For sale is a 6.5 Kicker CompCVT shallow mount subwoofer custom fitted into the stock under dash housing. The sub is rated at 150 watts RMS and 300 watts peak (4 ohm). As seen in the pics, I made an adapter from delrin plastic that was then bolted to the stock housing. There is silicone around the mating surfaces to ensure no air leaks. The adapter and sub housing are then wrapped in black suede. When installed under the dash, only about 1.5 inches of the suede is shown. Unless you know what you are looking for, you can't tell there is a subwoofer there. There is about one summer's worth of the occasional weekend drives on the sub. The bass output is a huge step up to the Tang Band sub (I had that one before this). If you are expecting the level of bass from a 10 inch sub, this isn't for you. It delivers a good amount of bass but is not over powering.
I also have a set of speaker plates as shown in the linked thread below. I made these plates using the template shown in the thread. The only difference is that I made mine out of 3/16" aluminum plate as I did not want to take the risk of cracking hardboard or stripping screw threads. If interested in these plates, please read the attached thread carefully as a cut to the dash stock speaker housing is required to fit the 5.25" component speaker/woofer. I will post a pic of my aluminum plates when I get a chance.
US$300 (CAD$400) takes both the sub/sub housing and speaker plates. Given the size of these items, I"m happy to ship at the buyer's expense.
Thank you for your interest.
https://www.fiero.nl/forum/Forum3/HTML/000080.html
Edit - 3/16" aluminum speaker plates shown.
[This message has been edited by Eau_Rouge (edited 04-10-2019).]
