  The Mall
  Parts for Sale - More to be Added Periodically (Page 1)
Parts for Sale - More to be Added Periodically by hye_4_life
Started on: 08-21-2017 01:59 AM
Replies: 59 (2712 views)
Last post by: hye_4_life on 07-14-2019 08:07 PM
hye_4_life
Report this Post08-21-2017 01:59 AM Click Here to See the Profile for hye_4_lifeSend a Private Message to hye_4_lifeEdit/Delete MessageReply w/QuoteDirect Link to This Post
***With most other projects completed, I will be focusing on this thread. There will be plenty of parts added regularly.***
Trying to get a little more organized so it's time to clear out a few things. Parts are also listed on eBay and more things will be added as I get to them.
C4 Corvette Front Non-Heavy Duty Rotors - Left and Right - Drilled and Slotted - Black Zinc Coated - New, Unused - $100
Used Eibach [Rear] Lowering Springs with Isolators - $100
Used ['84-'87] Eibach Front & Rear Lowering Springs - $200
Used '84-'87 Front and Rear Summit Racing Drilled and Slotted Rotors with Front Spindles - The rotors are from Summit Racing and they're their brand. They were only used for several thousand miles before being swapped out for a 12" Corvette conversion. Installing the rear rotors will require the removal of the rear dust shields or bending them to clear the rotors. Front rotors come assembled with spindles but the dust cap is not included - $100
Used '84-'87 Rear Uprights - $50
Used Steel Clutch Pedal - $25
Used Pair of Door Handle Trim - Non-power door lock, door handle trim. Second picture shows two small cracks on driver's side piece - $10
Used Instrument Trim - Plain - $10
Used '84-'87 Front Sway Bar End Links - $10
Used Headlight Switch Trim - $5
Used Passenger's Side Interior Door Handle Trim - Power door lock, door handle trim - $5
New Carbon Fiber Dash Trim Overlay - I believe this kit is for a manual transmission - $200
Used Instrument Trim - Dot Matrix - $20
Used V6 Coolant Crossover Pipe - $20 - I believe this is from an '85-'87 manual transmission car
Used Spare Tire Hardware - $5
Used Passenger Side HVAC Vent Frame - $5
Used Passenger's Side Door Handle Trim - $5 - Manual door locks
Used '84-'87 Passenger's Side Rear Upright - $20 - No Hub
Used Set of Door Hinges - $50
NOS Pair of GT Quater Windows - $1000 - Sold
'86-'87 Tan Armrests - $20 - $10 - Sold
Sluppy123's '84-'87 Rear Caliper Brackets for 12" Corvette Upgrade - $100 - $80 - Sold
Brand New Prothane '84-'87 Front Sway Bar End Links - $10 - Sold
Aftermarket Center Caps - Never used but have some scuffs from storage - $15 - Sold
Fiero Store (I think?) Glove Box '86-'87 Tan (I think) - The OE Fiero style door latch works great. The liner is well worn and could use a replacement, headliner material would be a great, cheap alternative. It has a few minor blemishes on the leading edge and a couple more on the bottom right corner, near where passengers bumper their knee as they enter/exit the car. Mounting hardware is not included, will need four moderately long bolts, nuts, and four oversized washers to distribute the weight - $150 - Sold
Mr Mikes Dark Grey Padded Armrest Cover - New, Never Used - $25 - Sold
Performance Sound Stereo Wiring Harness - $25 - Sold
Manual Mirror Adjustment Bezel - $5 - Sold
Rear Window Louver - Sold
Used V6 Fuel System - This was removed from a running car several years ago. Includes sending unit, flex lines, two sets of hard lines, and the fuel rail with injectors. The locking tab on the yellow connector on the sending unit broke off while taking the picture as can be seen in the picture - $50 - Sold
Used Aero Bumper License Plate Bracket - Has a crack on the top right corner as can be seen in the picture - $25 - Sold
Used V6 Valve Covers - $25 - Sold
Used Bumper Pads - Pretty sure they're from a GT but not sure if they're fronts or rears - $5 - Sold
Used Lug Nut Covers - Set of 5 - $5 - Sold
T-Top Conversion - $600 - Sold
Rear View Mirror with Metal Mounting Tab - Has some spotting down the center of the mirror, second image shows it a little better - $10 - $5 - Sold
Used/Rebuilt '84-'87 Calipers - These were only used for several thousand miles before being swapped out for a 12" Corvette conversion. The fronts were rebuilt with Raybestos kits and the rears were purchased rebuilt from the Fiero Store. They were painted red to add just that little extra bit of stopping power. The brake lines were replaced with Raybestos units at the same time - $100 - Sold
[This message has been edited by hye_4_life (edited 05-27-2020).]
Fiero Vice
Report this Post08-21-2017 06:24 AM Click Here to See the Profile for Fiero ViceSend a Private Message to Fiero ViceEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent. Thanks.
[This message has been edited by Fiero Vice (edited 08-21-2017).]
hye_4_life
Report this Post08-22-2017 12:26 AM Click Here to See the Profile for hye_4_lifeSend a Private Message to hye_4_lifeEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by hye_4_life (edited 08-23-2017).]
viperine
Report this Post08-22-2017 01:13 AM Click Here to See the Profile for viperineSend a Private Message to viperineEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pm sent on center caps.
busa_powered
Report this Post08-22-2017 09:52 AM Click Here to See the Profile for busa_poweredSend a Private Message to busa_poweredEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good luck with the 1000 dollar sail panels
GMann20
Report this Post08-23-2017 01:22 AM Click Here to See the Profile for GMann20Send a Private Message to GMann20Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey! Its for the pair of quarter windows? >I mean $1000.00 has a nice ring. IMBW
G L Mann Oklahoma City, Oklahoma
hye_4_life
Report this Post08-24-2017 12:38 AM Click Here to See the Profile for hye_4_lifeSend a Private Message to hye_4_lifeEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by hye_4_life (edited 04-19-2020).]
hye_4_life
Report this Post09-05-2017 01:33 AM Click Here to See the Profile for hye_4_lifeSend a Private Message to hye_4_lifeEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by hye_4_life (edited 09-07-2017).]
hye_4_life
Report this Post09-05-2017 01:37 AM Click Here to See the Profile for hye_4_lifeSend a Private Message to hye_4_lifeEdit/Delete MessageReply w/QuoteDirect Link to This Post
hye_4_life
Member since Jul 2008
More Pictures - Sold
jjd2296
Report this Post09-05-2017 08:32 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
Pm sent for glove box. Don't want to miss out on this.
jjd2296
Report this Post09-05-2017 09:53 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
jjd2296
Member since Jan 2016
Still waiting for a reply on the glove box. Money in hand.
jjd2296
Report this Post09-06-2017 01:53 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
Heard the glove box is posted on eBay but I can't find the link??
jjd2296
Report this Post09-06-2017 03:20 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
jjd2296
Found link! and you wont ship to Canada?? us canucks buy half the stuff posted here! how can I get this??
hye_4_life
Report this Post09-06-2017 08:44 PM Click Here to See the Profile for hye_4_lifeSend a Private Message to hye_4_lifeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry for the late reply, work and school consume a significant majority of my time. Anywho, all PMs have been replied to.
jjd2296
Report this Post09-06-2017 08:58 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
THNX!! PM sent waiting your reply!!
jjd2296
Report this Post09-06-2017 09:42 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
jjd2296
[This message has been edited by jjd2296 (edited 09-06-2017).]
jjd2296
Report this Post09-07-2017 09:17 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
Payment sent for the tan glove box!!
jjd2296
Report this Post09-07-2017 09:19 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
jjd2296
Pm sent for the end links as well.
hye_4_life
Report this Post09-08-2017 10:48 PM Click Here to See the Profile for hye_4_lifeSend a Private Message to hye_4_lifeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump for updated prices
hye_4_life
Report this Post09-10-2017 05:46 PM Click Here to See the Profile for hye_4_lifeSend a Private Message to hye_4_lifeEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by hye_4_life (edited 07-15-2019).]
hye_4_life
Report this Post09-10-2017 05:47 PM Click Here to See the Profile for hye_4_lifeSend a Private Message to hye_4_lifeEdit/Delete MessageReply w/QuoteDirect Link to This Post
hye_4_life
jjd2296
Report this Post09-10-2017 06:58 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
Pm sent on springs !
L.I. Fieros
Report this Post09-11-2017 09:50 PM Click Here to See the Profile for L.I. FierosSend a Private Message to L.I. FierosEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent about the performance sound wiring harness!
GMann20
Report this Post09-20-2017 01:55 PM Click Here to See the Profile for GMann20Send a Private Message to GMann20Edit/Delete MessageReply w/QuoteDirect Link to This Post
Great transaction and super communication. Thank you very much.
jjd2296
Report this Post09-20-2017 09:18 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got mine today too great!!
hye_4_life
Report this Post09-29-2017 03:48 AM Click Here to See the Profile for hye_4_lifeSend a Private Message to hye_4_lifeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fiero Vice
Report this Post10-02-2017 12:57 AM Click Here to See the Profile for Fiero ViceSend a Private Message to Fiero ViceEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got my package the other day! Great seller! Excellent communication! Would do business again! Thank you!
GMann20
Report this Post10-02-2017 11:30 AM Click Here to See the Profile for GMann20Send a Private Message to GMann20Edit/Delete MessageReply w/QuoteDirect Link to This Post
Delivered and installed. Looks perfect, brand new.
Thanks for a very pleasant transaction and fast shipping.
L.I. Fieros
Report this Post10-11-2017 01:42 PM Click Here to See the Profile for L.I. FierosSend a Private Message to L.I. FierosEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got my stuff, thanks! Great doing business with you! Positive feedback left.
Phirewire
Report this Post10-11-2017 06:07 PM Click Here to See the Profile for PhirewireSend a Private Message to PhirewireEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM Sent
hye_4_life
Report this Post11-18-2018 02:57 AM Click Here to See the Profile for hye_4_lifeSend a Private Message to hye_4_lifeEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by hye_4_life (edited 04-12-2020).]
hye_4_life
Report this Post11-18-2018 03:04 AM Click Here to See the Profile for hye_4_lifeSend a Private Message to hye_4_lifeEdit/Delete MessageReply w/QuoteDirect Link to This Post
hye_4_life
Originally posted by hye_4_life:
T-Top Conversion - Appears to be pretty complete. It's a complete roof from a T-Top car though I'm not sure what year or trim it's from, this was how I bought it. It comes with the glass but no keys for them, it also comes with the bags for the glass as well as a pair of reproduction P seals I'd purchased from FieroParts.com's thread. Unfortunately, I don't have the means to ship this so it will have to be picked up from Fresno, CA - $600
Evidently, I noticed I'd left some plastic trim out of the pictures. I'll take pictures of those and add them later today. Also, it appears I may have the keys after all. I'll confirm that later today as well.
A_Pegasi
Report this Post11-25-2018 12:42 PM Click Here to See the Profile for A_PegasiSend a Private Message to A_PegasiEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent regarding the door handles.
hye_4_life
Report this Post06-29-2019 02:03 AM Click Here to See the Profile for hye_4_lifeSend a Private Message to hye_4_lifeEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by hye_4_life (edited 06-29-2019).]
hye_4_life
Report this Post06-29-2019 02:16 AM Click Here to See the Profile for hye_4_lifeSend a Private Message to hye_4_lifeEdit/Delete MessageReply w/QuoteDirect Link to This Post
hye_4_life
hye_4_life
Report this Post06-29-2019 02:58 AM Click Here to See the Profile for hye_4_lifeSend a Private Message to hye_4_lifeEdit/Delete MessageReply w/QuoteDirect Link to This Post
hye_4_life
hye_4_life
Report this Post06-29-2019 08:22 PM Click Here to See the Profile for hye_4_lifeSend a Private Message to hye_4_lifeEdit/Delete MessageReply w/QuoteDirect Link to This Post
hye_4_life
[This message has been edited by hye_4_life (edited 07-14-2019).]
hye_4_life
Report this Post06-29-2019 08:32 PM Click Here to See the Profile for hye_4_lifeSend a Private Message to hye_4_lifeEdit/Delete MessageReply w/QuoteDirect Link to This Post
hye_4_life
hye_4_life
Report this Post06-29-2019 08:39 PM Click Here to See the Profile for hye_4_lifeSend a Private Message to hye_4_lifeEdit/Delete MessageReply w/QuoteDirect Link to This Post
hye_4_life
[This message has been edited by hye_4_life (edited 04-02-2020).]
hye_4_life
Report this Post06-29-2019 09:07 PM Click Here to See the Profile for hye_4_lifeSend a Private Message to hye_4_lifeEdit/Delete MessageReply w/QuoteDirect Link to This Post
hye_4_life
