  The Mall
  '88 Fiero Front Suspension + rear uprights + rear sway bar
'88 Fiero Front Suspension + rear uprights + rear sway bar by RandomTask
Started on: 11-09-2021 08:14 PM
Replies: 9 (574 views)
Last post by: RandomTask on 12-22-2021 07:27 PM
RandomTask
Total ratings: 150
Report this Post11-09-2021 08:14 PM Click Here to See the Profile for RandomTaskSend a Private Message to RandomTaskEdit/Delete MessageReply w/QuoteDirect Link to This Post
Local Pickup only in Northern VA. Make me an offer. If not, I'll say $200. Pulled out of my '88 Formula (although you'll be getting '88 4cyl springs).
Reason for selling: I bought a '88 4cyl to part out/build the front suspension off of/rebuild/powder coat.
Complete front end, rotor to rotor (Calipers not included) w/ sway bar and cross member + steering rack. Also have some spare rear uprights + toe rods+ trailing arms (one is slightly bent; looks like previous owner tried to jack car up on it) + some other suspension parts. Also comes with a rear sway bar that's been powder coated with brand new end (red) poly end links.
Will straight trade for some GT doors.
WILL NOT SHIP.
Total ratings: 463
Report this Post11-10-2021 07:55 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow... wish you were closer.
(Free bump, if nothing else.)
RandomTask
Total ratings: 150
Report this Post11-13-2021 12:55 AM Click Here to See the Profile for RandomTaskSend a Private Message to RandomTaskEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
RandomTask
Total ratings: 150
Report this Post12-05-2021 06:02 PM Click Here to See the Profile for RandomTaskSend a Private Message to RandomTaskEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Larry Hubbert
Report this Post12-06-2021 01:40 PM Click Here to See the Profile for Larry HubbertSend a Private Message to Larry HubbertEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a set of 88 GT doors with full power, with or without the outer body panels here in Elfers, FL 34680 if you are interested. I am interested in the 88 rear suspension parts you want to sell or trade. Please email me directly at LHUBBERT2@BRIGHTHOUSE.COM Thanks.
RandomTask
Total ratings: 150
Report this Post12-10-2021 03:21 PM Click Here to See the Profile for RandomTaskSend a Private Message to RandomTaskEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Larry but the issue is getting down to FL.
Still looking; hopefully to trade.
reinhart
Report this Post12-15-2021 04:10 AM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's a fair price. I bought an entire front suspension from a local yard and I think it was about $500 total including the crossmember with me doing all the work to remove lol.
RandomTask
Total ratings: 150
Report this Post12-19-2021 01:56 PM Click Here to See the Profile for RandomTaskSend a Private Message to RandomTaskEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pic. Also have a front and rear 88 fascia I'll throw in.
[This message has been edited by RandomTask (edited 12-19-2021).]
Fieromotion
Report this Post12-21-2021 06:48 PM Click Here to See the Profile for FieromotionSend a Private Message to FieromotionEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh dear so far from Texas This is what I have been looking. Need only the original x member plus it´s parts.
Some lucky will get them. Heikki
RandomTask
Total ratings: 150
Report this Post12-22-2021 07:27 PM Click Here to See the Profile for RandomTaskSend a Private Message to RandomTaskEdit/Delete MessageReply w/QuoteDirect Link to This Post
Couple of things: One of the Upper A-arm shafts broke when installing. I pilfered one off the above setup. I'll give you the broken (powder coated) one. You *might* be able to fix.
I also have a front + rear fascia off an 88 (Yellow) I'm throwing in.
So quick inventory of the package:
Front K-Member w/ steering rack
All front suspension bits less above mentioned shaft and sway bar (I *might* have it in the shed, I'll have to check). Springs from 4cyl car.
Powder coated items - Front/Rear sway bar mounts. Brake backing plates (can't remember if they were from front or back or if they're interchangeable).
Rear trailing arms (one slightly bent from what appear to be someone attempting to jack car up on it)
Rear camber bars.
Rear sway bar (powder coated) w/ brand new poly bushings.
Front+Rear fascia.
2007 Cobalt SS axles. Brand new - used for mockup. Welded some pieces onto the cups during mockup; you can easily grind off.
[This message has been edited by RandomTask (edited 12-22-2021).]
