  The Mall
  Car Sold - Cleaning out the garage, Performance parts for sale
Car Sold - Cleaning out the garage, Performance parts for sale by Bridgetown
Started on: 08-14-2017 12:36 AM
Replies: 28 (1681 views)
Last post by: ron768 on 11-28-2017 01:11 PM
Bridgetown
Report this Post08-14-2017 12:36 AM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
Some good stuff here needs a new home.
All prices are CAD dollars
All prices do not include shipping
Paypal only (No Gift transactions)
Prices negotiable, money talks, no dibs.
Rotrex C30-94 Supercharger system - SOLD
I would like to sell this as a package, but I could separate parts if so desired. Everything you need to supercharge your car. Link to info on the supercharger here: http://www.rotrex.com/media...et%20C30%20Range_pdf
C30-94 Rotrex Charger
Oil reservoir and 2 bottles of traction fluid:
Oil cooler and fittings:
Various charge pipe fittings:
2 BAR GM map sensor
Street Dreams lowering spindles with aluminum hubs (no bearings) - $800
Brand new never installed.
Prothane control arm Bushing kit Front 84-87 - SOLD
Prothane trailing link bushing kit Rear 88 - SOLD
Both new in original boxes
Rear 12" springs for coilover conversion 275# rate (not Eibachs, purchased from Fiero Addiction) - SOLD
Adjustable brake proportioning valve - SOLD
The 13/16" / 21mm (early model) adapter allows you to add upto 3 times more rear brake bias
Info:https://www.fiero.nl/forum/Forum4/HTML/064690.html
Fiero Fiberglass tapered door mouldings - SOLD
New, never installed.
TCE external crank trigger kit - SOLD
Allows you to use the early model crank sensor on late model 60 degree v6's (if you don't know what it is you probably don't need it)
Moates BURN2 chip burner - SOLD
Used maybe 2 times
OBD2 All in one scan tool - SOLD
Barely used
'7730 ECU with WOT-TECH 3400 swap chip - $100
'7730 ECU unaltered stock ecu - SOLD
Allstar coil spring adjusters - SOLD
[This message has been edited by Bridgetown (edited 11-30-2017).]
jjd2296
Report this Post08-14-2017 07:01 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
How does that supercharger work on a fiero??
CJB118
Report this Post08-14-2017 10:32 AM Click Here to See the Profile for CJB118Send a Private Message to CJB118Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent, re spring adjusters and prothane kit.
THANK YOU for giving the community all the relevant info on your for-sale parts. This is one of the best postings I have seen here in the mall section. Time spent creating a posting that includes clear photographs and descriptions, WITH relevant part numbers and application info, will be rewarded when you avoid having to send multiple messages and PMs back and forth with those same questions and answers. +1
[This message has been edited by CJB118 (edited 08-14-2017).]
tshark
Total ratings: 68
Report this Post08-14-2017 11:07 AM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm interested in the proportioning valve, if it'll fit an '88.
Inferno
Report this Post08-14-2017 02:20 PM Click Here to See the Profile for InfernoSend a Private Message to InfernoEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent about the Motes and the OBD2 All in 1
Bridgetown
Report this Post08-14-2017 04:17 PM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM replied
Bridgetown
Report this Post08-14-2017 05:09 PM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bridgetown
Member since Feb 2007
I don't believe it will fit the '88s. Mine is the 21mm unit
Bridgetown
Report this Post08-14-2017 05:12 PM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bridgetown
PM replied
Bridgetown
Report this Post08-14-2017 05:17 PM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bridgetown
PM replied
tshark
Total ratings: 68
Report this Post08-14-2017 08:14 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
[B]Originally posted by Bridgetown:[/B
I think you're right. Thanks, anyway.
Luke
Report this Post08-15-2017 09:59 PM Click Here to See the Profile for LukeClick Here to visit Luke's HomePageSend a Private Message to LukeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pm sent about tapered gfx and crank trigger
Domtech
Report this Post08-15-2017 10:43 PM Click Here to See the Profile for DomtechSend a Private Message to DomtechEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have an 88, but I'm interested in it for reverse engineering purposes since they have been unavailable for a while.
Bridgetown
Report this Post08-16-2017 08:47 PM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
That would be a great service to the Fiero community. Let me know if you want to purchase
ericjon262
Total ratings: 67
Report this Post08-17-2017 04:55 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent.
"The day I tried to live, I stole a thousand beggars' change and gave it to the rich."
Bridgetown
Report this Post08-23-2017 02:05 PM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
Only a few items left
sluppy123
Report this Post08-24-2017 03:21 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent.
CJB118
Report this Post08-24-2017 04:25 PM Click Here to See the Profile for CJB118Send a Private Message to CJB118Edit/Delete MessageReply w/QuoteDirect Link to This Post
Parts received, thank you.
Bridgetown
Report this Post08-24-2017 05:03 PM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
All PMs replied
Bridgetown
Report this Post08-29-2017 02:05 PM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Still some good stuff available
Bridgetown
Report this Post09-06-2017 08:11 PM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
Only a few items left!
[This message has been edited by Bridgetown (edited 09-06-2017).]
Bridgetown
Report this Post11-15-2017 11:22 PM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump.
Last chance at the drop spindles before it goes on eBay.
I would really like to see this go to another PFF member.
ron768
Report this Post11-16-2017 01:18 AM Click Here to See the Profile for ron768Send a Private Message to ron768Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
Danyel
Total ratings: 171
Report this Post11-16-2017 12:40 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump.
contact PFF member KEV he was looking for drop spindles
Danyel
Black Widow Build Thread 2007 - 2014 Tylers Toy
My Low Profile Buckets for sale My LED Sidemarkers for sale
ron768
Report this Post11-22-2017 08:39 AM Click Here to See the Profile for ron768Send a Private Message to ron768Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
Bridgetown
Report this Post11-23-2017 09:49 PM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM replied
Bridgetown
Report this Post11-23-2017 11:09 PM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bridgetown
PM replied
Bridgetown
Report this Post11-24-2017 04:00 PM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
Black Friday Bump!
Just the '7730 ECU's and the Drop Spindles left.
Today only $750 on the Drop Spindles!!!
[This message has been edited by Bridgetown (edited 11-24-2017).]
ron768
Report this Post11-24-2017 11:51 PM Click Here to See the Profile for ron768Send a Private Message to ron768Edit/Delete MessageReply w/QuoteDirect Link to This Post
Pm sent
ron768
Report this Post11-28-2017 01:11 PM Click Here to See the Profile for ron768Send a Private Message to ron768Edit/Delete MessageReply w/QuoteDirect Link to This Post
bump to get attention
