  The Mall
  parts horde look in here!!
parts horde look in here!! by hiwil88formula
Started on: 01-29-2016 04:49 PM
Replies: 39 (1758 views)
Last post by: RPYRAZOO on 08-14-2016 01:05 PM
hiwil88formula
Report this Post01-29-2016 04:49 PM Click Here to See the Profile for hiwil88formulaSend a Private Message to hiwil88formulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
*****new parts added 7 Feb 14*****
Recently bought out a guy that retired from fieros, I cherry picked the stuff I need here is the rest more to be added when I get time.
V6 power pulley $60
V6 timing chain $20
Ecm trays x6 $20
3.1 piston set h562cp .75 x2 $100 set
Front speaker grilles x2 $20
Nos gt sail panel, right side only, with correct tape x2 $$$make offer$$$
85-86 v6 oil pan x2 $50
87-88 v6 oil pan $40
Pioneer 4x6 good condition $25 pr
Pyramid sub x2 $15
V6 timing chain cover $50 ea
Gt steering wheel $100
2 tone Gt steering wheel $50
Gt gauge pods x3 $25
Gt gauge pod bad condition $15
Nos ac delco fuel pulsator $20
180 degree thermostat $10
Adjustable fuel pressure regulator $100
V6 fuel pump high pressure $80
V6 windage tray $50
88 lower ball joint $50 pr
84-87 inner tie rods $20 pc
RD 88 inner tie rods $20 pc
Black poly engine cradle mounts $40
Rubber control arm bushing set $20
Nossway bar link rubber $2.50 pc
Body emblems $make offer$
V6 kn air filter x2 $40 new one $20 used one
V6 egr tubes flexible x2 $40 pc
Polished coil coolant tubes set $25
Arp con rod bolts 133-6002 x4 $60pc
Th125 shift kit $40
Silv o lite piston set 1486 .75 3.1 $200
Dual gauge pod x1 $40
Silver dash trim pieces $25 a/c and oil pod piece
Comp cams lifter set 802-12 $80
V6 alt brackets x6 $25 pc
120 mph speedo$60
Ac delco HL 118 roller lifters set $180
Ac delco water pump v6 $50
88 carbomet brake pads x2 $40 pc
Rear sway bar bushings (red) $15 pc
Engraved v6 intake $40
Fiero radio mounts x3 $20
Cold start injector x5 $25
NOS EGR valve $30
GT decklid Vents $75 a set
V6 Exhaust manifolds $60 set
MSD Blaster Coil $30
NOS Coil $15
VDO gauges $25 a piece
V6 Rubber Dog Bone $20
Rubber Cradle mounts $25
[This message has been edited by hiwil88formula (edited 02-07-2016).]
mrfiero
Total ratings: 150
Report this Post01-29-2016 06:26 PM Click Here to See the Profile for mrfieroSend a Private Message to mrfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by hiwil88formula:
Nos gt sail panel right with correct tape x2 $$$make offer$$$
I'm interested in these items......would like to see what else you have though.
Phirewire
Report this Post01-29-2016 10:31 PM Click Here to See the Profile for PhirewireSend a Private Message to PhirewireEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interested In GT Gauge pod if it includes the gauges and the wiring.
NEVERDONE
Report this Post01-29-2016 11:12 PM Click Here to See the Profile for NEVERDONESend a Private Message to NEVERDONEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interested in sub, and the "gt" emblems.
robert1234
Report this Post01-30-2016 07:15 AM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
I want the quarter windows GT - You got PM
Yes both sets !!!!!!
[This message has been edited by robert1234 (edited 01-30-2016).]
MulletproofMonk
Total ratings: 78
Report this Post01-30-2016 09:24 AM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
joesfiero
Report this Post01-30-2016 09:31 AM Click Here to See the Profile for joesfieroSend a Private Message to joesfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll take both sets of speaker grilles and poly cradle mounts. Price shipped to 34291.
Thanks
-Joe
Tom Slick
Report this Post01-30-2016 12:01 PM Click Here to See the Profile for Tom SlickSend a Private Message to Tom SlickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm interested in the GT sail panels, if not already sold.
Also, the '88 ball joints and inner tie rods.
Are the rear swaybar bushings for an '88?
Thanks
[This message has been edited by Tom Slick (edited 01-30-2016).]
hiwil88formula
Report this Post01-30-2016 01:03 PM Click Here to See the Profile for hiwil88formulaSend a Private Message to hiwil88formulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tom pm sent. For everybody the sail panels are both the right side. It's not a pair. When I opened up the left side it was in about 20 pieces. So I got 2 rights
I FAR I
Report this Post01-30-2016 01:08 PM Click Here to See the Profile for I FAR ISend a Private Message to I FAR IEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
I'll take the second Pyramid subwoofer......Thanks.
hiwil88formula
Report this Post01-30-2016 02:03 PM Click Here to See the Profile for hiwil88formulaSend a Private Message to hiwil88formulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
All pm's replied to.
87GT2M6
Report this Post01-30-2016 07:04 PM Click Here to See the Profile for 87GT2M6Send a Private Message to 87GT2M6Edit/Delete MessageReply w/QuoteDirect Link to This Post
my pm was not addressed..... still waiting on reply.
Thanks
Tom Slick
Report this Post02-01-2016 07:32 PM Click Here to See the Profile for Tom SlickSend a Private Message to Tom SlickEdit/Delete MessageReply w/QuoteDirect Link to This Post
PP sent
blakeinspace
Total ratings: 120
Report this Post02-02-2016 02:38 AM Click Here to See the Profile for blakeinspaceSend a Private Message to blakeinspaceEdit/Delete MessageReply w/QuoteDirect Link to This Post
oil filter cap for a SD valve cover in there?... You come across one, let me know...
orygunparson
Report this Post02-02-2016 02:48 AM Click Here to See the Profile for orygunparsonSend a Private Message to orygunparsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you still have a set of the GT sail panel, I will buy a set. Please PM me. Thanks!
hiwil88formula
Report this Post02-07-2016 08:44 AM Click Here to See the Profile for hiwil88formulaSend a Private Message to hiwil88formulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ttt
hiwil88formula
Report this Post02-12-2016 09:59 PM Click Here to See the Profile for hiwil88formulaSend a Private Message to hiwil88formulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
ttt
fierogt455
Report this Post02-12-2016 11:22 PM Click Here to See the Profile for fierogt455Send a Private Message to fierogt455Edit/Delete MessageReply w/QuoteDirect Link to This Post
Are the exhaust manifolds cracked?
fierogt28
Report this Post02-12-2016 11:53 PM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
What is in the 15th picture down from the top?
PM sent...
hiwil88formula
Report this Post02-13-2016 10:03 AM Click Here to See the Profile for hiwil88formulaSend a Private Message to hiwil88formulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those would be radio mounts.
hiwil88formula
Report this Post02-13-2016 07:40 PM Click Here to See the Profile for hiwil88formulaSend a Private Message to hiwil88formulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
hiwil88formula
Member since Oct 2001
the exhaust manifolds all have been repaired and are ready to go
fierogt455
Report this Post02-13-2016 09:43 PM Click Here to See the Profile for fierogt455Send a Private Message to fierogt455Edit/Delete MessageReply w/QuoteDirect Link to This Post
I will take a pair of exhaust manifolds! You have a pm.
Thunderstruck GT
Total ratings: 99
Report this Post02-14-2016 03:24 PM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just found this on Ebay: http://www.ebay.com/itm/252...e=STRK%3AMEBIDX%3AIT
I'm guessing it's yours?
hiwil88formula
Report this Post02-14-2016 05:33 PM Click Here to See the Profile for hiwil88formulaSend a Private Message to hiwil88formulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those are mine. Not everybody is on pennocks.
Spoon
Total ratings: 61
Report this Post02-14-2016 06:07 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
Spoon
Spoon
Total ratings: 61
Report this Post02-14-2016 07:14 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spoon
Member since May 2004
Payment sent for cradle mounts.
Spoon
fierogt455
Report this Post02-14-2016 09:34 PM Click Here to See the Profile for fierogt455Send a Private Message to fierogt455Edit/Delete MessageReply w/QuoteDirect Link to This Post
Payment sent for a pair of exhaust manifolds.
Thunderstruck GT
Total ratings: 99
Report this Post02-16-2016 06:45 PM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Payment made for the NOS EGR valve.
fierogt455
Report this Post02-18-2016 05:17 PM Click Here to See the Profile for fierogt455Send a Private Message to fierogt455Edit/Delete MessageReply w/QuoteDirect Link to This Post
Received the exhaust manifolds today. Thanks
+1
Thunderstruck GT
Total ratings: 99
Report this Post02-20-2016 06:45 PM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got the EGR valve today.
100% perfect!
THANKS!
WhoDey
Report this Post02-20-2016 08:15 PM Click Here to See the Profile for WhoDeySend a Private Message to WhoDeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Received the engraved intake and 120 mph speedo. Quick shipping and good quality parts!! Thanks.
Spoon
Total ratings: 61
Report this Post02-20-2016 11:17 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Received my Rubber Cradle mounts. Better than expected. Fast shipping.
Spoon
hiwil88formula
Report this Post03-02-2016 08:31 AM Click Here to See the Profile for hiwil88formulaSend a Private Message to hiwil88formulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ttt
WhoDey
Report this Post03-20-2016 11:09 AM Click Here to See the Profile for WhoDeySend a Private Message to WhoDeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you still have the dual gauge pod?
Thunderstruck GT
Total ratings: 99
Report this Post03-20-2016 11:23 AM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
***DELETE***
Posted in wrong thread
Sorry
[This message has been edited by Thunderstruck GT (edited 03-21-2016).]
hiwil88formula
Report this Post03-21-2016 12:34 AM Click Here to See the Profile for hiwil88formulaSend a Private Message to hiwil88formulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Let me check on the pod I'll let you know tomorrow. And I still have a ton of parts for sale.
Report this Post03-23-2016 02:36 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any interior parts? I'm searching for a console storage box in Saddle Tan, suitable for a 70,000 mile car.
hiwil88formula
Report this Post03-23-2016 06:18 PM Click Here to See the Profile for hiwil88formulaSend a Private Message to hiwil88formulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry nothing like that. I do still have one gauge pod left.
WhoDey
Report this Post03-24-2016 12:32 PM Click Here to See the Profile for WhoDeySend a Private Message to WhoDeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Already went a different route with my gauges. Thanks.
RPYRAZOO
Report this Post08-14-2016 01:05 PM Click Here to See the Profile for RPYRAZOOClick Here to visit RPYRAZOO's HomePageSend a Private Message to RPYRAZOOEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have a HVAC/RADIO bezel that will fit an "87 GT? Don't know if the color is universal, but I'm looking for a dark grey piece.
Thanks,
Rich
