  The Mall
  Fieroguru Performance 2019 Black Friday/Cyber Monday Sale 10% off 11/23 - 12/2
Fieroguru Performance 2019 Black Friday/Cyber Monday Sale 10% off 11/23 - 12/2 by fieroguru
Started on: 11-16-2019 03:55 PM
Replies: 9 (773 views)
Last post by: Fiero Vice on 12-07-2019 11:40 PM
Total ratings: 259
Report this Post11-16-2019 03:55 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
2019 Black Friday/Cyber Monday Sale – 10% off!
The sale will start 11/23/2019 and end the morning of the 12/03/2019. All prices are shipped within the U.S. There will be a shipping surcharge for any Canada or International shipments.
Preferred payment method is paypal, but I will accept personal checks and money orders, but they will need to clear before parts will be shipped.
Send me a PM or email @ fieroguruperformancellc@gmail.com and I will send you a paypal request.
13" Brake Kit for 88 Fieros:
https://www.fiero.nl/forum/Forum4/HTML/060122.html
Full kit w/ drilled/slotted rotors - $575
Hardware only kit (full kit w/o rotors) - $315
Lateral Link Relocation Brackets for rear of 88 Fieros: $315
https://www.fiero.nl/forum/Forum4/HTML/060635.html
Rear Coilover Kits for 84-88 Fieros:
https://www.fiero.nl/forum/Forum4/HTML/076627.html
Level 1 Coilover Kit: $100 with new strut hats, stainless steel hardware and bump stops
Level 2 Coilover Kit: $175 Everything in Level 1 + adjuster sleeves in your choice of color (Silver, Black, Blue and Red)
Level 3 Coilover Kit: $300 Everything in Level 2 + your choice of springs. Black or silver no cost option (Red, Blue, Yellow, etc. $40 additional). Also choice of spring rate, & length (I can assist with these selections).
Level 4 Coilover Kit: $535 Everything in Level 3 + KYB struts. Coilover kit ships fully assembled and ready for bolt-in install.
F40 shifter bracket, both cables & reverse lockout: $330
LS4/F40 starter bracket: $85
LS4 multi-port oil bypass plate (only fits LS4 oil pan, won't fit LS1/2/3 oil pans): $50.00
F40/F23 clutch line connector: $40
FieroMaster88
Total ratings: 168
Report this Post11-16-2019 11:42 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I need a brake upgrade for my 84 Fiero, hint hint. I already have the 13” brakes and lateral link relocation parts on my 88 and love them.
88 Coupe: 2.0L Turbo 4 Cylinder, W2A, T25 Turbo, water/meth injection
84 Indy #64: Restoration Project
84 IMSA wide body SE: 3800 Swap in progress
Total ratings: 259
Report this Post11-23-2019 02:44 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump!
ron768
Report this Post11-23-2019 11:02 PM Click Here to See the Profile for ron768Send a Private Message to ron768Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
Total ratings: 259
Report this Post11-24-2019 10:40 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by ron768:
PM sent
Replied.
RandomTask
Total ratings: 150
Report this Post11-25-2019 12:53 PM Click Here to See the Profile for RandomTaskSend a Private Message to RandomTaskEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are the prices advertised before or after discount?
Also, the F40 shift cables/adapter- does that work for -any- F40? Or only ones from specific models?
Thanks,
Total ratings: 259
Report this Post11-25-2019 01:13 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks,
All listed prices already have the discount applied. For example the list price for the 13" brake kit is $640 shipped in the US, it is listed above for $575.
The F40 kit will work with any G6 version and other F40s that use the 3 bolts to mount the shifter assembly to the transmission case. There are several 2 bolt flange versions out there as well and this kit will not work for those. I verify those details at time of ordering. Here is a picture of the 3 bolt setup.
Here is a picture of the 2 bolt setup:
Total ratings: 259
Report this Post11-29-2019 10:14 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
pcar
Report this Post11-29-2019 01:28 PM Click Here to See the Profile for pcarSend a Private Message to pcarEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent.
Fiero Vice
Report this Post12-07-2019 11:40 PM Click Here to See the Profile for Fiero ViceSend a Private Message to Fiero ViceEdit/Delete MessageReply w/QuoteDirect Link to This Post
Guru,
Once again, excellent products! Thank you for providing it to the Fiero community.
