  The Mall
  ecotek engine brackets
ecotek engine brackets by thelinsells
Started on: 06-10-2021 08:12 PM
Replies: 20 (435 views)
Last post by: thesameguy on 06-22-2021 01:04 PM
thelinsells
Report this Post06-10-2021 08:12 PM Click Here to See the Profile for thelinsellsSend a Private Message to thelinsellsEdit/Delete MessageReply w/QuoteDirect Link to This Post
these brackets are made so that the engine is in the right place in the car.In 2007 the first of these brackets were used.Over 100,000 miles has been put on this set .A set for 84-87 and a set for 88 subframes (cradle) . $275 saves you weeks of work.Install ,when the subframe is out,can be done in a weekend.
Total ratings: 328
Report this Post06-11-2021 02:49 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
As they say "one picture is worth 1000 words" . I have a friend who is about to begin an Ecotec swap but I understand that this engine mounts differently depending on model year. I passed on your name and he should be contacting you . I hope that you can help him.
thelinsells
Report this Post06-12-2021 02:32 PM Click Here to See the Profile for thelinsellsSend a Private Message to thelinsellsEdit/Delete MessageReply w/QuoteDirect Link to This Post
As stated in the opening there is two kits.One is for 84-87 and the other is for 88.The difference is in the space between the side rails.This difference allows for the split line on the bellhousing to fall in the right place , so the trans will be located so the axles will fall to a proper place .Yes a lot of work goes into doing it right.
Total ratings: 328
Report this Post06-12-2021 10:16 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Perhaps my wording was wrong. The Ecotec engine was offered by GM for 13 years in a number of iterations.I believe that the mounting points on these engines was not all the same for the entire run. The question would be; will your mounts fit all the Ecotec engines made or perhaps just some specific model years like the Gen 1 designs.
thelinsells
Report this Post06-12-2021 11:25 PM Click Here to See the Profile for thelinsellsSend a Private Message to thelinsellsEdit/Delete MessageReply w/QuoteDirect Link to This Post
What year are you going to use so I can tell you what to do.
thelinsells
Report this Post06-12-2021 11:30 PM Click Here to See the Profile for thelinsellsSend a Private Message to thelinsellsEdit/Delete MessageReply w/QuoteDirect Link to This Post
thelinsells
Member since May 2014
Yes the Ecotek engine block has been changed over the last fifteen or so years.Where my brackets bolt on seem not to have changed.Most of the big changes have been to the heads and oil pans.Most of these changes have allowed them to be used on older blocks.One thing I have noted is the exhaust has stayed the same .That is one exhaust manifold seems to fit all years.
[This message has been edited by thelinsells (edited 06-13-2021).]
qwikgta
Total ratings: 84
Report this Post06-14-2021 12:03 AM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
how about a 2016, 2.0 LTG motor? The exhaust and intake are 180' from the early motors. I have a 2016 motor and it would be fit into an 88 cradle. Does your kit work?
Rob
thelinsells
Report this Post06-14-2021 08:44 PM Click Here to See the Profile for thelinsellsSend a Private Message to thelinsellsEdit/Delete MessageReply w/QuoteDirect Link to This Post
If this motor where in your Fiero would the intake be to the front of the car or the rear?
qwikgta
Total ratings: 84
Report this Post06-15-2021 01:25 AM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The intake would be in the rear, next to the trunk.
thelinsells
Report this Post06-16-2021 12:21 AM Click Here to See the Profile for thelinsellsSend a Private Message to thelinsellsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you for showing me this motor .This is something new to me.The block has many points the same as other Ecotek . The head seems to be the big change.I would have to see more pix to see if the mounting points are the same.What year is it and what did it come out of?
qwikgta
Total ratings: 84
Report this Post06-16-2021 12:12 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
2016 Buick Regal. It came with the 6T70 auto trans, but I picked up the 2014-2018 F40 manual trans for it. The trans is unique to this motor b/c the starter is on the other side. I'll send some pics soon.
Total ratings: 328
Report this Post06-16-2021 03:37 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was inquiring for a friend. As he doesn't frequent this forum, I will pass on the comment to him but I still maintain that with the Ecotec one size doesn't fit all. I would recommend that you specifically state what model years your mounts will fit as it may make things go smoother.
qwikgta
Total ratings: 84
Report this Post06-17-2021 11:28 AM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
So I don't have any pics of my motor, b/c in my storage but here are two from the web. pay no attention to the RWD trans.
This is the intake side, that faces the trunk
This is the exhaust side that faces the back seat/fire wall.
Rob
[This message has been edited by qwikgta (edited 06-17-2021).]
thelinsells
Report this Post06-18-2021 05:43 AM Click Here to See the Profile for thelinsellsSend a Private Message to thelinsellsEdit/Delete MessageReply w/QuoteDirect Link to This Post
What I can tell you is that , with the Ecotek I have worked with,the oil pans , exhaust manifolds and intermediate shafts are all interchangable.The water pump,thermostat , alternater and AC all bolt up to each other. The holes where the brackets screw on are in the right places.These engines you are showing may have the same basic block with 180 degree heads.It will be interesting to find out.
foxgapfiero
Report this Post06-19-2021 12:19 PM Click Here to See the Profile for foxgapfieroSend a Private Message to foxgapfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I saw a Saab turbo in my friends shop the other day with a 5 speed. I gather this is pretty much the same motor as the Ecotech, but it can be had in a non turbo 6 speed configuration. Would your brackets work with this also?
Coming to the Carlisle show to hunt up a few of these swaps to get ideas and advice.
Thanks, Mark
Mark Hoagland
86 1/2 GT 3.4 5-speed 355 nose and tailights REAL bright yellow
84 SE Convertible
thelinsells
Report this Post06-19-2021 06:31 PM Click Here to See the Profile for thelinsellsSend a Private Message to thelinsellsEdit/Delete MessageReply w/QuoteDirect Link to This Post
SAAB did use Ecotek.They also used a euro White motor.
qwikgta
Total ratings: 84
Report this Post06-19-2021 10:43 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, Mark
Yes, the SAAB 2.0 (LK9) is a Turbo Ecotec. https://en.wikipedia.org/wiki/GM_Ecotec_engine
Rob
thelinsells
Report this Post06-20-2021 10:43 AM Click Here to See the Profile for thelinsellsSend a Private Message to thelinsellsEdit/Delete MessageReply w/QuoteDirect Link to This Post
What year?
foxgapfiero
Report this Post06-21-2021 06:55 AM Click Here to See the Profile for foxgapfieroSend a Private Message to foxgapfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rob, that was what was in the Saab, it was definitely older one and had many issues. Not well taken care of I guess. It was getting a turbo and several sensors. Does anyone know the designation for the bigger horse motor that comes with the six speed? I think that would be the one I would like to use. Finding a turbo motor that has not been abused may be kind of tough. The bigger motor, I believe , does not get a turbo.
[This message has been edited by foxgapfiero (edited 06-21-2021).]
qwikgta
Total ratings: 84
Report this Post06-21-2021 05:18 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
not sure but I do know that the 2.0 Turbo also came with a F40 6 speed, I picked up one off a 07 Saab. It has the ECOTEC bellhousing and will only work with those motors. I planned on putting it behind a LSJ supercharged 2.0 motor I also have.
Rob
thesameguy
Report this Post06-22-2021 01:04 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The LK9 was in the 2003-2011 9440 body, aka "Sport Sedan" or "Sport Combi." In the US, it was either 175hp (2.0t, B207L) or 210hp (2.0T, B207R). The F35 was standard all years, the F40 was on certain trims except in 2005 and 2006. All these motors were run by Trionic 8, but there were some subtle differences in the motor over time.
The other motor in these cars was the LP9 / B284 from 2006 to 2009. The manual was always an F40. Output was 250hp-280hp depending on year/trim. All are run by Bosch ME9.
All Saab motors from 1999 on are turbocharged.
[This message has been edited by thesameguy (edited 06-22-2021).]
