New items added:
Manual steering column with key: $60
GT Steering wheel with scrapes/knicks on top leather portion, great candidate for recovering: $45
Power mirrors with all wiring and control switch, passenger side glass has crack: $80
Auto dimming mirror purchased from mmeyers on PFF but never used: $40
Aux cover plate with pattern cover: $10
Harbor Freight multifunction tool, used once or twice: $10
GT trunk carpet in good condition, needs cleaning: $25
Rear bulkhead covers, lower one has some stains and both could use cleaning. Local pickup preferred: $20 ea
Front lower control arms from 86 GT. Ball joints worn and need replacement: $30ea
L67 sc lower intake: $30
Seat belt assemblies from 86 GT: $25ea
86 GT steering rack with approx. 69k miles. Tie rods need replacement, when last driven steering felt normal: $70
Fuel filler neck from 86 GT. No leaks, cap included: $50
Sunroof glass in good shape, local pickup: $45
Other items for sale but not pictured:
2 sets of 86 GT rear springs with 69K and 170k miles: $40 ea set
Front and rear wheel well liners from 86 GT: $25 per liner, local pickup prefered
Assortment of Fiero and 3800 parts up for sale. Prices exclude shipping unless otherwise noted.
Upper & lower IP cluster trim: $5 eaIP cluster frame: $10Cruise control module and wiring harness: $25
Rear tailight assembly and cover (small crack on light assembly): $10
Tan performance sound overhead console. The gray “performance badge” is loose: $20Left & right inner carpet console trim: $10 ea
(1) HVAC control head: $20 ea
4 speed shifter trim (no ash tray doors, minor scuffs): $10
IP trim cover (minor scuffs): $5
IP housing and cover plate: $5(1) Trunk switches: $7 ea
Dash light and Headlight switch: $10
Speaker cover (no fabric): $10
Speaker covers w/fabric: $15
(2) PCM trays: $5 ea
85 GT gas/temp gauge: $10
Shifter boot: $5
3rd Brake lamp assembly and harness: $15
Door handle trim: $5
Left & right lower seat belt receptacles: $10 ea
Front quarter window trim (by sideview mirror): $5
Sunvisors in good used condition: $40Gen 1 headlight motors and buckets (will need rebuild): $40
(3) Plastic intake air box: $10 ea
(3) Engine bay cooing tubes: $10 ea set
Intake air canister and fiter: $10Washer fluid bottle and pump: $15 ea
Fuel lines (metal and rubber/metal set): $15 ea
84 Spare tire jack and bracket: $35
Fuel injector harness: $5
Ignition coil: $5
Cold start injector/line: $10
Cruise contro module: $15
Rear decklid hinges: $20
EGR vacuum solenoid: $10
Rear deacklid torsion springs: $45
Middle intake manifold: $10
(2) Spare tire hold down bracket: $10 ea
Battery tray: $15
Positive battery cable: $5
Cruise control canister (held vacuum when removed): $8
Rear fan motor: $10Wiper blade arms: $20
Tire iron: $5
Rear trunk latch bracket: $5
Fuel tank straps (surface rust but usable): $10
Engine dog bone: $5(2) Exhaust crossover heat shield: $5 ea
GT spoiler. Paint is 7/10 with some spider cracks as pictured:
$125 $100
Update: Spoiler recently slipped off a box and chipped on the drivers side rear edge on the end. I've reduced the price to reflect the new damage.
One 86 GT 4 spd PCM's
and one 87 5 spd PCM: $25
Master cylinder and proportioning valve from 69k mile Fiero: $25
(1) Left engine vent: $20 ea
(1) "D" plate set (one has small crack in front corner): $15 ea set
GT vent hold down bracket: $10Fast back bracket: $5
Front trunk gasket from 69k mile Fiero: $20
86 GT Front Bumper: paint is faded and there are scrapes/hole on the bottom section, see pic $100 pick up only
(2) Northstar throttle body: $45 ea
3800 NA valve covers (gasket maker used by prior owner, will need removing: $253800 PCM tray: $15
ICM Harness (slight heat damage but usable): $10
3800 tensioner bracket from H-body: $15
3.8 s/c press on pulley: $10
Front mount battery cables (pulled from late model GM vehicle): $75 shipped for the pair
Random parts, $5 ea
Project L67 Fiero[This message has been edited by Jfrost (edited 04-02-2017).]
