  The Mall
  *New* Iron Duke Stainless 4-2-1 headers
*New* Iron Duke Stainless 4-2-1 headers by Slammed
Started on: 12-13-2016 03:15 AM
Replies: 17 (1539 views)
Last post by: fireboss on 06-11-2017 07:55 PM
Slammed
Total ratings: 79
Report this Post12-13-2016 03:15 AM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
The headers are built from 304 stainless and are fully TIG welded. 16 gauge 1 1/2" primaries, with a 2 1/4" ID collector and 3/8" flanges. These do not exit in the stock location as they are much longer, so the stock downpipe will need a flange welded onto it. I do not have a duke car together at the moment so for the time being I will not be offering a crimp or weld on adapter.
I will include hardened conical washers and new bolts with the headers.
For now they are made to order. If there is enough of a demand I will start keeping them in stock
The price right now is $225 shipped to the US and only to the US. If I start stocking them the price will drop
Any questions please ask! I'm glad to help
rkirkpatrick
Report this Post12-13-2016 03:29 PM Click Here to See the Profile for rkirkpatrickSend a Private Message to rkirkpatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is there no O2 sensor spot?
Slammed
Total ratings: 79
Report this Post12-13-2016 04:01 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is, just not in the set pictured. It was built for a remote mount turbo s10. It will exit out of the collector toward the driver side.
qwikgta
Total ratings: 84
Report this Post12-13-2016 09:13 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Two things. First, for those who are thinking about a header for your 2.5L I can tell you from actual experience (not just "what I think") that it will work on your motor. I put one on my 2.5 and while I can't say for sure it was any faster, I couldn't believe the difference it made in the RPM's. What I'm saying is that when you throttle the pedal the RPM's came up MUCH faster, it was like night/day between the stock setup. Again, not saying I took a second off my 0-60 or anything but the RPM's would rise and fall much faster than stock.
Second, I think the stock manifold is shaped the way it is because of the loop that it creates for the catalytic converter. Any chance on getting the end to point the other direction so that it can exit the motor and already be heading for the "hump" that is placed on the stock cradle for the exhaust to exit? When I did mine I ran a cat in the stock muffler location and just a resonator tip on the end of the pipe. Even had a "Supertrapp" on for a while. (remember those).
Great looking header, I may even purchase one for my wall of "Fiero Stuff".
Rob
LaFierte
Report this Post12-13-2016 10:04 PM Click Here to See the Profile for LaFierteSend a Private Message to LaFierteEdit/Delete MessageReply w/QuoteDirect Link to This Post
Out of curiosity, how come you did away with the bolt holes on the flange at the head side?
Slammed
Total ratings: 79
Report this Post12-13-2016 10:46 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Less waste and not as hard on the plasma. I would love to have a plasma that could handle 3/8" pierce cuts over and over again, but that isn't going to happen and the flanges are cut much quicker this way.
Total ratings: 463
Report this Post12-14-2016 06:10 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
This header is quite similar to some Jeep headers that I've seen. Most of the Jeep headers use similar flanges.
Our 4.0 six cylinder also had the same flanges. The factory uses a "captive washer" type bolt.
Slammed
Total ratings: 79
Report this Post12-14-2016 06:50 AM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh c'mon, don't go giving away my secrets! A note though, you cannot take any jeep header and bolt it to the iron duke. They are not the same
[This message has been edited by Slammed (edited 12-14-2016).]
Total ratings: 463
Report this Post12-14-2016 06:14 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not my intent. Most everything I found was either more expensive than yours, or crap, anyway.
Just an observation about the flanges. (The header that I replaced worked just fine with those flanges.)
Edit - A question, though...
How close does the header come to the starter? (Or how close will the extension pipe need to be?)
I am thinking about buying one of the later gear reduction starters for my Duke, to save a little weight and some current drain. They seem to have the solenoid "clocked" at about 1 o'clock or 1:30, looking at the front of the starter. Wondering if there will be enough room.
Thanks!
[This message has been edited by Raydar (edited 12-14-2016).]
Slammed
Total ratings: 79
Report this Post12-14-2016 07:41 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll put one on my duke block here and take some pictures. I know it will clear the stock starter no problem
regal7point5
Report this Post12-19-2016 09:29 PM Click Here to See the Profile for regal7point5Send a Private Message to regal7point5Edit/Delete MessageReply w/QuoteDirect Link to This Post
As promised, you have been Paypal'ed...Woo hoo. I know these are MTO, and the holidays are upon us, but what kind of lead time can I expect?
Thanks,
Aaron
Slammed
Total ratings: 79
Report this Post12-20-2016 01:01 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll try and get them out before the weekend but it will likely be the 26th
Thank you for the purchase!
regal7point5
Report this Post12-29-2016 09:46 PM Click Here to See the Profile for regal7point5Send a Private Message to regal7point5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Were you able to get the header shipped out yet? I have a couple more days off work and would love to get it mocked up before going back to the grind, haha.
regal7point5
Report this Post01-07-2017 06:25 PM Click Here to See the Profile for regal7point5Send a Private Message to regal7point5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Please check your PM's...Thanks.
Hidalgo
Report this Post06-05-2017 02:51 PM Click Here to See the Profile for HidalgoSend a Private Message to HidalgoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm curious to know, regal7point5, did you receive and install your headers? And if so, what are they like?
regal7point5
Report this Post06-07-2017 08:15 PM Click Here to See the Profile for regal7point5Send a Private Message to regal7point5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Never received them...had to file a PayPal claim to get refunded. Same thing happened to a bunch of folks that were buying GT reproduction taillights from this member. I don't think the member has been active on here since. It is a shame because the pictures of the headers showed real promise.
Francis T
Total ratings: 119
Report this Post06-11-2017 06:03 PM Click Here to See the Profile for Francis TClick Here to visit Francis T's HomePageSend a Private Message to Francis TEdit/Delete MessageReply w/QuoteDirect Link to This Post
Vert nice header and you did right not going the equal length rout; a 3Y is the way to go with that motor. My only concern, without 8 bolts they may warp down the road and cayse exhaust leaks. Whereas we made headers and intake manifolds for the v6s i would suggest keeping your inventory low. Good luck
fireboss
Total ratings: 58
Report this Post06-11-2017 07:55 PM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
And also to actually produce the product and ship them to the people who paid for them....
