  The Mall
  Fiero & 3800 Parts (Page 1)
Fiero & 3800 Parts by Jfrost
Started on: 11-09-2015 10:55 PM
Replies: 73 (3382 views)
Last post by: Jfrost on 04-02-2017 11:05 PM
Jfrost
Report this Post11-09-2015 10:55 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
New items added:
Manual steering column with key: $60
GT Steering wheel with scrapes/knicks on top leather portion, great candidate for recovering: $45
Power mirrors with all wiring and control switch, passenger side glass has crack: $80
Auto dimming mirror purchased from mmeyers on PFF but never used: $40
Aux cover plate with pattern cover: $10
Harbor Freight multifunction tool, used once or twice: $10
GT trunk carpet in good condition, needs cleaning: $25
Rear bulkhead covers, lower one has some stains and both could use cleaning. Local pickup preferred: $20 ea
Front lower control arms from 86 GT. Ball joints worn and need replacement: $30ea
L67 sc lower intake: $30
Seat belt assemblies from 86 GT: $25ea
86 GT steering rack with approx. 69k miles. Tie rods need replacement, when last driven steering felt normal: $70
Fuel filler neck from 86 GT. No leaks, cap included: $50
Sunroof glass in good shape, local pickup: $45
Other items for sale but not pictured:
2 sets of 86 GT rear springs with 69K and 170k miles: $40 ea set
Front and rear wheel well liners from 86 GT: $25 per liner, local pickup prefered
Assortment of Fiero and 3800 parts up for sale. Prices exclude shipping unless otherwise noted.
Upper & lower IP cluster trim: $5 ea
IP cluster frame: $10
Cruise control module and wiring harness: $25
Rear tailight assembly and cover (small crack on light assembly): $10
Tan performance sound overhead console. The gray “performance badge” is loose: $20
Left & right inner carpet console trim: $10 ea
(1) HVAC control head: $20 ea
4 speed shifter trim (no ash tray doors, minor scuffs): $10
IP trim cover (minor scuffs): $5
IP housing and cover plate: $5
(1) Trunk switches: $7 ea
Dash light and Headlight switch: $10
Speaker cover (no fabric): $10
Speaker covers w/fabric: $15
(2) PCM trays: $5 ea
85 GT gas/temp gauge: $10
Shifter boot: $5
3rd Brake lamp assembly and harness: $15
Door handle trim: $5
Left & right lower seat belt receptacles: $10 ea
Front quarter window trim (by sideview mirror): $5
Sunvisors in good used condition: $40
Gen 1 headlight motors and buckets (will need rebuild): $40
(3) Plastic intake air box: $10 ea
(3) Engine bay cooing tubes: $10 ea set
Intake air canister and fiter: $10
Washer fluid bottle and pump: $15 ea
Fuel lines (metal and rubber/metal set): $15 ea
84 Spare tire jack and bracket: $35
Fuel injector harness: $5
Ignition coil: $5
Cold start injector/line: $10
Cruise contro module: $15
Rear decklid hinges: $20
EGR vacuum solenoid: $10
Rear deacklid torsion springs: $45
Middle intake manifold: $10
(2) Spare tire hold down bracket: $10 ea
Battery tray: $15
Positive battery cable: $5
Cruise control canister (held vacuum when removed): $8
Rear fan motor: $10
Wiper blade arms: $20
Tire iron: $5
Rear trunk latch bracket: $5
Fuel tank straps (surface rust but usable): $10
Engine dog bone: $5
(2) Exhaust crossover heat shield: $5 ea
GT spoiler. Paint is 7/10 with some spider cracks as pictured: $125 $100
Update: Spoiler recently slipped off a box and chipped on the drivers side rear edge on the end. I've reduced the price to reflect the new damage.
One 86 GT 4 spd PCM's and one 87 5 spd PCM: $25
Master cylinder and proportioning valve from 69k mile Fiero: $25
(1) Left engine vent: $20 ea
(1) "D" plate set (one has small crack in front corner): $15 ea set
GT vent hold down bracket: $10
Fast back bracket: $5
Front trunk gasket from 69k mile Fiero: $20
86 GT Front Bumper: paint is faded and there are scrapes/hole on the bottom section, see pic $100 pick up only
(2) Northstar throttle body: $45 ea
3800 NA valve covers (gasket maker used by prior owner, will need removing: $25
3800 PCM tray: $15
ICM Harness (slight heat damage but usable): $10
3800 tensioner bracket from H-body: $15
3.8 s/c press on pulley: $10
Front mount battery cables (pulled from late model GM vehicle): $75 shipped for the pair
Random parts, $5 ea
Project L67 Fiero
[This message has been edited by Jfrost (edited 04-02-2017).]
Spoon
Total ratings: 61
Report this Post11-10-2015 11:56 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
you have a pm.
Spoon
Jfrost
Report this Post11-11-2015 04:05 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM replied to.
Jfrost
Report this Post11-12-2015 10:31 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Front mount battery cables and lower IP cluster trim sold.
fierogt455
Report this Post11-13-2015 10:04 PM Click Here to See the Profile for fierogt455Send a Private Message to fierogt455Edit/Delete MessageReply w/QuoteDirect Link to This Post
You have a pm.
Jfrost
Report this Post11-14-2015 06:19 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM replied to.
fierogt455
Report this Post11-14-2015 07:34 PM Click Here to See the Profile for fierogt455Send a Private Message to fierogt455Edit/Delete MessageReply w/QuoteDirect Link to This Post
Payment sent.
Jfrost
Report this Post11-14-2015 08:18 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM replied to.
Jfrost
Report this Post11-16-2015 10:51 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Intake housing and filter sold.
fierogt455
Report this Post11-18-2015 02:18 PM Click Here to See the Profile for fierogt455Send a Private Message to fierogt455Edit/Delete MessageReply w/QuoteDirect Link to This Post
Parts received; positive feedback left.
Spoon
Total ratings: 61
Report this Post11-18-2015 11:54 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Received my battery cables super fast.
Thanks, left good feedback.
Spoon
FIEROPHREK
Total ratings: 137
Report this Post11-19-2015 09:11 AM Click Here to See the Profile for FIEROPHREKSend a Private Message to FIEROPHREKEdit/Delete MessageReply w/QuoteDirect Link to This Post
You have a P.M.
12.3 is faster than a 13.2
rkirkpatrick
Report this Post11-21-2015 08:05 PM Click Here to See the Profile for rkirkpatrickSend a Private Message to rkirkpatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is trunk switch from '84??
Need one for an '86
Jfrost
Report this Post11-21-2015 08:19 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Need one for an '86
They are all from an 86
Jfrost
Report this Post11-27-2015 03:45 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Found another pair of front mount battery cables. Exhaust and a few other items sold and list updated.
Jfrost
Report this Post12-01-2015 10:11 AM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Parts list updated, bump.
NightMare Cruiser
Report this Post12-01-2015 10:56 AM Click Here to See the Profile for NightMare CruiserSend a Private Message to NightMare CruiserEdit/Delete MessageReply w/QuoteDirect Link to This Post
How much do you think to ship rear spoiler?
Jfrost
Report this Post12-01-2015 11:28 AM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent.
Jfrost
Report this Post12-04-2015 11:32 AM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump.
Jfrost
Report this Post12-04-2015 11:33 AM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Jfrost
Member since Jul 2009
Bump.
Jfrost
Report this Post12-11-2015 08:32 AM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Jfrost
Report this Post12-14-2015 05:39 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Bjornen
Report this Post12-17-2015 02:05 AM Click Here to See the Profile for BjornenSend a Private Message to BjornenEdit/Delete MessageReply w/QuoteDirect Link to This Post
You have a PM
Jfrost
Report this Post12-21-2015 09:45 AM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM replied to, bump.
Jfrost
Report this Post12-21-2015 09:21 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Jfrost
GT vent brackets and one set of "D" plates sold.
oldschoolbilly
Report this Post12-22-2015 11:46 AM Click Here to See the Profile for oldschoolbillySend a Private Message to oldschoolbillyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pm sent on sunvisors
oldschoolbilly
Report this Post12-22-2015 01:32 PM Click Here to See the Profile for oldschoolbillySend a Private Message to oldschoolbillyEdit/Delete MessageReply w/QuoteDirect Link to This Post
oldschoolbilly
Member since Oct 2013
paypal sent for visors
Jfrost
Report this Post12-28-2015 12:44 AM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Jfrost
Report this Post01-02-2016 04:02 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
New Year bump
Spoon
Total ratings: 61
Report this Post01-04-2016 11:48 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
You have a pm.
Spoon
Jfrost
Report this Post01-14-2016 11:01 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Jfrost
Report this Post01-19-2016 08:59 AM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Jfrost
Report this Post01-19-2016 09:02 AM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Jfrost
Bump
Jfrost
Report this Post02-09-2016 09:25 AM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Found out I'll need to move by June so I want these parts sold to a new home.
Project L67 Fiero
FieroCat
Report this Post02-09-2016 01:56 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would like one of the ECM's. Are they tested and known to be good?
My Fiero: 1986 Pontiac Fiero GT, V6, 4-speed manual
Jfrost
Report this Post02-09-2016 02:00 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, pulled from working/running vehicles. PM sent.
anthony_86gt
Report this Post02-09-2016 02:29 PM Click Here to See the Profile for anthony_86gtSend a Private Message to anthony_86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent.
Jfrost
Report this Post02-12-2016 03:35 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Trunk switch and bezel sold, PM's replied to.
Jfrost
Report this Post03-02-2016 08:44 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Jfrost
Report this Post03-10-2016 02:00 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have to move in the next few months and I want as much of this gone as possible.
