Hello, up for grabs is a full set of four 16" three pc performance wheels with tires. They are the compomotive ts series wheels that are identical to the ferrari 5 point star wheels but have the 5x100 bolt pattern of the fiero. (so no wheel adapters needed). they will bolt right up to any fieros factory hub. they are perfect for any ferrari replica to give it that authentic look and feel, not to mention also to boost the value of the car as-well. the tire sizes for the 2 front wheels are 225-50r16. the sizes for the 2 rear wheels are 255-50r16. i rinsed off the wheels so you can get a better view. but they both can use a good polishing. the wheels themselves are chrome, the center star is a pearl silver, and the studs that go all the way around the wheel (which holds all 3 pieces together) are the factory steel bolts. i was going to replace them with a chrome or gold chrome studs that i saw on ebay for a great price. they are always on ebay which make real easy and cheap to get. i took the rear wheel off so you can see the wheel tread. as you ca see the lug nuts that hold the wheels to the car are hidden behind a center plate. you will see that plate on the ground next to the rear wheel. and in place on the front wheel thats on the car. you can also use these wheel with smaller or wider tires to fit what ever application you want. these wheels are perfect for any wide body kit as-well. Wow only 950.00 with free shipping in the usa!!
[This message has been edited by xeforce (edited 10-17-2015).]
