  The Mall
  Big bore throttle body
Big bore throttle body by jjd2296
Started on: 02-02-2019 02:07 PM
Replies: 7 (603 views)
Last post by: Harold James Kie on 02-05-2019 07:36 PM
jjd2296
Report this Post02-02-2019 02:07 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone have one of the fiero Holley throttle bodies that have been bored out for sale?
Spoon
Total ratings: 61
Report this Post02-03-2019 09:11 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just curious, do you also need the bored out intake to match the bored throttle body?
Spoon
Report this Post02-04-2019 10:19 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If this is for a V6 the main restriction is the neck in the upper intake manifold . A larger throttle body won't give you much if any more horsepower by just increasing the V6 throttle body bore.
There was a special Holly throttle body made for the Duke but AFAIK it only fits the 87-88 engines. They are hard to come by but we see them for sale ever so often. If you are looking for more Duke power see here:
Iron Duke Resource Site
Mike Morris
Report this Post02-05-2019 09:24 AM Click Here to See the Profile for Mike MorrisSend a Private Message to Mike MorrisEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a spare V6 low mile Holley TB if anyone wants it for porting to keep down time to a minimum. Who else these days ports the V6 upper intake?
jjd2296
Report this Post02-05-2019 10:09 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
If someone has both for sale I would be interested.
Spoon
Harold James Kie
Report this Post02-05-2019 12:15 PM Click Here to See the Profile for Harold James KieSend a Private Message to Harold James KieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Several years back I read a book on performance tips that was meant to be applied to any intake system, most specifically carbs. I used the knowledge on my Holley and without actually increasing the diameter at the butterfly I streamlined it all the way through and even made a "airfoil" out of the butterfly and thinned the shaft/screws down to what seemed like a safe compromise. The article that I read showed that by feathering the leading and trailing edges of the butterfly it became more "slippery" and also if you were splitting hairs it gave a quicker throttle response. Note that the edges must be feathered on opposite sides - that is front "leading" edge is filed away in such a manner that it will not effect the butterfly in the closed position and same for the trailing edge. Does it help? Who knows, I am sure that there is some benefit as the book that I read from was influenced by trials on race cars running Webers etc. Anyway when I had to smog my Fiero in Ca I took it off, replaced the chip and got it through the DMV inspection but never put it back so if you want it make me an offer on it. I also did do port matching at the time but the manifold is still with the car.
jjd2296
Report this Post02-05-2019 02:20 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
Was it a noticeable difference? Did you feel the lag when you put the inmodified one back on? Now sure what it’s worth I’ll PM you
Harold James Kie
Report this Post02-05-2019 07:36 PM Click Here to See the Profile for Harold James KieSend a Private Message to Harold James KieEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is hard to say as I think that it did feel more responsive and a bit quicker but I never did any trials. I would guess, and this is only a guess, that it did add some power and maybe knocked some off the 0-60 times. I did a fair amount of street racing with my Fiero and I did well against cars that should have buried me. (I beat a 5.0 Mustang and a Porsche 911 but some of that was being quicker off the line) Often one modification will not help as much as if there are other upgrades to compliment the changes and I had a Hyper-Tech chip and a few other "tricks".
