  The Mall
  84-87 7075 brake swap front hubs
84-87 7075 brake swap front hubs by sluppy123
Started on: 02-13-2020 10:59 AM
Replies: 10 (1387 views)
Last post by: J60123 on 01-30-2023 01:33 AM
sluppy123
Report this Post02-13-2020 10:59 AM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have two sets of front brake swap hubs for sale. Stock 5x100mm bolt pattern. Rotor centering ring is turned to fit either the 12" C4 Corvette or 13" C5/6 Corvette front rotor. 7075 high strength aluminum powder coated black. 3lbs each vs 7+ lbs each for a modified cast iron hub. Dorman 54mm long wheel studs and bearing races are pressed in. Timken bearings and seals included. $400 shipped in the US outside the US buyer pays shipping.
I also stock the required adapters to do either brake swap.
jjd2296
Report this Post02-13-2020 05:40 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is a quality product. I bought a set and was very impressed.
pcar
Report this Post02-15-2020 08:44 AM Click Here to See the Profile for pcarSend a Private Message to pcarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Agreed, buy with confidence.
renderareason
Report this Post06-24-2020 08:16 AM Click Here to See the Profile for renderareasonSend a Private Message to renderareasonEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
renderareason
Report this Post07-21-2020 10:12 AM Click Here to See the Profile for renderareasonSend a Private Message to renderareasonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I received my hubs and they are impressive, very high quality. I cannot wait to get them installed.
I also purchased the Corvette brake adapters to complete my setup:
- Front C5 Corvette caliper adapters for use with C5 13" rotors (for 84-87 Fiero)
- Rear caliper adapters to move 88 Fiero Caliper out to fit 12" front C4 Corvette rotor (for 88 Fiero)
riley
Report this Post08-06-2020 11:41 AM Click Here to See the Profile for rileySend a Private Message to rileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
pm sent
Franked
Report this Post09-05-2020 10:06 AM Click Here to See the Profile for FrankedSend a Private Message to FrankedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you sell the re-drilled rotors for the 5x100mm pattern?
sluppy123
Report this Post09-05-2020 11:33 AM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes I can provide redrilled rotors. PM me what swap you are doing and I will get you a price.
Jlife
Report this Post01-17-2022 10:40 AM Click Here to See the Profile for JlifeSend a Private Message to JlifeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sluppy I misplaced my centering rings for my 1988 12 inch kit. Can you send me a new set.
Thank you.
kevin
Report this Post04-04-2022 09:39 PM Click Here to See the Profile for kevinSend a Private Message to kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
sluppy123,
I have a 1985 SE 5p V6. My Fiero has 17 inch wheels. I want to purchase your Corvette 13 inch conversion for my front brakes. How much will it cost me? I’m in California.
Cordially,
Kevin Sullivan
kevinsullivan@frontier.com
916-600-6482
J60123
Report this Post01-30-2023 01:33 AM Click Here to See the Profile for J60123Send a Private Message to J60123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Any chance a set of these hubs are available?
