2.8 and 2.5 parts for sale by Detainabull
Started on | : 10-11-2015 05:36 PM |
Replies | : 28 (782 views) |
Last post by | : Detainabull on 01-11-2016 08:33 PM |
Oct 11th, 2015
Detainabull Member Posts: 193 From: Durham, NC Registered: Jan 2015
Currently tearing down an 87 GT 5 speed and an 87 2.5 4 cylinder. List of parts I have as of now are: 2.5L Starter Cylinder head Intake manifold Exhaust manifold-SOLD Air intake Ignition coil pack-SOLD AC lines-SOLD 2.8L Holley throttle body-SOLD Rubber intake tube Engraved fiero intake-SOLD Intake manifold(middle) Evap canister(trunk side) Fuel rail with injectors(injectors may or may not work) Fuel injector wiring harness Throttle cable Cruise control cable-SOLD Throttle body cable bracket AC lines-SOLD Added** Fuel expansion tank-SOLD AC compressor bracket-SOLD Valve covers Coolant crossover pipe 87 GT front suspension parts Also have a set of decklid hinges and one torsion bar that bolts to the driver side of decklid. The GT car has grey interior and a sunroof package. I plan on using all of this interior and sunroof but will sell If the offers are worth it. Should have the cradle out and suspension available soon. Thanks guys      [This message has been edited by Detainabull (edited 01-11-2016).]
05:36 PM
Oct 16th, 2015
Bump
*Added Parts* 88 dot matrix cluster trim 2.5L. Belt tensioner assembly. Spring is still strong Driver side front fender marker light Passenger side rear quarter marker light
04:32 PM
Oct 24th, 2015
Bump*
Sold parts: 2.5 belt tensioner 2.8 intake tube *pending* Shift assembly Trans bracket *pending*
10:30 PM
Oct 25th, 2015
FieroTony Member Posts: 1175 From: Conowingo, MD Registered: Feb 2012
How much $$$ for the exhaust manifold (88 2.5)?
08:33 AM
Oct 28th, 2015
*Bump*
Sold parts Pending* Isuzu Transaxle brackets Isuzu shift bracket Isuzu slave cylinder 2.8 EGR tube
The GT car is a parts car so if you don't see what's on the list just ask. I should be removing the brakes and control arms on Friday pending the weather. Thanks
08:13 PM
Oct 31st, 2015
notwohorns Member Posts: 1175 From: greenville, il. usa Registered: Jul 2009
PM sent. Looking for a motor mount bracket
03:21 PM
Nov 2nd, 2015
FieroMontreal Member Posts: 3121 From: Registered: Jul 2001
Is your 87 coupe automatic or manual?
10:30 AM
Nov 3rd, 2015
[QUOTE]Originally posted by FieroMontreal:
Is your 87 coupe automatic or manual?[/QUOTE
Manual, 5speed
01:52 AM
flimbob Member Posts: 643 From: Plano, Texas, USA Registered: May 2008
pm sent
06:37 AM
I'm interested in the prom for the ECU. I'm tired of looking ofr the source of my code 42 so I might give this a try as it's pretty much the only thing I haven't changed. How much do you want for the prom or the whole ECU?
12:19 PM
Nov 9th, 2015
mrossum Member Posts: 804 From: lake havasu city, az Registered: Oct 2000
how much for 2.5L coil pack and thermostat housing shipped to 86406 ------------------ 87 coupe 4 cyl, 5 speed
09:59 AM
| quote | Originally posted by mrossum:
PM sent
10:42 AM
Nov 22nd, 2015
*Bump*
New parts available Rear brake calipers Rear strut/spring setup
10:38 PM
rkirkpatrick Member Posts: 136 From: Royalton, Ill, USA Registered: Jul 2015
Do you have a trunk release switch for an 86 ??
11:18 PM
Push rid guides for the 2.5?
I don't see them on the head?
11:19 PM
I should have the guides in a bucket with the rockers and pushrods. I'll double check tomorrow after work. No trunk release switch
11:49 PM
Nov 23rd, 2015
thanks...I am sending a PM with my phone number...Please send picts of the guide..
01:52 PM
Nov 25th, 2015
Parts added* Dust shields  Rear control arms  Rear calipers(probably need rebuild)  Rear strut and spring  GT exhaust cut before the cat converter  Tie rods(ends will need replacing)
05:04 PM
Nov 29th, 2015
Cavvy09 Member Posts: 113 From: Williamstown, w.v. united states Registered: Jun 2015
was looking for v6 thermostat housing. If you have one what would you want for it shipped to Williamstown wv? Also you mentioned above about possibly selling gray interior. If available I am looking for whole center section pod bezel back to glove box and how much?
09:20 PM
Dec 7th, 2015
anthonyelectric Member Posts: 285 From: Rotterdam, NY, USA Registered: Mar 2015
I was able to purchase the correct rear transmission mount from this forum member. Detainabull was very easy to work with, amazingly fair on price, and the part was in my hands within days.
Thank you,
Anthony
06:03 AM
Anthonyelectric was a great buyer. I would highly recommend him to anyone involved in a sale. Clearly communicated through the forum and through texting. Made immediate payment upon price agreement. A Very smooth transaction. Thanks again!
03:47 PM
Dec 9th, 2015
i could use the 4cyl thermostat housing. how much shipped to 86406? ------------------ 87 coupe 4 cyl, 5 speed
12:06 PM
Sry mrossum. That has been sold already. I'll update the list
06:49 PM
Update
Sold: Right rear control arm Both rear dust shields GT shift knob 120mph speedo and gauge cluster Trunk/defrost switch
07:46 PM
Dec 13th, 2015
Bump* parts added 87 GT front springs Front spindles Front dust shields Front brake calipers Front upper and lower control arms
11:10 AM
Dec 28th, 2015
Sold Wiper motor Fastback trunk seal GT steering wheel
**bump**
04:32 PM
Jan 1st, 2016
355Fiero Member Posts: 548 From: Victoria, BC Canada Registered: Dec 2004
Interested in the 4 cyl A/C lines. How much shipped to V9C 4M9 (Victoria, BC Canada) Ship USPS please so I don't get hit with UPS brokerage fees.
You can pm me here or email me directly at don_ostergard at shaw dot ca.
Thanks Don
02:47 PM
PM sent
04:12 PM
Jan 11th, 2016
Bump Sold parts* Headlight dimmer switch Rubber intake hose Steering column
Lots of stuff still available. Make offers!
08:33 PM
