  The Mall
  12" corvette brake upgrade for your 84-87 fiero (Page 1)
12" corvette brake upgrade for your 84-87 fiero by sluppy123
Started on: 10-11-2015 04:44 PM
Replies: 41 (5854 views)
Last post by: pcar on 03-14-2023 05:09 AM
sluppy123
Report this Post10-11-2015 04:44 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
These brackets allow the use of 88-95 C4 12" rotors and 88 Fiero calipers on your 84-87 fiero. You will need 16" wheels at the min but I have heard of people getting the stock 15" wheel over them on 88's. People have been doing this swap on 88's for years, it is very well balanced, lightweight and affordable. Using the 88 Fiero caliper allows you to have an e-brake, nothing needs to be done to the cables or the calipers. The fronts are a bolt on and will require a hub made to install the new rotor onto. I have these available here-https://www.fiero.nl/forum/Forum4/HTML/071647.html When you install the rear calipers you will need to swap sides, Driverside on the pass side and pass side on the driverside. This will put the bleeder facing down requiring you to bleed the calipers off the car, I have done it several times and it isn't hard to do. Also the Threaded holes that hold the bracket to the knuckle will need to be drilled out and tapped with a M12x1.75 tap, I will include the required drill bit and Tap with each set of brackets.
All parts are available from Rockauto-
Front parts-
Power Stop drilled and slotted rotors, AR8240XPR $44.79ea
ACDelco 1988 Fiero left front caliper, 18FR722 $39.79 ea. That includes the $8.00 core
ACDelco 1988 Fiero Right front caliper, 18FR721 $39.79 ea. That includes the $8.00 core
REAR parts-
Power Stop Drilled and slotted rotors, AR8241XPR $41.79 ea
Centric1988 Fiero Left Rear caliper, w/ all brackets and hardware- 14162533 $126.79ea That includes the $70 core
Centric1988 Fiero Right Rear caliper, w/ all brackets and hardware- 14162534 $126.79ea That includes the $70 core
Front brackets-
$95 Shipped will get you 2 front brackets, milled from 7075 Aluminum and powder coated black, 2-6061 Aluminum rotor centering rings and the required bolts to mount the brackets to the knuckle.
Rear brackets-
$140 shipped will get you 2 rear brackets, milled from 7075 Aluminum and powder coated black, 2-6061 aluminum rotor centering rings, the required M12x1.75 mounting bolts and the Drill and M12x1.75mm tap. You can knock $10 off that price if you don't need the drill and tap.
$210shipped if you buy both a front and rear set together.
topcat
Total ratings: 148
Report this Post10-11-2015 08:48 PM Click Here to See the Profile for topcatSend a Private Message to topcatEdit/Delete MessageReply w/QuoteDirect Link to This Post
PayPal for a set of rear? No tap or drill needed
sluppy123
Report this Post10-11-2015 09:53 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent with paypal info
topcat
Total ratings: 148
Report this Post10-12-2015 02:34 PM Click Here to See the Profile for topcatSend a Private Message to topcatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Paypal sent.
Thanks
fierogt455
Report this Post10-14-2015 11:16 PM Click Here to See the Profile for fierogt455Send a Private Message to fierogt455Edit/Delete MessageReply w/QuoteDirect Link to This Post
Paypal sent for a set of 2 rear brackets, 2-6061 aluminum rotor centering rings, the required M12x1.75 mounting bolts and the Drill and M12x1.75mm tap.
Regards,
Freeman
Australian
Report this Post10-15-2015 06:12 AM Click Here to See the Profile for AustralianClick Here to visit Australian's HomePageSend a Private Message to AustralianEdit/Delete MessageReply w/QuoteDirect Link to This Post
How much to ship the lot to me i'm in 2074 NSW Australia.
sluppy123
Report this Post10-15-2015 06:45 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I will get you a quote and PM you at total.
topcat
Total ratings: 148
Report this Post10-18-2015 05:47 PM Click Here to See the Profile for topcatSend a Private Message to topcatEdit/Delete MessageReply w/QuoteDirect Link to This Post
My brackets came in yesterday. They look great, and I am looking forward to the install. Next weekend is my weekend off, so I will work on them then.
Thanks again!
fierogt455
Report this Post10-19-2015 07:56 PM Click Here to See the Profile for fierogt455Send a Private Message to fierogt455Edit/Delete MessageReply w/QuoteDirect Link to This Post
I need a set of front, rear, and a set of hubs.
Regards,
Freeman
fierogt455
Report this Post10-20-2015 11:01 PM Click Here to See the Profile for fierogt455Send a Private Message to fierogt455Edit/Delete MessageReply w/QuoteDirect Link to This Post
Payment sent.
fierogt455
Report this Post10-25-2015 01:40 PM Click Here to See the Profile for fierogt455Send a Private Message to fierogt455Edit/Delete MessageReply w/QuoteDirect Link to This Post
Parts received, thanks!
87convert
Report this Post10-28-2015 04:59 PM Click Here to See the Profile for 87convertSend a Private Message to 87convertEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would like both fromt and rear plus a pair of hubs.
Rolland
sluppy123
Report this Post10-29-2015 01:56 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Rolland
I sent you a pm regarding this.
WickedFieroGTP
Report this Post10-29-2015 03:17 PM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Parts received. Feedback left.
87convert
Report this Post10-30-2015 01:28 PM Click Here to See the Profile for 87convertSend a Private Message to 87convertEdit/Delete MessageReply w/QuoteDirect Link to This Post
Paypal payment sent. Looking forward to these parts since the 88 parts you sent in June worked great.
Thanks;
Rolland
Luke
Report this Post11-24-2015 12:34 AM Click Here to See the Profile for LukeClick Here to visit Luke's HomePageSend a Private Message to LukeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pm sent re: cost to ship a front set north of the border.
lordbg0205
Report this Post12-12-2015 08:06 AM Click Here to See the Profile for lordbg0205Send a Private Message to lordbg0205Edit/Delete MessageReply w/QuoteDirect Link to This Post
Any redrilling of the rotor necessary to fit the lug pattern?
IwannaIRM
Total ratings: 58
Report this Post02-04-2016 02:14 PM Click Here to See the Profile for IwannaIRMSend a Private Message to IwannaIRMEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM Sent.
Luke
Report this Post02-15-2016 12:23 AM Click Here to See the Profile for LukeClick Here to visit Luke's HomePageSend a Private Message to LukeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lord. Yes you have to drill the fiero pattern into the rotors. A drill press, plus old rear hub with studs removed will do the job.
Internet-man
Report this Post05-31-2016 05:51 PM Click Here to See the Profile for Internet-manSend a Private Message to Internet-manEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mine just arrived. They look great! Thanks
90turbo1
Report this Post06-01-2016 01:03 PM Click Here to See the Profile for 90turbo1Send a Private Message to 90turbo1Edit/Delete MessageReply w/QuoteDirect Link to This Post
is this a better upgrade than the lebaron rotor, s10 truck caliper swap???
if so put me down for a front set will get rears when I do my swap.
gwg1995
Report this Post06-04-2016 07:44 PM Click Here to See the Profile for gwg1995Send a Private Message to gwg1995Edit/Delete MessageReply w/QuoteDirect Link to This Post
Pm'd
mugsman
Report this Post06-23-2016 10:10 PM Click Here to See the Profile for mugsmanSend a Private Message to mugsmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pm sent
90turbo1
Report this Post06-26-2016 08:56 PM Click Here to See the Profile for 90turbo1Send a Private Message to 90turbo1Edit/Delete MessageReply w/QuoteDirect Link to This Post
pm sent to you.....
sluppy123
Report this Post06-27-2016 09:00 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by 90turbo1:
pm sent to you.....
I replied to your PM.
ericjon262
Total ratings: 67
Report this Post07-10-2016 08:03 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
parts received! thanks!
sybersonix
Report this Post02-11-2017 11:13 PM Click Here to See the Profile for sybersonixClick Here to visit sybersonix's HomePageSend a Private Message to sybersonixEdit/Delete MessageReply w/QuoteDirect Link to This Post
i need a front and rear set with front rotor hubs. please contact. ty...
jbs2212
Report this Post02-12-2017 12:45 AM Click Here to See the Profile for jbs2212Send a Private Message to jbs2212Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent.
I FAR I
Report this Post02-18-2017 01:42 PM Click Here to See the Profile for I FAR ISend a Private Message to I FAR IEdit/Delete MessageReply w/QuoteDirect Link to This Post
Would this setup fit over Cheviot 15 inch dia wheels of 7 inch and 8 inch width?
Thanks
sybersonix
Report this Post03-09-2017 11:48 PM Click Here to See the Profile for sybersonixClick Here to visit sybersonix's HomePageSend a Private Message to sybersonixEdit/Delete MessageReply w/QuoteDirect Link to This Post
SLUPPY ROCKS, GREAT BRACKETS AND THE GUY REALLY HAS IT DOWN GOOD FOR A WONDERFUL BRAKE SYSTEM. THANK YOU SO MUCH. HE'S YOUR MAN FOR THE UPGRADE !!!!!!!
fatmerk
Report this Post03-10-2017 09:22 AM Click Here to See the Profile for fatmerkSend a Private Message to fatmerkEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM'd
IXSLR8
Report this Post11-27-2017 12:31 PM Click Here to See the Profile for IXSLR8Send a Private Message to IXSLR8Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM'd.
zi_gravedigger
Report this Post03-27-2018 12:02 PM Click Here to See the Profile for zi_gravediggerSend a Private Message to zi_gravediggerEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM'd
Cheeper2keeper
Report this Post03-28-2018 01:31 AM Click Here to See the Profile for Cheeper2keeperSend a Private Message to Cheeper2keeperEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you the same guy that was making the short hood struts that mount beside the headlights?
Blowerwhine
Report this Post02-22-2019 07:39 PM Click Here to See the Profile for BlowerwhineSend a Private Message to BlowerwhineEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM'd
86GT405
Report this Post05-28-2022 01:11 PM Click Here to See the Profile for 86GT405Send a Private Message to 86GT405Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is there any chance you are still selling these in 2022? I need some!
Shianne
Report this Post06-24-2022 03:03 PM Click Here to See the Profile for ShianneSend a Private Message to ShianneEdit/Delete MessageReply w/QuoteDirect Link to This Post
sluppy123
Report this Post07-02-2022 08:29 AM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
These are still available for purchase. I don't stock them but machine them as purchased.
kpazzh0ly
Report this Post07-04-2022 11:28 AM Click Here to See the Profile for kpazzh0lySend a Private Message to kpazzh0lyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would be interested in brackets and hubs. Sent you a PM.
Boogietime
Report this Post02-23-2023 11:46 AM Click Here to See the Profile for BoogietimeSend a Private Message to BoogietimeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are these still available, front and rear?
