  The Mall
  FS Sprint Headers and widened 88 crossover
FS Sprint Headers and widened 88 crossover by carnut122
Started on: 02-24-2016 07:07 AM
Replies: 10 (697 views)
Last post by: carnut122 on 04-19-2016 07:40 PM
carnut122
Total ratings: 83
Report this Post02-24-2016 07:07 AM Click Here to See the Profile for carnut122Send a Private Message to carnut122Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had these headers on my 1988 3.4 L V-6 (yes, they'll fit a 2.8 L) for about 6 years and I went back to the stock manifolds. The crossover has been slightly widened to better line up with the headers and it has had the internal restriction removed (which is supposed to be worth 10hp?). I would buy these only if you plan on installing them while the engine is out of the car and if you intend on using studs instead of flange bolts. The headers are in very solid condition. I'll take $280 shipped in the lower 48 for just the headers or $340 shipped in the lower 48 for the headers and crossover.
[This message has been edited by carnut122 (edited 02-24-2016).]
Imnuts
Report this Post02-24-2016 12:09 PM Click Here to See the Profile for ImnutsSend a Private Message to ImnutsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Will these bolt up to the Stock crossover?
carnut122
Total ratings: 83
Report this Post02-24-2016 08:06 PM Click Here to See the Profile for carnut122Send a Private Message to carnut122Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm not sure as I was not happy with how it all lined up with the stock crossover, so I cut down the middle of the Y, cut out the restriction, spread it out pipes slightly, and then had the muffler shop weld in the patches that you see in the picture. The alignment on my crossover is still less than optimal. If I was to reinstall the headers, I'd take the crossover to a muffler shop and have them slightly expand the bellows on the ends. Or, I'd construct some copper crash washers to ensure that there are no leaks. Due to "extra noise" I always wondered if I had exhaust leaks. Thus, I put the stock exhaust back on. Well, the stock exhaust seems to be just as loud, and I saw no evidence of an exhaust leak, so apparently they were sealed up.
Total ratings: 463
Report this Post02-24-2016 09:11 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
If these are the same set of headers that I sold to Carnut, then a stock crossover can be made to fit, but it doesn't fit well.
I had a stock crossover on my car, with these headers, but it really wasn't happy. Had to spread it a bit and pull it up tight with the four bolts.
You will likely find that all of the earlier Fiero Store headers will fit just the same as these.
The later ones fit better, but the tubes are sectioned together and welded. They don't have the one piece tubes that make up these headers.
carnut122
Total ratings: 83
Report this Post02-25-2016 07:25 AM Click Here to See the Profile for carnut122Send a Private Message to carnut122Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, they are the ones I bought from you. After I got them home, I blasted them, painted them with ceramic paint, and cured the paint in my powder coating oven. Structurally, I don't think they've changed a bit since I got them from you; they're still very solid headers.
carnut122
Total ratings: 83
Report this Post02-26-2016 07:28 AM Click Here to See the Profile for carnut122Send a Private Message to carnut122Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
hobbywrench
Report this Post02-26-2016 01:55 PM Click Here to See the Profile for hobbywrenchSend a Private Message to hobbywrenchEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has anyone ever seen the measured hp gain with these headers on 2.8? I notice FieroStore is always silent. I have always avoided these new as a big investment without known gain. It looks like the welding has held up well.
Total ratings: 463
Report this Post02-26-2016 09:29 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
The general consensus is that they are maybe a little better than ported stockers.
I'm thinking ~5 HP is what I remember hearing. (To be fair, it's been a while. 5 was the minimum. It may be more than that.)
With that said, a hard look can crack the stockers. These things are thick as hell. I'd really be surprised if they were to ever crack.
carnut122
Total ratings: 83
Report this Post03-01-2016 09:36 AM Click Here to See the Profile for carnut122Send a Private Message to carnut122Edit/Delete MessageReply w/QuoteDirect Link to This Post
Last bump before they go into storage.
Rfe88GT
Report this Post04-19-2016 03:01 PM Click Here to See the Profile for Rfe88GTSend a Private Message to Rfe88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey they look great. Thanks for packing them so well.
carnut122
Total ratings: 83
Report this Post04-19-2016 07:40 PM Click Here to See the Profile for carnut122Send a Private Message to carnut122Edit/Delete MessageReply w/QuoteDirect Link to This Post
They're very solid. Glad to hear your satisfied with the purchase.
Thanks!
