  The Mall
  ***FOR SALE*** - 88 Coupe - ***3800SC - 4t65eHD - Full Restoration***
***FOR SALE*** - 88 Coupe - ***3800SC - 4t65eHD - Full Restoration*** by Rare87GT
Started on: 08-08-2021 11:40 PM
Replies: 18 (1701 views)
Last post by: RichLo1 on 10-27-2021 03:01 PM
Rare87GT
Total ratings: 173
Report this Post08-08-2021 11:40 PM Click Here to See the Profile for Rare87GTSend a Private Message to Rare87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
****FOR SALE****
88 Coupe, 3800SC/Auto - 4t65E-HD, 121k on chassis for sale. Fully restored, top to bottom. Needs only exterior paint. All the hard work is done, no shortcuts on this build. Everything new within last 500 miles.
2002 Buick Park Avenue Engine/Transmission 3800 Series II Supercharged - OBD 2 wiring
Tuned on HP Tuners
EGR & EVAP Deleted
3.5" ZZP Modular Pulley
8 rib pulley setup
SFI Balancer
Stock Fuel Injectors - cleaned and professionally flow matched
New Aluminum Intake Gaskets
Valve cover gaskets
Series III Aluminum Oil Pan
New Oil Pan Gasket
New rear main seal
Custom fender cold air intake
ZZP rear plogs
Ceramic coated crossover pipe
3" exhaust with Flowmaster with C6 exhaust tips
Red Top Optima battery
New ICM
New Crank Sensor
Autolite 104 plugs gapped at .048
New AC delco set of coil packs
AEM fuel pump
Pillar gauges - Aeroforce scan gauge &
AEM Wideband gauge and sensor - tuned 11.0-11.4 WOT
Transmission- new GT torque converter with higher stall. New meiziere aluminum flexplate.
ZZP Aluminum Transmission Pan
Suspension
All painted with rust oleum (completely removed everything to paint each part separate)
All new bolts
All new ball joints, tie rods, poly bushings all around, front and rear wheel bearings.
Added rear sway bar with zero lash end links
Front sway bar zero lash end links
Rodney Dickman Steering rack bushing
New 12" vette rotor kit front and back/calipers and pads
Rear coilovers
Fieroguru rear lateral links
Fierostore Stainless Steel Brake Lines "the complete lines"
Underside of car completely painted with rust oleum.
No rust on car (rear trunk corners shown)
Body
Stage 3 I believe Tedd Wilson - side scoops
Low pro 60mm headlights with hella housings and LED bulbs
LED side markers
LED 3rd brake light
Wheels/tires are 18/17 combo (May not go with the car - both brand new under 500 miles)
Have the Stock wingless decklid. Added decklid with spoiler currently on car now
Interior
Russ door panels and seat covers.
New black carpet
New black headliner
New Bluetooth radio
New speakers
Center sub box (may not go with car)
Exterior
Needs paint
**EDIT - Just added brand new side window glass on both driver and passenger. Also installed brand new inner and outer dew wipes, new felt guides, and door striker bolts.
$12,500 OBO
Located in Wichita, KS
Only reason that I'm considering selling is because we have the opportunity to buy another Fiero I've been wanting to get and don't need 4 Fieros. We were ready to paint soon, but decided to hold off plus if the new owner wants a certain color and I paint it something else it may not be as wanted. If it doesn't sell, we will paint it and keep it.
Thank you,
Amir
Any questions on the car please call, text, or message.
316-990-6094
https://www.youtube.com/watch?v=P6L-wLQ36y8 - Exhaust Sound
https://www.youtube.com/watch?v=EL2L58PUsak - Low Pro Headlights w/LED
https://www.youtube.com/watch?v=YKKSyiRImjM - Driving and a little wide open throttle
88 Formula - 3800SC/4t65eHD
88 Coupe - 3800SC/4t65eHD
87GT - Great Blue Chop Top
[This message has been edited by Rare87GT (edited 08-13-2021).]
Total ratings: 463
Report this Post08-09-2021 09:17 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can't imagine what you've found that makes it worth selling this one, after all the work you've put in it. But GLWS, nonetheless.
Rare87GT
Total ratings: 173
Report this Post08-09-2021 11:07 AM Click Here to See the Profile for Rare87GTSend a Private Message to Rare87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's the car I wanted since the 30th anniversary in Indy
Total ratings: 463
Report this Post08-09-2021 12:21 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cool! Good luck!
Rare87GT
Total ratings: 173
Report this Post08-13-2021 04:46 PM Click Here to See the Profile for Rare87GTSend a Private Message to Rare87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
Just added brand new side window glass, new inner and outer dew wipes and felt guides. Also installed new door striker bolts.
Rare87GT
Total ratings: 173
Report this Post08-20-2021 11:43 AM Click Here to See the Profile for Rare87GTSend a Private Message to Rare87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump...Starting to install the warber hood scoop now and get the car ready for primer. FYI, if I paint it price will go up.
fireboss
Total ratings: 58
Report this Post08-20-2021 08:55 PM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
A/C ?
Rare87GT
Total ratings: 173
Report this Post08-21-2021 05:28 PM Click Here to See the Profile for Rare87GTSend a Private Message to Rare87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by fireboss:
A/C ?
At the moment has the AC delete pulley. But I do have the AC lines already custom made with the Grand Prix and Fiero ends ready to install in a box for the car. AC can be installed with a new compressor if the buyer requests it. Will take care of that if it is something that is requested pending a deal.
[This message has been edited by Rare87GT (edited 08-21-2021).]
Rare87GT
Total ratings: 173
Report this Post08-31-2021 09:59 AM Click Here to See the Profile for Rare87GTSend a Private Message to Rare87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
imacflier
Report this Post09-02-2021 01:53 PM Click Here to See the Profile for imacflierSend a Private Message to imacflierEdit/Delete MessageReply w/QuoteDirect Link to This Post
Price with working A/C and painted Vette Velocity Yellow?
TIA
Larry
da.slyboy
Report this Post09-02-2021 03:20 PM Click Here to See the Profile for da.slyboySend a Private Message to da.slyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
Is it just as easy to obtain side glass through any windshield shop of did you have to have it special ordered?
I also enjoy that you continue to work on it and make improvements as you are in the selling process.
[This message has been edited by da.slyboy (edited 09-02-2021).]
Rare87GT
Total ratings: 173
Report this Post09-05-2021 02:11 PM Click Here to See the Profile for Rare87GTSend a Private Message to Rare87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
TIA
Larry
Larry,
PM sent.
Thanks,
Amir
Rare87GT
Total ratings: 173
Report this Post09-05-2021 02:13 PM Click Here to See the Profile for Rare87GTSend a Private Message to Rare87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rare87GT
Member since Oct 2001
Unfortunately the side window glass is not made anymore from what I understand. But I could be wrong. My buddy had this set of glass for years and I wanted to get rid of the scratched glass, so I had these put in with new dew wipes and felt guides.
Thank you for the nice comments.
Rare87GT
Total ratings: 173
Report this Post09-15-2021 11:04 AM Click Here to See the Profile for Rare87GTSend a Private Message to Rare87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump. Probably only going to keep this for sale a few more weeks before we decide to go ahead and paint it.
Rare87GT
Total ratings: 173
Report this Post09-22-2021 08:01 PM Click Here to See the Profile for Rare87GTSend a Private Message to Rare87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Things are still progressing on the car. I'm not stopping but if someone does indeed want the car, then we can discuss. If it gets painted, it's going to most likely be sold on Bring a Trailer.
Just updating - Warber hood scoop done on hood.
[This message has been edited by Rare87GT (edited 09-22-2021).]
Rare87GT
Total ratings: 173
Report this Post09-23-2021 10:19 AM Click Here to See the Profile for Rare87GTSend a Private Message to Rare87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sale pending
87Fiero
Report this Post09-24-2021 03:14 PM Click Here to See the Profile for 87FieroSend a Private Message to 87FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Where did you get the Stage 3 side scoops?
Are they still being made?
Rare87GT
Total ratings: 173
Report this Post09-27-2021 10:17 AM Click Here to See the Profile for Rare87GTSend a Private Message to Rare87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
These scoops were from Tedd Wilson. He is still making fiberglass parts when he has time. You would have to message him to find out when he would be able to make another set or what his exact plans are.
Thank you,
Amir.
RichLo1
Report this Post10-27-2021 03:01 PM Click Here to See the Profile for RichLo1Send a Private Message to RichLo1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Still for sale?
