Update System
  The Mall
  FS: Embrace Racing RACESPEC Hood Vent
by doublec4
Started on: 01-19-2016 10:03 PM
Replies: 8 (679 views)
Last post by: doublec4 on 01-27-2016 04:56 PM
doublec4
Total ratings: 150
Report this Post Click Here to See the Profile for doublec4Click Here to Email doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
There are quite a few hood vent options for the Fiero, however, most of them require a lot of body work and repaint etc. This can get pretty costly and time consuming so I came up with a solution with the following requirements:
- Can be installed in an afternoon (fairly easily)
- Entire installation and product cost less than $200
- Looks aggressive but appropriate for the Fiero
- Functional
- Spare tire compartment remains sealed and unmodified.
I ended up making these custom aluminum vents that flow with the lines of the hood, and fit nicely in the front section to relieve pressure build up at high speeds.
They are made entirely from aluminum and I stock them in black powdercoat.
You will need to simply cut two holes in your hood, drill the mounting holes, and rivet the vent into place. In this case I used normal aluminum rivets, but you can also find black rivets to make them blend in. The vents actually somewhat match the vents at the back of the car and really do a nice job of letting the pressure out at high speeds.
Price is as follows:
Black Powder Coat: $175
More details here:
http://www.embraceracing.com/racespecvent.php
Get them while you can! I only have a few left and I'm not sure I plan to make anymore after this batch.
Best bet is to email me on my website to get a hold of me the quickest.
Thanks!
Check out my build and my website!
https://www.fiero.nl/forum/Forum3/HTML/000100.html
Embrace Racing
Supracoupe
Report this Post Click Here to See the Profile for SupracoupeSend a Private Message to SupracoupeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interested. Email sent.
LFiero67
Report this Post Click Here to See the Profile for LFiero67Send a Private Message to LFiero67Edit/Delete MessageReply w/QuoteDirect Link to This Post
Headlights stay down at 137 mph....
10.007 @ 135.54MPH. <-- Video
Best 60' 1.42
Best mph 137.66
Billet 6262 Precision turbo, PT1001 intercooler, ST1 cam, 140lb springs, comp pushrods, HV3, stock L32 bottom end and heads.
Old M90 XP Cam time -
11.425 @115.60
1.543 60'
doublec4
Total ratings: 150
Thanks for the review and pictures!
rourke_87_T-Top
Report this Post Click Here to See the Profile for rourke_87_T-TopClick Here to Email rourke_87_T-TopSend a Private Message to rourke_87_T-TopEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just a question; could those be tweaked to shutter open with fan engaged ?
doublec4
Total ratings: 150
Anything is possible, but it would be very difficult. You would essentially have to mutilate the vent and come up with some sort of hinge system to remount all of the slats. Would be very cool though!
hetterbr
Report this Post Click Here to See the Profile for hetterbrClick Here to Email hetterbrSend a Private Message to hetterbrEdit/Delete MessageReply w/QuoteDirect Link to This Post
You have a P.M.
NEVERDONE
Report this Post Click Here to See the Profile for NEVERDONEClick Here to Email NEVERDONESend a Private Message to NEVERDONEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just an idea that I might try on my gt. Instead of mounting this on top of the hood, why not cut out a hole just for the vents to poke through. Mount it from the bottom maybe.
doublec4
Total ratings: 150
It's possible but it will require body work... unless you have a really steady hand and can make that cut look awesome! The idea of the top mount is obviously to hide the cut. If you'd like to try it out just shoot me an email and I have a few more vents.
Thanks!
