  The Mall
  Looking to buy 4T60e Transmission Low Miles working
Looking to buy 4T60e Transmission Low Miles working by Dennis LaGrua
Started on: 03-13-2021 05:40 PM
Replies: 6 (386 views)
Last post by: Johns 4.9 on 03-17-2021 07:28 PM
Total ratings: 329
Report this Post03-13-2021 05:40 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking to buy a 4T60e transmission for my 4.9L Cadillac swap. Its the 1993 model. The guy I purchased it from said 68K miles and it works great. Installed it and it grinds like its blown out. Tried to return it and the guy already skipped town. If I can find one in the W NJ E PA area or in NJ that would be great.
Leads also appreciated.
[This message has been edited by Dennis LaGrua (edited 03-13-2021).]
Total ratings: 206
Report this Post03-14-2021 08:32 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I suggest that you would be better off having the transmission you have rebuilt.
Total ratings: 329
Report this Post03-16-2021 09:07 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Joe that really is the best idea. I am now leaning that way but those transmissions are old and you often get the comment that they are expensive to rebuild. Was thinking about rebuilding it myself as the friction discs and bands are not real difficult to replace but the trans may have a gear or sprocket problem and that may complicate things.
Johns 4.9
Report this Post03-16-2021 11:41 AM Click Here to See the Profile for Johns 4.9Click Here to visit Johns 4.9's HomePageSend a Private Message to Johns 4.9Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Dennis,
The transmissions are not that expensive if you rebuild them yourself. They sell rebuild kits on eBay. There is a guy on YouTube who has videos on how to rebuild GM transmissions. I rebuilt my 4T60 trans with help from his three part video series on that transmission. You can also add a shift kit and a higher stall converter.
It sucks that some people lack integrity. Good luck getting things figured out.
Cheers
John
Total ratings: 329
Report this Post03-16-2021 09:31 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Johns 4.9:
Hey Dennis,
Cheers
John
No big deal replacing the friction plates, bands,seals, relays and some bearings but the trans that I have appears to have damaged planetary gears of which four are inside the final drive housing. Have to check the process to replace them. Actually the stall speed of the TC on the 4.9L transmission is only 1850 RPM. Thats pretty low.
Total ratings: 206
Report this Post03-17-2021 06:58 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Caddy 4T60 E should be using a VCC, lockup is controlled by the PCM.
Johns 4.9
Report this Post03-17-2021 07:28 PM Click Here to See the Profile for Johns 4.9Click Here to visit Johns 4.9's HomePageSend a Private Message to Johns 4.9Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Dennis,
Check eBay for parts for your 4T60e. They have all kinds of stuff.
Cheers
