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent.
2002z28ssconv
Total ratings: 51
Report this Post06-16-2015 05:44 AM Click Here to See the Profile for 2002z28ssconvClick Here to visit 2002z28ssconv's HomePageSend a Private Message to 2002z28ssconvEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have any AC hoses?
KMFDMFAN
Report this Post06-16-2015 10:26 AM Click Here to See the Profile for KMFDMFANSend a Private Message to KMFDMFANEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent for Radiator support pieces
WickedFieroGTP
Report this Post06-16-2015 08:13 PM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by mr_corean:
PM sent.
PM returned
I think I have two sets up here. I'll set them aside for when you come up to pick up that cross member.
PM returned
2002z28ssconv
Total ratings: 51
Report this Post06-16-2015 09:32 PM Click Here to See the Profile for 2002z28ssconvClick Here to visit 2002z28ssconv's HomePageSend a Private Message to 2002z28ssconvEdit/Delete MessageReply w/QuoteDirect Link to This Post
Could you send them ASAP?
I have a couple guys that need them badly.
[This message has been edited by 2002z28ssconv (edited 06-16-2015).]
PacNWFiero
Report this Post06-16-2015 11:56 PM Click Here to See the Profile for PacNWFieroSend a Private Message to PacNWFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
WickedFieroGTP
Report this Post06-17-2015 09:14 PM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Contact made
Originally posted by PacNWFiero:
PM sent
PM returned
raptor_vrscx
Report this Post06-18-2015 08:21 AM Click Here to See the Profile for raptor_vrscxSend a Private Message to raptor_vrscxEdit/Delete MessageReply w/QuoteDirect Link to This Post
pm answered on lower rad support I will take one please hold one for me, as I added to the list of items I am in need of. would like to ship together.
[This message has been edited by raptor_vrscx (edited 06-18-2015).]
WickedFieroGTP
Report this Post06-18-2015 08:12 PM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Reply sent
KMFDMFAN
Report this Post06-19-2015 09:57 AM Click Here to See the Profile for KMFDMFANSend a Private Message to KMFDMFANEdit/Delete MessageReply w/QuoteDirect Link to This Post
Payment Sent.
I am also interested in the 88 front springs. Do you know what they came off of? GT, Formula or coupe? Also what does the tag say?
Thanks again.
:-D
fierogt28
Report this Post06-19-2015 05:37 PM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well, this garage sale of fiero parts is nice to see. Everything is all nicely neat and all parts together.
I've been to a few fiero garages and I all the parts are everywhere. Absolutely no order or class.
Can't find anything. Very discouraging. I don't know how people can live like that.
For starters, what the RPO code on the front 88 springs?? Interested, need the 3 letter code.
Thanks,
[This message has been edited by fierogt28 (edited 06-19-2015).]
WickedFieroGTP
Report this Post06-19-2015 11:03 PM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks,
Springs are currently spoken for. If that changes your first in line.
Darth Z
Report this Post06-20-2015 02:44 AM Click Here to See the Profile for Darth ZSend a Private Message to Darth ZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks like you have a few parts that I will need once I take delivery of my 87. Subscribing.
WickedFieroGTP
Report this Post06-20-2015 06:31 AM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll be here and congratz on the new addition.
whitesmoke
Report this Post06-20-2015 07:31 PM Click Here to See the Profile for whitesmokeSend a Private Message to whitesmokeEdit/Delete MessageReply w/QuoteDirect Link to This Post
pm sent
WickedFieroGTP
Report this Post06-21-2015 02:51 PM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by whitesmoke:
pm sent
Pm returned
KMFDMFAN
Report this Post06-22-2015 08:52 AM Click Here to See the Profile for KMFDMFANSend a Private Message to KMFDMFANEdit/Delete MessageReply w/QuoteDirect Link to This Post
Payment sent for front springs
WickedFieroGTP
Report this Post06-22-2015 10:00 PM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Payment received and parts shipped. Thank you.
GTMN
Report this Post06-23-2015 04:20 PM Click Here to See the Profile for GTMNSend a Private Message to GTMNEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interested in the gold fuel door assy. What is the paint condition on the fuel door? Is it factory paint or a respray? Thanks.
Mark
revin
Total ratings: 234
Report this Post06-24-2015 02:38 PM Click Here to See the Profile for revinSend a Private Message to revinEdit/Delete MessageReply w/QuoteDirect Link to This Post
WickedFieroGTP
Report this Post06-24-2015 07:38 PM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mark
Pm sent
PhxFiero
Report this Post06-25-2015 02:21 PM Click Here to See the Profile for PhxFieroSend a Private Message to PhxFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am looking for the catalytic converter heat shield for an 1988 V6 5-spd...the one that goes between the cat and the body. Please let me know if you have this. Thx!
WickedFieroGTP
Report this Post06-26-2015 07:00 PM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pm sent
KMFDMFAN
Report this Post06-27-2015 10:23 AM Click Here to See the Profile for KMFDMFANSend a Private Message to KMFDMFANEdit/Delete MessageReply w/QuoteDirect Link to This Post
Springs and shroud pieces received in excellent condition!
Thanks again.
WickedFieroGTP
Report this Post06-28-2015 12:13 AM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks again.
Glad you are happy with everything. Feedback left.
KMFDMFAN
Report this Post06-28-2015 10:14 AM Click Here to See the Profile for KMFDMFANSend a Private Message to KMFDMFANEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm still too much a a newb to leave feed back for people...
What about Bob
Report this Post06-28-2015 10:43 AM Click Here to See the Profile for What about BobSend a Private Message to What about BobEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 3 button dome lights were in 84s and some 85s. The center button lights the center two lamps. These dome lights also had the silver or bronze finish that the rest of the dash panels had. 86-88 dome lights were the 2 button (and Performance Sound slider) and were solid color.
WickedFieroGTP
Report this Post06-28-2015 09:28 PM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Awesome info Bob. Thank you.
