Paypal only
US Shipment only
PM or email me
Local Pickup is available
Edit* Sorry needed to add, this is for a 84-87 cradle. The motor mount isn't correct for the 88 cradle.I purchased these mounts prior to getting my transmission and ended needing a Pin style mount for a newer transmission. These are all the brackets you need along with new rubber mounts for a 3800/SC & 4T65E swap. The trans brackets are from a Trans Sport Van and the motor mount is from West Coast Fiero. When using the Transport mounts you will need to notch the cradle slightly as these mount the transmission lower than most aftermarket brackets. $200 shipped for all of the mounts. Not looking to split them up right now.
Sold
This is a Thermostat housing from a 2.8, if you are needing one to modify for a swap, here you go. $25 shipped
Sold
If you have the wrong oil filter adapter for your swap, this one will work, it moves the oil pressure sensor away from the axle as well. You will need to use the short style filter with this adapter. $30 shipped
[This message has been edited by Lancer-AM (edited 04-01-2016).]
