  The Mall
  Fiero parts CHEAP, cleaning house(and a few 3800 swap parts)
Fiero parts CHEAP, cleaning house(and a few 3800 swap parts) by Threedog
Started on: 05-12-2017 02:04 PM
Replies: 17 (815 views)
Last post by: Threedog on 05-30-2017 01:25 PM
Threedog
Total ratings: 61
Report this Post05-12-2017 02:04 PM Click Here to See the Profile for ThreedogSend a Private Message to ThreedogEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am moving soon, and I don't need a lot of this stuff(really, I don't need any of it). So stuff is gonna go for cheap. If you'd like, I can provide more pictures. Pickup location for big stuff is Ann Arbor, Michigan
Overview picture is here, everything except the spare decklid is for sale.
Specific stuff..
Wheels and tires. Four 15inch stock(GT?) Wheels, painted back with minor chips. They have tires with tread that hold air, but they are old(5-10 years I think). I used them as the tires the car sat on for the winter. -100$ OBO(Pickup only)
Decklid vents -$20 each, $30 for the pair(I can ship these for relatively cheap!)
Painted Wiper Arms(86 GT) -$15
Spare Tire Jack - $10
Passenger side mirror housing (non power) -$20
Bracket that goes under the fuel tank-$10
3800 SWAP Parts
Gauges(oil pressure and voltage), with bracket that fits fiero GT location, works - $30
Oil filter adapter for 3800 - $15
3800 Alternator with the "long" arm. Works well but does have a slight bearing noise - $20
Misc mirror stuff. Tell me what you want and I will see if I have it.
I know there are mirrors, brackets, power motors, and non power stuff in this box.
84-86 Headlight Lower Benzels -$10 for both
GT dog bone -$10
Metal Exhaust guards for GT bumper -$5 each
E-brake cable(never used) -$15
Decklid vent brackets(GT) -$10 each 15 for the pair
Air Filter top -$10
Rear(?) brake dust shields, one I think is slightly warped -$10 for the pair
Radiator fan(out of a 86 or 87 GT) works(I think) -$25(Pick up only)
Front brackets and calipers(used, worked when used) -$25 for both
Blower motor, works(used) -$10
Front compartment thing(covers the A/C and blower motor) -$15
HVAC/Radio center console piece(warping, has four small holes drilled into the lower passenger side) -$15
Center console, dirty, minor warping -$30(pick up only)
Passenger side inner door panel, grey. the top rightmost mounting point ripped off, but other than that its in good condition. - $40 OBO(Pickup only)
Two One Fiero 2.8 Computers(86 and 87 GT 5-Speed), working - $15 each
This kinda cool shifter knob, fits on the GT 4-Speed handle(doesn't fit on the five speed) - $15
A/C Box(out of an 86 GT) - $10
Non Cruise control turn signal level - $5
Gauge plates. Good condition, one has the plexiglass glued to the back of it though(no idea why but I can provide more pics if you want it) -$10 each
Power windows/mirror bracket. Power Mirror Switch NOT included -$10
Console vents -$5 each
Lights/dimmer switches and bracket(works) -$10 each
Lights switch(works) -$5
HVAC controls(works) -$10
80 MPH Gauge cluster. Speedo and tach def work, not so sure about the fuel gauge/temp gauge -$40
[Not Pictured] Trunk release/Rear Defrost switch and bracket -$10
[Not Pictured] Power Mirror Switches -$5 Each
Seatbelts -$15 each or $20 for the pair
Seatbelt..latches(??) -$5
Passenger side B piller speaker mount -$5
Cig lighter bracket -$5 each(I have like two or three of them)
Cig lighter(works) -$5
Radio/HVAC frame, minor chips on the top right and bottom left -$10
4 Speed shifter boot(out of an 87), good condition -$20
Emergency brake boot(tear on the inside "elbow" of the boot) -$10
Third brake light housing -$10
Radio out of an 87 GT(with the better audio package), works -$20
Dash board, has damage around the speaker covers and only comes with one speaker cover -$40(Pick up only)
Side vents on the dashboard, good condition -$10 each or 15 for the pair
Broken center console "frame" -$15(pick up only)
All the metal brackets for the frame -$10
Gauge/dash housing, four small holes drilled into the drivers side, -$20(Pick up only)
Trim piece for under the steering wheel -$10
Shift Boot trim piece(warped a bit) -$10
Send me a PM.
Pick up location is Ann Arbor, MI(Southeast Michigan)
[This message has been edited by Threedog (edited 06-01-2017).]
Threedog
Total ratings: 61
Report this Post05-12-2017 02:32 PM Click Here to See the Profile for ThreedogSend a Private Message to ThreedogEdit/Delete MessageReply w/QuoteDirect Link to This Post
I also have 13.3 feet(160 inches) of 3/8" aluminium fuel line. -$20
Threedog
Total ratings: 61
Report this Post05-12-2017 04:49 PM Click Here to See the Profile for ThreedogSend a Private Message to ThreedogEdit/Delete MessageReply w/QuoteDirect Link to This Post
Threedog
Member since Jun 2013
Found more stuff! This should be it, although I may be selling a door panel pretty soon here..
3Inch intake tube. It was 2.5 feet, but I cut it to 1.5 feet, this is the left over ~ 1 foot -$10
Fiero Mud Flaps. These were installed on the front of my first Fiero, they are pretty beat up. -$5
GT Gauge set. Works, could use new Plexiglas cover. Good condition. $50
Extra wiring/Plugs
I have all the transmission wiring and plugs from a 96 3800 Regal. Plus, a chopped rear light wiring harness off an 87 Fiero GT
[This message has been edited by Threedog (edited 05-12-2017).]
notwohorns
Report this Post05-12-2017 07:52 PM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent. Question about the '86 computer and HVAC contorls
Threedog
Total ratings: 61
Report this Post05-13-2017 10:58 AM Click Here to See the Profile for ThreedogSend a Private Message to ThreedogEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump for the morning crowd
lorennerol
Report this Post05-13-2017 12:53 PM Click Here to See the Profile for lorennerolSend a Private Message to lorennerolEdit/Delete MessageReply w/QuoteDirect Link to This Post
In for the seat belts as long as they are functional and clean.
Derrick
Report this Post05-14-2017 12:17 AM Click Here to See the Profile for DerrickSend a Private Message to DerrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
What 3800 swap parts do you have? I need the bracket the coils sit on.
Threedog
Total ratings: 61
Report this Post05-14-2017 09:14 PM Click Here to See the Profile for ThreedogSend a Private Message to ThreedogEdit/Delete MessageReply w/QuoteDirect Link to This Post
No Bracket unfortunately.
Alternatively you could buy new custom wires then just bolt your coilpack to the firewall, like I did.
Threedog
Total ratings: 61
Report this Post05-16-2017 02:29 PM Click Here to See the Profile for ThreedogSend a Private Message to ThreedogEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
handymanpat
Report this Post05-17-2017 10:01 PM Click Here to See the Profile for handymanpatSend a Private Message to handymanpatEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got the parts today!
Nice, clean parts. Shipped fast and packaged great!
Thanks
Threedog
Total ratings: 61
Report this Post05-19-2017 03:44 PM Click Here to See the Profile for ThreedogSend a Private Message to ThreedogEdit/Delete MessageReply w/QuoteDirect Link to This Post
Found more stuff!
I have all of the round trim needed for a GT, with the exception of the sidemarkers.(no mounting hardware included) - $40 for all of it.
Wiper arms - $10 for both
If someone is interested in LED rear sidemarkers, I might be willing to let a pair go for $60(the right side will have a crack in it).
Threedog
Total ratings: 61
Report this Post05-26-2017 03:50 PM Click Here to See the Profile for ThreedogSend a Private Message to ThreedogEdit/Delete MessageReply w/QuoteDirect Link to This Post
Memorial day bump.
CrazyDragn
Report this Post05-26-2017 04:00 PM Click Here to See the Profile for CrazyDragnSend a Private Message to CrazyDragnEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you happen to have any parts that are for the sunroof?
I need the parts that attach to the AFT of the top of the ceiling (the part that holds the sunroof down to lock......
Notchie to Fast Back Conversion
After Market Steering Wheel Conversion
Threedog
Total ratings: 61
Report this Post05-28-2017 08:39 PM Click Here to See the Profile for ThreedogSend a Private Message to ThreedogEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unfortunately I do not. All I have from the sunroof is the wind breaker that goes in the front compartment.
h.d.fire
Report this Post05-28-2017 09:55 PM Click Here to See the Profile for h.d.fireSend a Private Message to h.d.fireEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent on the aluminum fuel line.
yamaha94
Report this Post05-29-2017 09:48 AM Click Here to See the Profile for yamaha94Send a Private Message to yamaha94Edit/Delete MessageReply w/QuoteDirect Link to This Post
Emailed about the Radio thanks
1fast2m4
Report this Post05-29-2017 10:39 AM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
I didn't see one but I thought I'd ask, do you have a Auto shift cable bracket for the TH125?
Threedog
Total ratings: 61
Report this Post05-30-2017 01:25 PM Click Here to See the Profile for ThreedogSend a Private Message to ThreedogEdit/Delete MessageReply w/QuoteDirect Link to This Post
I do not, sorry.
