  The Mall
  88 Formula, console skeleton, 88 headlights, 88,84-87 parts,MANY other parts for sale
88 Formula, console skeleton, 88 headlights, 88,84-87 parts,MANY other parts for sale by AL68
Started on: 02-09-2017 10:40 PM
Replies: 29 (1083 views)
Last post by: AL68 on 03-10-2017 08:00 PM
AL68
Report this Post02-09-2017 10:40 PM Click Here to See the Profile for AL68Send a Private Message to AL68Edit/Delete MessageReply w/QuoteDirect Link to This Post
don't like the price - make me an offer!
Selling off some stuff to raise money for down payment on a new house - I need a bigger garage!
All prices + shipping - USPS or Fedex, I ship out Fedex Wed, USPS &Fedex Saturday AM.
I have bigger pics of items if needed, more stuff comming once I dig it out, contact me if you need anything, parted out
an 88 Formula & 86 GT (no GT taillights ......yet.....) I'm usually here 9-10p CST
88 Formula : 96k, auto, parked 2 years ago - did run good & started at 15 degrees when last moved, battery bad,tries weathered,
good tan interior, needs paint, rear bumper has tear, was going to rebody as a GT but found one.
has salvage on title from light RF damage in the late 90's. No rust except little on battery tray fron acid,
trunk corners solid, Have many pictures. - $800
Also have a set of black 88 Formula wheels, good shape/bad tires, pickup only, $150 sold
console skeleton from 88 Formula, fits all years, NO CRACKED HOLES anywhere, packed & ready to ship - $150
box is only 12 lbs but 48x14x12, USPS retail ground is about $45 to the coasts
new 3pcs motor/trans mounts for 2.8 auto 2472,2466,2467 - $15.00 all three - sold
(2) 1" drop Rodney lower ball joints 84-87, $69 ea new, sell $100 pr
1227170 PCM from 88 Formula v6/auto with Hypertech 228021 Streetrunner chip (195 thermostat) - $60
1227170 PCM from 86 GT v6/auto stock $20 - sold
"FIERO" side scoop used - $15 - sold
"FIERO" 3rd brake mask & lens - $10 - sold
window switch plate n/a
main (not on motor) headlight relay 84-86. working when pulled - $15
MSD Fiero coil - $10 - sold
Leather auto shifter handles dark gray, nice used - $15 each
86 owners manual - $5 - sold
88 Formula steering wheel, light color wear on top edge,7 out of 10, smooth solid foam, buttons good - $40
non-Fiero simulated leather foam steering wheel with Fiero center, little wear on top, 6 out of 10, good
driver wheel to replace squishy GT one, $20 - sold
good console gauges (covers have cracked screw holes) - $10 ea
88 Formula cluster w/trim panel, all working, 120mph speedo with 48K, - $100
86 GT cluster, no trim, speedo probably bad - mileage uneven, good tach - $25 sold
v6 alternator bracket, bead blasted, nice - $50
v6 t-stat housing, bead blasted - $20 - sold
EGR dress-up caps - $5 ea - sold all
tan dash pocket - $10
Aero/GT front plate bracket - sold
3pc keyed alike locks & mount/cover, 86 GT - $50
nice Camaro leather verticle shift knobs, fit Fiero, $12 ea
tan rubber solid shift knob - $5
Premium Sound Systems, tan or gray, complete system w/all wiring - $100 each---------- both sold
first sold gets box with speaker (no guarantee) & radio adapter pigtail
second - no speaker but has factory wire, no radio adapter
T-Top parts: overhead lights console cover & an original console to modify like original,
2 plastic pieces with good screw holes, 2nd pair are broken - $30 for all ----------------------sold
pair of light gray visors from 84 SE, VERY nice - look new - $25 pr ----- sold
87-88 headlight setup, working motors, harness had one socket repaired with waterproof
crimp connectors(lower right), will ship w/outhousing assemblies if not wanted for cheaper
shipping - $120 sold
recall trunk strips w/clips, some overspray on clips, good rubber/no tears - $50 ea - only one left
Set of 5 used strip clips $15
Fiero/Bonneville leather handle cores for recovering (all have little clip under knob), $5 ea
Fiero quarter window scoops, fiberglass ok, rough faded paint, each has screw holes filled
with resin, needs sanding/repaint, $50 pr - sold
80's Mustang GT/Turbo scoop was on 86 GT trunk lid, all studs good to bolt on, can bond on, 25" wide x 25" long to points, $70 - sold
88 engraved intake washed, some paint came off, ready to blast & paint/powdercoat - $40
88 valve covers, a lot of paint came off, ready to blast & paint/powdercoat - $30
88 T-stat housing used $15 - sold
88 EGR tube - good used - $30
short 5spd shifter & cables (from RPRO's white 86 GT 3.4) - $75 sold
pair of Cardone window motors #42-19,never installed, $50 pr - sold
pair of stainless quick-connect lines for 3800 swaps - $25 pr
pair of tan door pockets, need a little cleaning, $20 pr
seat cover back for L or R from 86 GT, no tears or broken piping, nice, $50
more to come........
[This message has been edited by AL68 (edited 03-10-2017).]
mrfiero
Total ratings: 150
Report this Post02-09-2017 10:48 PM Click Here to See the Profile for mrfieroSend a Private Message to mrfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dibs on T-Top parts & both subwoofer systems. PM sent!
Knight Rider
Report this Post02-10-2017 02:53 AM Click Here to See the Profile for Knight RiderSend a Private Message to Knight RiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM Sent on Gen II headlight setup
hoddy
Report this Post02-10-2017 03:29 AM Click Here to See the Profile for hoddySend a Private Message to hoddyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pm sent
Spadesluck
Report this Post02-10-2017 06:19 AM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent for the quarter scoops
trivet
Report this Post02-10-2017 09:31 AM Click Here to See the Profile for trivetSend a Private Message to trivetEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is a great price on the Formula - I would grab it if it was closer. GLWS!!
MEL H. JOHNSON
Report this Post02-10-2017 10:39 PM Click Here to See the Profile for MEL H. JOHNSONSend a Private Message to MEL H. JOHNSONEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent for side scoop, 3rd brake lite & trunk scoop !!!!! Mel
ARFiero
Report this Post02-10-2017 10:46 PM Click Here to See the Profile for ARFieroSend a Private Message to ARFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent on 3 spoke steering wheel.
AL68
Report this Post02-11-2017 01:42 AM Click Here to See the Profile for AL68Send a Private Message to AL68Edit/Delete MessageReply w/QuoteDirect Link to This Post
all pm's/posts replied
both subs and t-top parts sold
Knight Rider
Report this Post02-11-2017 05:37 PM Click Here to See the Profile for Knight RiderSend a Private Message to Knight RiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent for headlights
AL68
Report this Post02-11-2017 10:47 PM Click Here to See the Profile for AL68Send a Private Message to AL68Edit/Delete MessageReply w/QuoteDirect Link to This Post
pm's replied - pm me back if I missed someone
headlights sold
MEL H. JOHNSON
Report this Post02-11-2017 11:47 PM Click Here to See the Profile for MEL H. JOHNSONSend a Private Message to MEL H. JOHNSONEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent & paypal on the way !!!!! Thanks, Mel
AL68
Report this Post02-12-2017 11:52 PM Click Here to See the Profile for AL68Send a Private Message to AL68Edit/Delete MessageReply w/QuoteDirect Link to This Post
sold list updated & pm's replied
AL68
Report this Post02-14-2017 11:07 PM Click Here to See the Profile for AL68Send a Private Message to AL68Edit/Delete MessageReply w/QuoteDirect Link to This Post
pm's replied
Division006
Report this Post02-18-2017 01:53 PM Click Here to See the Profile for Division006Send a Private Message to Division006Edit/Delete MessageReply w/QuoteDirect Link to This Post
Dibs on the stock default stereo if it's still in that car !
Division006
Report this Post02-18-2017 02:09 PM Click Here to See the Profile for Division006Send a Private Message to Division006Edit/Delete MessageReply w/QuoteDirect Link to This Post
Division006
Member since Apr 2016
https://i.imgsafe.org/898b60d92f.jpg <------- Here's the Semi dmg's again all the way down the side.
https://i.imgsafe.org/898b69b223.jpg <------- Front left tire no rubber thingy stopping rocks from hitting door.
https://i.imgsafe.org/898b743312.jpg <------- I need that metal thing that supposed to cool off my Alternator, it's like a coil thing, perhaps you can look at this and tell me what else I should but that's missing that your trunk has.
https://i.imgsafe.org/898b763ab6.jpg <------- Missing those two screws that hold this vent.
https://i.imgsafe.org/898b799ec4.jpg <------- My visor looks like crap, maybe you have one ?
https://i.imgsafe.org/898b9175ff.jpg <------ My skeleton is so bad, Now i can't even hold up my other button thingybibob
https://i.imgsafe.org/898ba5230d.jpg <----- Need trim to like stop water from hitting my face after I get out of the vehicle and rocks are jammed in the door, ( sometimes can't get out and water still hits me )
https://i.imgsafe.org/898bc1dde7.jpg <----- Front left flap rubber thing is gone, this is where I reinforced my **** but still hear noises or something.
https://i.imgsafe.org/898bd99e55.jpg <---- circle means flap is missing and like part of the car got sucked out along with my other rearview mirror. I still painted it so no one will notice.
https://i.imgsafe.org/898be2d800.jpg <----- What happens when your car comes with a broken skeleton.
https://i.imgsafe.org/898bf7affc.jpg <---- this is what happens when you lose the shield that holds your wires up. There is one screw too, i think that is supposed to hold this like shield.
https://i.imgsafe.org/898c0abdb0.jpg <----- tried to glue my skeleton with E600 and like 3 other types of glue to no avail. This is what happens when you drive across the US too many times and try to fix your car on the side of the road and you're deaf.
https://i.imgsafe.org/898c2097cf.jpg <------ Itt is a pain to fix it. This is what happens when you can't glue **** right you have to buy more **** .
https://i.imgsafe.org/898c327b45.jpg <----- This is the rear right tire, the flap missing of my rear right tire, there is like water hitting my belt probably, but I have no idea because I can't hear. I should probably put that flap up in there with all the screw that come with it? I keep hearing squealing when i'm going through puddles in Grass Valley and sometimes i feel it wants to snap or some **** .
https://i.imgsafe.org/898c446fed.jpg <---- This is the rear right tire again dude; the circles signify i need a rubber flap that goes up all above the tire.
-Kyle
[This message has been edited by Division006 (edited 02-19-2017).]
Division006
Report this Post02-18-2017 02:12 PM Click Here to See the Profile for Division006Send a Private Message to Division006Edit/Delete MessageReply w/QuoteDirect Link to This Post
Division006
I still call dibs on dem stock stereo you got bromhide. I gotta have that stock stereo for the Fiero ! those were them good ol' days. Help.
Division006
Report this Post02-18-2017 02:52 PM Click Here to See the Profile for Division006Send a Private Message to Division006Edit/Delete MessageReply w/QuoteDirect Link to This Post
Division006
https://i.imgsafe.org/8a4d29b87b.jpg <------ The circles signify the damages. I put house paint on the black marks. I think the Semi wanted to suck me underneath. I did not have have a scoop that is a new scoop I put on the side.
https://i.imgsafe.org/8a4cbd1827.jpg <------ The tire sucked everything. Luckily I took a hard right as soon as the vortex attacked me from behind.
I think I might need to get a beer, sit next to a Ford Taurus, maybe get some body parts. Maybe it's still feasibly possible ? my car is completely new except for these things.
AL68
Report this Post02-18-2017 11:51 PM Click Here to See the Profile for AL68Send a Private Message to AL68Edit/Delete MessageReply w/QuoteDirect Link to This Post
I don't have the radio or body parts, the red car's been gone a couple years, just saved the good stuff & most is already sold.
The console skeleton is going to be on ebay if no one here needs it.
The white Formula is in a storage lot 20 miles away from me, won't see it unless someone's interested in buying it.
[This message has been edited by AL68 (edited 02-18-2017).]
hiwil88formula
Report this Post02-19-2017 12:39 PM Click Here to See the Profile for hiwil88formulaSend a Private Message to hiwil88formulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I need the intake and valve covers pm me your paypal. Shipping to 78250
GDC88
Report this Post02-19-2017 12:51 PM Click Here to See the Profile for GDC88Send a Private Message to GDC88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sent PM
USMUCL
Report this Post02-19-2017 08:03 PM Click Here to See the Profile for USMUCLSend a Private Message to USMUCLEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dibs on the visors. PM'd
[This message has been edited by USMUCL (edited 02-19-2017).]
handymanpat
Report this Post02-19-2017 09:34 PM Click Here to See the Profile for handymanpatSend a Private Message to handymanpatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks so much for the great parts and fast shipping. Everything was packaged very well!
ARFiero
Report this Post02-22-2017 09:50 PM Click Here to See the Profile for ARFieroSend a Private Message to ARFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got my parts today! Thanks!
Shelby
MEL H. JOHNSON
Report this Post02-23-2017 08:42 PM Click Here to See the Profile for MEL H. JOHNSONSend a Private Message to MEL H. JOHNSONEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Al, I got my goody box & can tell by your package that you've done it before !!!!! Thanks for a GREAT deal !!!!!! Mel
AL68
Report this Post02-25-2017 01:00 AM Click Here to See the Profile for AL68Send a Private Message to AL68Edit/Delete MessageReply w/QuoteDirect Link to This Post
no problem, just want to make sure they get there in one piece, had too many parts damaged in shipping from Ebay
edit: anyone else not seeing the pictures?
[This message has been edited by AL68 (edited 02-25-2017).]
BigB
Report this Post03-05-2017 04:29 PM Click Here to See the Profile for BigBSend a Private Message to BigBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Greetings. Interested in 88 rear sway bar end brackets which attach to the bottom of the strut. Please let me know.
[This message has been edited by BigB (edited 03-05-2017).]
AL68
Report this Post03-07-2017 08:59 PM Click Here to See the Profile for AL68Send a Private Message to AL68Edit/Delete MessageReply w/QuoteDirect Link to This Post
all the suspension parts from the car are already gone, sorry.
Silicoan86
Report this Post03-08-2017 01:37 PM Click Here to See the Profile for Silicoan86Send a Private Message to Silicoan86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Any chance I could get you to ship those '88 lace wheels up to MN?
AL68
Report this Post03-10-2017 08:00 PM Click Here to See the Profile for AL68Send a Private Message to AL68Edit/Delete MessageReply w/QuoteDirect Link to This Post
sorry, sold them last weekend at a swap meet
PM me if need/interested in anything instead of posting here for now, working on buying house & might not be here every day
