  The Mall
  1988 2M4 Roller, Rebuilt/Modded Duke
1988 2M4 Roller, Rebuilt/Modded Duke by regal7point5
Started on: 07-15-2017 07:06 PM
Replies: 23 (977 views)
Last post by: regal7point5 on 10-14-2017 07:34 AM
regal7point5
Report this Post07-15-2017 07:06 PM Click Here to See the Profile for regal7point5Send a Private Message to regal7point5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Long story, but testing the waters and considering bailing on my project. Bought the car as a running daily driver, but the engine leaked bad and needed a clutch so out came the engine. Engine has been fully rebuilt and 95% of all needed parts cleaned and collected and motor is on the engine stand ready to go back in. I cannot find the unique Balancer that an 88 takes and life changes have forced me to reconsider finishing. I would prefer to sell with the motor but would consider selling the car and engine separately. Last resort is a "part out". Feel free to ask any questions. The car has no rust underneath and appears to have been well maintained through its life. I can post pictures of the engine tomorrow. I have the original wheels as well.
Here is what has been done in the past year with 0 miles or nearly 0 miles since work...
-rebuilt steering rack with Rodney's bronze bushing
-new inner and outer tie rods
-new poly swaybar endlinks
-new sunroof seal
-new inner and outer dew wipes
-new rear suspension bushings
-new brake master cylinder
Engine:
-.030 Speedpro coated hypereutectic pistons from SBC, 9.25 to 1 calculated compression
-crank and rods resized to .010
-rotating assembly balanced, flywheel resurfaced
-Crower Cams hydraulic roller regrind (can pull the cam card if needed for specs)
-Ported head (bowl cleanup, knife-edged guides, port matched runners)
-new valves, keepers, head bolts, rocker arms, roller lifters, pushrods, timing gear, timing gear cover, seals, gaskets, etc
-long block is assembled less likely pump/Balancer
I have too much money in this, but wanted to do things right with the engine. Would like to get $1500 for the car and $1200 for the engine...or $2500 for everything. Located in Richmond VA area.
https://www.flickr.com/phot...n/dateposted-public/
Total ratings: 461
Report this Post07-15-2017 08:43 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice!
GLWS!
I was actually thinking about doing something similar, except that I was going to base it on an 87 block, so that I didn't have to use the odd 88 balancer.
I was thinking about using a cast iron SD head, but it sounds like you've done all the stuff to make your head flow properly.
And the car itself looks great! MUCH nicer than mine.
regal7point5
Report this Post07-16-2017 12:15 PM Click Here to See the Profile for regal7point5Send a Private Message to regal7point5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Raydar! I hate the thought of parting with it but with 4 small kiddos, it is going nowhere fast and kids are expensive....awesome but expensive!
[This message has been edited by regal7point5 (edited 07-16-2017).]
Total ratings: 465
Report this Post07-16-2017 02:05 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just so you know, Flickr images can be directly embedded within your post. When choosing image size, just don't go any wider than 1024 pixels for use in this particular forum.
[This message has been edited by Patrick (edited 07-16-2017).]
regal7point5
Report this Post07-18-2017 09:29 PM Click Here to See the Profile for regal7point5Send a Private Message to regal7point5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Still available...and as always, feel free to make an offer. If I don't sell it here in the next couple weeks, it is off to Craigslist.
[This message has been edited by regal7point5 (edited 07-18-2017).]
regal7point5
Report this Post07-22-2017 12:25 PM Click Here to See the Profile for regal7point5Send a Private Message to regal7point5Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just loaded a bunch of engine pictures to my Flickr page...instead of bogging things down, the link below is to my Flickr page.
The pictures under the car is from before all the work was done. Also, I only took pictures of the head before pulling it apart, and after it was put back on, so unfortunately can't show off the bulk of the port work.
https://www.flickr.com/photos/30128663@N06/
regal7point5
Report this Post07-25-2017 06:23 PM Click Here to See the Profile for regal7point5Send a Private Message to regal7point5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Somebody make an offer before it dies on Craigslist!
Spektrum-87GT
Report this Post07-26-2017 01:40 AM Click Here to See the Profile for Spektrum-87GTSend a Private Message to Spektrum-87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry, edit.
[This message has been edited by Spektrum-87GT (edited 07-26-2017).]
Total ratings: 461
Report this Post07-26-2017 08:17 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
You probably don't much care about this, but I read your post in the other thread.
The 87 block does seem to use a similar crank to the 88. I forgot all about the reluctor wheel and the crank position sensor. Rockauto shows the same castings (87 to 88) in several instances. I just learned something.
regal7point5
Report this Post07-30-2017 04:44 PM Click Here to See the Profile for regal7point5Send a Private Message to regal7point5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Still looking for a home...make an offer!
Total ratings: 461
Report this Post07-30-2017 08:14 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I looked at the cam specs, vs stock. It appears to be fairly mild. ~10 degrees more duration, and a few hundredths more lift.
Of course, anything would be an improvement.
Of course that doesn't take into account the compression bump, and the porting. Or the balancing, for that matter.
Bottom line... based upon your "best guestimate", how much power do you expect the engine would be capable of?
Thanks!
[This message has been edited by Raydar (edited 07-30-2017).]
regal7point5
Report this Post07-31-2017 10:26 PM Click Here to See the Profile for regal7point5Send a Private Message to regal7point5Edit/Delete MessageReply w/QuoteDirect Link to This Post
From everything I have read, I would say it should make a solid 125 to 130hp and shouldn't level off after 4000rpm like the stock engine. You are correct on the cam, a little more duration and lift, and was ground to still work with the stock computer.
Total ratings: 461
Report this Post08-01-2017 05:46 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks. Still thinking.
regal7point5
Report this Post08-05-2017 07:52 AM Click Here to See the Profile for regal7point5Send a Private Message to regal7point5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Another week on here then off to Craigslist!
regal7point5
Report this Post08-08-2017 07:05 AM Click Here to See the Profile for regal7point5Send a Private Message to regal7point5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Price drop to $2200 for everything!
regal7point5
Report this Post08-11-2017 09:04 PM Click Here to See the Profile for regal7point5Send a Private Message to regal7point5Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have lost my mind...$2000, for it all. Goes on Craigslist next week.
regal7point5
Report this Post08-17-2017 09:21 PM Click Here to See the Profile for regal7point5Send a Private Message to regal7point5Edit/Delete MessageReply w/QuoteDirect Link to This Post
regal7point5
Report this Post08-22-2017 07:37 AM Click Here to See the Profile for regal7point5Send a Private Message to regal7point5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
regal7point5
Report this Post08-27-2017 08:48 PM Click Here to See the Profile for regal7point5Send a Private Message to regal7point5Edit/Delete MessageReply w/QuoteDirect Link to This Post
$1800 for a member here.
KurtAKX
Total ratings: 128
Report this Post08-28-2017 08:07 AM Click Here to See the Profile for KurtAKXSend a Private Message to KurtAKXEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks!
You have his cam card?
Total ratings: 461
Report this Post08-28-2017 05:00 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
It was visible through one of the links above.
https://www.flickr.com/phot...663@N06/35277270573/
regal7point5
Report this Post09-20-2017 06:32 AM Click Here to See the Profile for regal7point5Send a Private Message to regal7point5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Still have this for sale...open to offers.
regal7point5
Report this Post10-05-2017 08:45 PM Click Here to See the Profile for regal7point5Send a Private Message to regal7point5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Still open to offers...trying to move and need cash. Worst I can say is "no thanks".
regal7point5
Report this Post10-14-2017 07:34 AM Click Here to See the Profile for regal7point5Send a Private Message to regal7point5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Lots of good parts in this...and moving soon. $1500
