1988 Pontiac Fiero GT for sale. Regular oil changes, uses syncromesh in the Getrag. Comes with some extra parts and pieces, including original shop manual (yeah the 4 inch thick one), I'm getting out of the Fiero business for now. Looking for around $4,000 right now. Craigslist ad at
https://stlouis.craigslist....cto/5756120175.html.The good:
Lots of work done.
Shifter assembly/cables completely replaced/rebuilt, along with short shifter, using Rodney Dickman parts.
Sunroof entirely rebuilt.
Rear suspension almost entirely new, using Fiero Store performance poly parts/Rodney Dickman parts. Only thing that isn't new is the springs.
Clutch/flywheel/slave cylinder brand new, still has a few miles left on the break in, using Spec parts. Master cylinder replaced about four years ago.
Aftermarket ignition coil
Momo Steering Wheel
Brake booster upgrade
Aftermarket stereo, works with stock performance sub
Paint is in decent shape, a few scratches here and there
Dew wipes (Fiero.nl vendor, did drivers side but still have to install passenger side)
Door hinges rebuilt (Rodney Dickman, did drivers side but still have to install passenger side)
Speakers
Other stuff, can't recall everything.
The bad:
The usual wear and tear on the interior - some chipped dash corners, leather driver seat needs to be recovered, and rear glove box cracked
One sail panel is cracked, the other has heat spidering
AC needs recharging
The engine could use a good bath...
