  The Mall
  For sale, COMPLETE L32/F23 swap
For sale, COMPLETE L32/F23 swap by BV MotorSports
Started on: 01-08-2017 12:58 AM
Replies: 7 (1286 views)
Last post by: BV MotorSports on 01-23-2017 07:36 PM
BV MotorSports
Total ratings: 189
Report this Post01-08-2017 12:58 AM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
***SOLD***
Sellling my complete setup out of my '88GT to make way for the new hotness swap! I'll try to note everything it has but it would be much easier just to call for more info.
****Edit to add** This is a complete, running and driving set up. Drop in and go. You will need to alter the firewall (easy) to make use of my quick disconnect wiring system. No longer have to touch the interior when pulling the drivetrain.
Builld and pics
Off the top of my head:
2007 Pontiac Grand Prix Series III L32 3800sc (genV SC!) converted to run Series II electronics. 70k miles
2001 F23 5 speed 60k miles (opened up and inspected by trans shop)
Spec stage3+ clutch
Spec HTOB & spacer
Delphi 60# pencil injectors **edit to update**
ZZP fuel rails
ZZP 3.2 modular pulley
ZZP Short stack w2a intercooler
ZZP stainless manifolds
ZZP RRFPR
ZZP IAT break out harness
ZZP Oil pressure spring
New OEM water pump
ZZP 185f tstat
Custom 3" stainless downpipe w/ vband and WBO2 bung (NO trunk cutting)
Northstar TB & ZZP adapter
LQ4 MAF
Custom CAI
MSD Plug wires
wiring harness & tuned ECU
Engine and trans mounts
California push/pull Shifter cables
F23 shifter cable mount
ARP flywheel bolts and crank drilled to 10mm x 1.0 (no more loose flywheel bolts..ever!)
All great running, buyer is welcome to test drive before buying. Will perform the complete swap to the buyers car (additional cost)
Call or PM for more info. 850-896-5527
[This message has been edited by BV MotorSports (edited 01-19-2017).]
onesexyfiero
Report this Post01-08-2017 09:51 AM Click Here to See the Profile for onesexyfieroSend a Private Message to onesexyfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
price?
BV MotorSports
Total ratings: 189
Report this Post01-08-2017 09:07 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
The stock exhaust crossover has been refitted and the shifter cables routed completely different. Not shown.
Quick connect wiring system
[This message has been edited by BV MotorSports (edited 01-08-2017).]
fireboss
Total ratings: 58
Report this Post01-13-2017 02:47 AM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by onesexyfiero:
price?
BV MotorSports
Total ratings: 189
Report this Post01-13-2017 07:43 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by fireboss:
Just PM or call for price as it will be between me and the buyer. No need to post it otherwise.
BV MotorSports
Total ratings: 189
Report this Post01-18-2017 12:39 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sale pending
88GaTa
Report this Post01-23-2017 07:16 PM Click Here to See the Profile for 88GaTaSend a Private Message to 88GaTaEdit/Delete MessageReply w/QuoteDirect Link to This Post
She's sitting in my garage right by her new home. I cant stop looking at it. Thanks so much Steven!
BV MotorSports
Total ratings: 189
Report this Post01-23-2017 07:36 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm happy for you buddy. It was great meeting you and your family. Terrible weather you brought with you!
