  The Mall
  keyless entry with pontiac keyfob for your car $50 shipped us and $60 canada. (Page 3)
keyless entry with pontiac keyfob for your car $50 shipped us and $60 canada. by mmeyer86gt/gtp
Started on: 02-15-2016 06:55 PM
Replies: 113 (4705 views)
Last post by: Dsanchez214 on 03-11-2021 12:44 PM
Richjk21
Report this Post06-29-2017 08:49 PM Click Here to See the Profile for Richjk21Send a Private Message to Richjk21Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, bought this a while ago but just got around to installing. Install was not too tough at all. Only thing that was a bit off was that on My 86GT the trunk popper wire is yellow with a black stripe, not gray/black as noted in the instructions. Luckily one of the other posters here ran into the same thing, and posted the correct wire (This wire color is what is shown in the 86 FSM). One other trick I added was I took the programming wire and ran it through a little latching pushbutton switch I had on hand from another project, and than tied it to the ground for the receiver. I tucked the button up under the dash next to my sub enclosure and now any time I need to program, I can just pull it down and press the button.
Rich
Edited to add - I Own Page 3
[This message has been edited by Richjk21 (edited 06-29-2017).]
USMUCL
Report this Post06-30-2017 07:26 PM Click Here to See the Profile for USMUCLSend a Private Message to USMUCLEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rich
Rich (and Page 3 Owner), did you wire to your footwell light on the passenger side? If so, was the white wire from the light the correct wire for your white wire from the RKE, or did you have to use the orange/white wire on the light like I did?
And, yea, the yellow/black is the correct trunk pop for 86 . . . and I *think* 87s.
[This message has been edited by USMUCL (edited 06-30-2017).]
Richjk21
Report this Post06-30-2017 10:50 PM Click Here to See the Profile for Richjk21Send a Private Message to Richjk21Edit/Delete MessageReply w/QuoteDirect Link to This Post
The white wire was the correct one on mine. After reading your post, I did check to be sure before wiring it to see which lead was carrying the +12V.
Rich
USMUCL
Report this Post07-01-2017 12:08 PM Click Here to See the Profile for USMUCLSend a Private Message to USMUCLEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rich
So, just to be clear, on yours the orange is carrying the 12 volt and the white is ground?
Richjk21
Report this Post07-03-2017 10:48 AM Click Here to See the Profile for Richjk21Send a Private Message to Richjk21Edit/Delete MessageReply w/QuoteDirect Link to This Post
That is exactly correct!! And agrees with the FSM. With the Bulb out on the Passengers side the Orange wire side of the bulb socket reads +12V to ground with my digital multi meter.
Rich
[This message has been edited by Richjk21 (edited 07-03-2017).]
Richjk21
Report this Post07-03-2017 10:53 AM Click Here to See the Profile for Richjk21Send a Private Message to Richjk21Edit/Delete MessageReply w/QuoteDirect Link to This Post
Richjk21
Member since Feb 2006
Just wanted to share one other thing I decided to do as a part of this upgrade project. I was wanting to jazz up the key fob unit a little bit.... it was a bit plain Jane for me.... I cannot take full credit for this one, as I drew inspiration from forum member Oreif, and his awesome door tabs he used to produce when he was still active on the forum several years ago (And Who's product I proudly have installed on my car). Anyhow here is what I did.... I have 2 fobs.... first one is done, second one is in progress. Not super easy to tell, but the diamond inside the arrowhead is silver.... it's much clearer and less washed out in real life... Anyhow, super happy with the product and this upgrade!!
Rich
USMUCL
Report this Post07-03-2017 01:59 PM Click Here to See the Profile for USMUCLSend a Private Message to USMUCLEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rich
That's crazy that mine tested out with a digital multi meter to be the exact opposite. The car is low mileage with no evidence anyone had messed with the wiring before me.
Richjk21
Report this Post07-03-2017 05:06 PM Click Here to See the Profile for Richjk21Send a Private Message to Richjk21Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah.... not sure what the dealio on that one is..... Only way to know for sure would be to follow wires back and see what's what.... Not sure it's worth it just to answer the question.... Maybe a couple pins/wires going out to your courtesy lights got inadvertently swapped in a connector..... Just for grins and giggles... did you check the wires on the drivers side.... are they reversed the same way??? Edited: From the diagram below it looks like they would have to be, both sides are wired together in one set of pins on C209.
Richjk21
Report this Post07-03-2017 05:18 PM Click Here to See the Profile for Richjk21Send a Private Message to Richjk21Edit/Delete MessageReply w/QuoteDirect Link to This Post
Richjk21
I would start with C209 - it is a two cavity connector that ONLY feeds the courtesy lights (circled in red) in the drawing attached. It is located by the LH side of the instrument panel, by the shroud.
Rich
Temi 300
Report this Post07-24-2017 05:31 AM Click Here to See the Profile for Temi 300Send a Private Message to Temi 300Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hello !
Ineed one with two fobs,
I dont know if there is actuators at mine doors.
Can you ship to Finland and how much is shipping.
I am seriously taken this parts.
Teemu
GMann20
Report this Post07-24-2017 06:15 PM Click Here to See the Profile for GMann20Send a Private Message to GMann20Edit/Delete MessageReply w/QuoteDirect Link to This Post
Could this be used with a the Fiero trunk release?
Thanks. Gary
G L Mann Oklahoma City, Oklahoma
mmeyer86gt/gtp
Total ratings: 73
Report this Post07-25-2017 10:56 AM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
I will have more units at the end of the week. If anyone is interested an i do ship international.
alex de jorge
Report this Post07-31-2017 10:06 PM Click Here to See the Profile for alex de jorgeSend a Private Message to alex de jorgeEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
mmeyer86gt/gtp
Total ratings: 73
Report this Post10-31-2017 12:07 AM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
1 november sale $50 for 1 module and 1 remote. $58 for 1 module and 2 remotes shipped usa.
Fiero Vice
Report this Post10-31-2017 11:23 AM Click Here to See the Profile for Fiero ViceSend a Private Message to Fiero ViceEdit/Delete MessageReply w/QuoteDirect Link to This Post
Your November sale got my attention. I'm in for $58 for 1 module and 2 remotes, but got few questions about future plan of installing alarm system. Would it create a conflict? PM sent!
Phirewire
Report this Post10-31-2017 11:28 AM Click Here to See the Profile for PhirewireSend a Private Message to PhirewireEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interested, are remotes new or used ( i don't recall seeing it in the thread.)
[This message has been edited by Phirewire (edited 10-31-2017).]
mmeyer86gt/gtp
Total ratings: 73
Report this Post10-31-2017 07:08 PM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
remotes are used but really good condition.
Fiero Vice
Report this Post11-01-2017 05:40 PM Click Here to See the Profile for Fiero ViceSend a Private Message to Fiero ViceEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pmt of $59.98 sent, $58 for 1 module and 2 remotes shipped, plus paypal fees of $1.98 per your request.
Thanks
Fiero Vice
Report this Post11-06-2017 06:46 AM Click Here to See the Profile for Fiero ViceSend a Private Message to Fiero ViceEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by Fiero Vice (edited 11-10-2017).]
Curtisk1060
Report this Post11-06-2017 08:32 PM Click Here to See the Profile for Curtisk1060Send a Private Message to Curtisk1060Edit/Delete MessageReply w/QuoteDirect Link to This Post
Paypal payment sent $58 for module and two remotes, thanks Curtis
Curtisk1060
Report this Post11-06-2017 08:53 PM Click Here to See the Profile for Curtisk1060Send a Private Message to Curtisk1060Edit/Delete MessageReply w/QuoteDirect Link to This Post
Curtisk1060
Member since Dec 2011
As an FYI for those of you with stock subwoofers, this installation is not quite as easy. Save yourself time and frustration and first remove the front passenger side dash speaker along with the subwoofer as it needs to be gone before you proceed. Just unbolt the three screws that hold in the subwoofer assembly and lower it down, no need to unwire it unless you want to.You will need to have the front speaker out in order to re-install the subwoofer box back into place once the wiring to the door lock solenoid is done. Next try to find a spot for the KE module. On my sons 87GT w/factory subwoofer and cruise control, I ended up just using some industrial strength velcro and stuck it under the heater box back against the passenger side footwell. It is up out of the way and fairly easy to get to and run the wires needed. You don't even know it is there unless you get down on your knees. Also, be sure to add enough wire lengths to the module on the bench for where you intend it to be mounted and cut to fit when in place. You can cover the wires in electric tape to simulate much of the factory wiring. Its not a lot of fun to solder overhead. As someone else previously mentioned, there is no difference whatsoever if you wire to both light blue wires and black wires versus only one each of them as they are all going to terminal C2 B ( blue) and C2 A ( black) of the door lock relay. If anyone can explain to me how it will open first the DS door, then the PS door, I would love to know how, given the fact that they are both energized simultaneously from the module. The orange wire goes to C1 A of the door lock relay. Also, be sure to verify that the white courtesy light wire in your car is in fact the ground of your courtesy lights. I really like the light on feature when opening the doors and/or trunk. Overall this is a great upgrade but it takes some time and patience to make it fit like factory. If you don't have cruise control or if you have converted it to the electronic version via the AR cruise control servo, then you will be able to locate the KE module in place of the old stock Fiero cruise control module along the drivers side tunnel area. I plan on doing this on my 88GT but it will take a bit more wire to reach the door relay. For those who have no factory subwoofer, the passenger side subwoofer amplifier location would seem to be the best location for the module if you wish to hide it. I don't understand how it is mounted if not located in this place as I would not just hang it from the wires going to/from the door lock relay. Hope this helps others. Curtis
[This message has been edited by Curtisk1060 (edited 11-06-2017).]
Fiero Vice
Report this Post11-07-2017 09:26 AM Click Here to See the Profile for Fiero ViceSend a Private Message to Fiero ViceEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by Fiero Vice (edited 11-07-2017).]
mmeyer86gt/gtp
Total ratings: 73
Report this Post11-07-2017 11:03 AM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have issues with my remote distributor all of the ones i received were bad. They are remedying this within 2 days and if i don't get a good set i will be refunding everyones money by friday. sorry for the issues.
mmeyer86gt/gtp
Total ratings: 73
Report this Post11-10-2017 12:35 AM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
all paid items that i had the addresses to were shipped today
tracking
9500 1159 0396 7313 1561 14
9500 1159 0396 7313 1561 21
9500 1159 0396 7313 1561 07
[This message has been edited by mmeyer86gt/gtp (edited 11-10-2017).]
mmeyer86gt/gtp
Total ratings: 73
Report this Post11-10-2017 02:10 PM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
mmeyer86gt/gtp
Member since Sep 2001
More kits avaliable
Fiero Vice
Report this Post11-13-2017 05:56 PM Click Here to See the Profile for Fiero ViceSend a Private Message to Fiero ViceEdit/Delete MessageReply w/QuoteDirect Link to This Post
mmeyer86gt/gtp,
Just got my package in the mail today. But there was no instructions provided as stated. Can you please send me one via email?
Thanks.
mmeyer86gt/gtp
Total ratings: 73
Report this Post11-13-2017 11:22 PM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
3 Wire Connector:
1. Pink- Switched 12V from fuse block (I use the one behind the stereo)
2. Black- Trunk release, black on 84, gray/black on 85+, at the trunk release switch
3. Black/White- Leave disconnected (ground to program remotes)
8 Wire Connector:
4. Red/Black- Not used
5. Orange/Black- Not used
6. White- Connect to the white wire going to the light
7. Gray- light blue wires
8. Tan- Splice both together, black wires on door lock/unlock connector next to light
9. Black- Ground screw for power lock relay
10. Orange- Orange/Black wire at power lock relay
jjd2296
Report this Post02-24-2021 01:02 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
I need another kit, with 2 keyfobs.
George P Wood
Report this Post02-25-2021 12:49 AM Click Here to See the Profile for George P WoodSend a Private Message to George P WoodEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would like another one also plus two remotes.
Please verify that they are all working prior to shipping.
Dsanchez214
Report this Post02-25-2021 11:24 AM Click Here to See the Profile for Dsanchez214Send a Private Message to Dsanchez214Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bring this thread back from the dead and a BUMP to the top.
I am also interested in keyless entry with 2 remotes.
Ponnari
Report this Post03-08-2021 09:21 PM Click Here to See the Profile for PonnariSend a Private Message to PonnariEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll take one please, and a extra remote. Sending you a PM
Thanks - Lou
"Because in a split second, It's gone"
Ayrton Senna
[This message has been edited by Ponnari (edited 03-08-2021).]
jaymelk2
Report this Post03-09-2021 07:33 AM Click Here to See the Profile for jaymelk2Send a Private Message to jaymelk2Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Meyer...long time no type🤪🤪 Please throw me in for a kit with two fobs please. Thank you sir.
87 GT....SBC...fast as hell...
Proud new owner of....THE DIRTY RAT
mmeyer86gt/gtp
Total ratings: 73
Report this Post03-10-2021 01:06 PM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
FYI im out been out for 2 years used to see 20-30 of these cars in local yards now see 1-2 every 4 months. Most do not have this option. I have 1 module but i am keeping that incase my modules go bad.
You can find these modules here
control box found in 93-95 camaros and firebirds. The box is found on the kick panel in front of the passenger side door under the trim piece.
remotes are called ABo0104T with the pontiac emblem.
Hawks motorsports from easily sc might have modules. I used to buy and sell stuff with them for a number of years. i would assume they want 80-100 for that module with pigtail. Remotes cost have gone up considerably used to get them for 10 each now see them from 25-30 each on ebay.
Dsanchez214
Report this Post03-11-2021 12:44 PM Click Here to See the Profile for Dsanchez214Send a Private Message to Dsanchez214Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you for the reply. I will definitely keep an eye out at the local junkyards.
