  The Mall
  Shelves full of Fiero parts for sale
Shelves full of Fiero parts for sale by wannav8
Started on: 05-17-2022 10:51 AM
Replies: 0 (374 views)
Last post by: wannav8 on 05-17-2022 10:51 AM
wannav8
Report this Post05-17-2022 10:51 AM Click Here to See the Profile for wannav8Send a Private Message to wannav8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sold my fiero projects as i am downsizing to get ready to move and retire. I have a bunch of parts from the 3 parts cars that i used to build 2 nice projects. All parts are removed and ready for pick up or ship. Here is the huge list of parts with prices. I wont ship larger parts as i dont have boxes big enough and shipping will probably be expensive anyways. Please text me at 817-202-7258 for any questions or request as i wont have time to get on here that often. Parts are located in my home shop in Waxahachie tx which is about 20 min south of dallas. Thanks.
PONTIAC FIERO PARTS
INTERIOR
HVAC CONTROL HEAD $20 1B 2EA
CONSOLE SIDE GRILLS GREY 1PR $20 1B
FUEL DOOR RELEASE CABLE AND HANDLE 2EA $10 1B
LOWER STEERING COLUMN COVER 3EA 1-TAN/2-BLK $20 1B
3RD BRAKE LIGHT BLACK $20 1B
OVERHEAD DOME MAP LIGHT BLACK $40 1B
SEAT BELT RETRACTORS BLACK $50 PR 1B
DASH GLOVE/MAP POCKET GREY $30 1B
INSTRUMENT CLUSTER HOUSING BACK COVER TAN $20 1B
ECM MOUNT BRACKET $10 1B 2EA
STEERING COLUMN ASSY W/GRANT WHEEL AND KEY GREAT SHAPE $150 1B
TAN SEAT BELT ASSY COMPLETE $50 1B
INSTRUMENT CLUSTER 85MPH $50 1C
DRIVER SIDE B PILLAR TRIM BLACK/TAN/GREY 3EA $20 1C
A PILLAR TRIM PASS SIDE BLACK/TAN 2EA $20 1C
PASSENGER SIDE B PILLAR TRIM BLACK/TAN/GREY 3EA $20 1C
DRIVER SIDE INTERIOR LOWER TRIM AROUND P/BRAKE HANDLE BLACK PAINT $20 1C
PASS LOWER INTERIOR TRIM TAN/BLK 2EA $20 1C
INSTRUMENT CLUSTER 120MPH WITH BLACK SURROUND A SILVER BEZEL $150 1C
INNER DOOR DEW WIPES $50 PR 1C
CENTER CONSOLE SKELETON MINOR CRACKING $50 1C 2EA
INTERIOR BACK PANEL BLACK VINYL AND GREY CARPET $25 EA 2A
DRIVER SIDE DASH TRIM/VENT TAN $10 2A
DOOR ARM RESTS LIGHT GREY AND TAN AND BLACK PAINTED $20PR 3 PR 2A
PASS INTERIOR DOOR PANEL GREY WPOCKET PW//PL $25 2A
PARKING BRAKE HANDLE AND CABLE ASSY $50 2A
AUTO SHIFTER ASSY W/CBALE $100 2A
INTERIOR DOOR PANELS PAINTED BLACK DRIVER AND PASS $25EA 2A
INNER DOOR DEW WIPE RETAINER BRKT FULL LENGTH $10PR 2B 3PR
TAN CARPET DRIVER COND $25 3B
HVAC CENTER PANEL VENTS $10PR 3B
DASH TOP METAL DEFROST VENT $10 3B
PARKING BRAKE HANDLE $25 3B
AUX BAT/OIL GAUGE $30 NO LENS OR POD 3B
HVAC RADIO SURROUND FOR AUX GAUGE OPTION $35 3B BLACK
SHIFTER SURROUND TAN $25 3B
AUTO SHIFT KNOB TAN/BROWN VERY NICE $25 3B
AUX GAUGES BAT/OIL WITH LENS/BLK-POD/BRKT $60 3B
AUX GAUGE LENS $5 3B
DEFROST DUCT WORK $15 3B
DASH SPEAKER GRILL COVERS 1TAN/2GREY $15 PR 3PR 3B
HOOD RELEASE CABLE $20 2EA 3B
HOOD RELEASE HANDLE $20 3B
ACCELERATOR PEDAL ASSY $20 3B
DARK GREY DASH SIDE VENTS $20PR 3B
DOME MAP LIGHT NON SUB WOOFER GREY/SILVER AND TAN 2EA $20 3B
HOOD RELEASE HANDLE AND CABLE $50 3B
SUNROOF WELTING STRIP GREY/TAN 2EA $10 3B
4SPEED SHIFTER PLATE TRIM W/ASH TRAY DOORS $40 3B
4 SPEED SHIFTER BOOT W/CRACKED MOUNT RING $15 3B
PARKING BRAKE BOOT $10 3B
INNER DOOR HANDLE TRIM $10EA 3B
CONSOLE SKELETON SIDE PANELS $10EA 3B
HVAC DUCT LARGE BEHIND DASH $25 4C
HVAC DUCT TOP UNDER DASH $15 4C
EXTERIOR
REAR BUMPER METAL REINFORCEMENT WITH PLASTIC ABSORBER $50 FLOOR
REAR QUARTER PANEL SECTION FOR NOTCHBACK CAR $100 2EA FLOOR BOTH SILVER
DRIVER SIDE DOOR LOADED POWER WORKS HINGES $200 FLOOR
PASS SIDE DOOR LOADED POWER WORKS HINGES $200 FLOOR
HOOD SILVER $125 FLOOR
PASS DOOR SHELL WITH HINGES $100 FLOOR
DRIVER " " $100 FLOOR
FUEL DOOR ASSY 2EA SILVER/GOLD $25 1B
FUEL DOOR POCKET NO DOOR RED $10 1B
NOTCHBACK INNER SAIL PANEL TRIM DRV SIDE $15 1B
AIR INLET GRILL FOR Q PANEL $10 3EA 1B
FRONT LOWER AIR DEFECTOR $30 1C
PASS SIDE LOWER GREY ROCKER COVER $25 1C
PASS SIDE FRONT Q PANEL RED $30 1C
DRIVER SIDE FRONT REAR Q PANEL SILVER $30 1C
DRIP RAIL MOULDINGS 1 DRVR SIDE 3 PASS SIDE $30 EA 1C
PASS DOOR SKIN TAN $40 1C
DRIVER DOOR SKIN SILVER $40 1C
PASS DOOR WINDOW $40 2A
R/F INNER WHEEL WELL $30 2A
L/F INNER WHEEL WELL $30 2A
L/R INNER WHEEL WELL $30 2A 2EA
REAR BUMPER COVER TOP MOUNT METAL BRKT $20 3EA 2B
REAR BUMPER METAL REINFORCEMENT WITH PLASTIC ABSORBER $50 2B
REAR BUMPER LOWER PLASTIC MOUNT TO MEDAL BUMPER $10 3A
TURN SIGNAL BRACKET FRONT LEFT $7 3A
W/S WASHER NOZLES $10 PR 3A
REAR BUMPER PLASTIC SHOCK ABS BLOCKS $15PR 3A
FRONT BUMPER SHOCK ABS BLOCKS $15PR 3A
DRIVER SIDE MIRROR MANUAL $40 3B
DRIVER SIDE TOP ENGINE VENT GRILL NOTCHBACK $10 3B
PASS " " $10 3B
TOP ENGINE VENT GRILL SCREENS $10 EA 3EA 3B
WIPER ARMS 2 PR $30PR 3B
SUNROOF GLASS NO LATCH $40 3B
SUNROOF GLASS WITH LATCH $75 3B
MARKER LIGHTS 2 RHF 1 LHF 1 RHR $5 EACH 3B
LOWER AIR DAM METAL BRACE $25 3B
ENGINE COMPARTMENT/REAR TRUNK
EXHAUST SYSTEM FROM Y-PIPE TO TIPS $100 FLOOR
FUEL FILTER LINES $30 1B
VAPOR CANISTER ASSY W/BRACKET $25 1B 2EA
FRONT ENG COMP HEAT SHIELD $20 1B 3EA
AIR BOX BETWEEN AIR VENT AND AIR CLEANER $20 1B 2EA
A/C COMP/BRKT/HOSE ASSY $150 1B
ENG COMPARTMENT COOLING FAN WITH DUAL OUTLETS $100 1C
TRUNK LID HINGES $25PR 1C
ENG COMP COOLING FAN ASSY W/1 DUCT $75 1C
BRAKE BOOSTER VAC HOSE W/VLAVE ENG COMP SIDE $7 2A
ENG COOLANT TUBE $10 2A
ENGINE VENTS MOUNT PLATES FOR STRUT TOWER NOTCHBACK $25PR 2A 2PR
VACUUM CANISTER METAL CAN $15 2EA 2A
V6 ACCELERATOR CABLE $20 2A
TRUNK CARPET $25 2EA 2A
VAPOR CANISTER VAC TUBE TO FUEL TANK $10 2B
FUEL FILLER NECK ASSY 2EA $25 2B
VAPOR CANISTER VAC TUBES TRUNK SIDE $10 2B
REAR ENG COMP METAL VAC LINES $10 2B
LARGE DIAM ENG COOLANT TUBE $20 2B 2EA
A/C LINES FROM COMP TO FIREWALL $40 2B
ENG FIREWALL COOLANT TUBE W/VAC STEEL TUBE $15 2B
VACUUM CANISTER METAL VAC LINE $10 2B
VAPOR CANISTER MOUNT BRKT $15 3A
AIR CLEANER CANISTER LOWER MOUNT BRKT $15 3A
AIR CLEANER LID SAND BLASTED $15 3B
ENG VENTS GRILL OUTSIDE MOUNT BRKT $15PR 3PR 3B
HEAT SHEILD LOWER TRUNK ENG SIDE $10 4C
FRONT TRUNK
HOOD PROP ROD $20 1B
SPARE TIRE HOLD DOWN ROD $10 1B 2EA
SUNROOF AIR DEFLECTOR WITH MOUNT BRKTS $40 1B
FRONT TRUNK SEAL $25 2A
WINDSHIELD WASHER BOTTLE GOOD COND $25 2A
BRAKE BOOSTER VAC HOSE $5 2A
SPARE TIRE CARRIER 2EA $30 2A
HVAC BOX ASSY $100 2A
BRAKE MASTER CYL $20 2A
ELECTRIC RAD FAN WORKS GOOD $40 2B
A/C LINE CONDENSOR TO FIREWALL $10 2B 2EA
3A
A/C CONDENSER $25 3A
COWL DRAIN TUBES $20PR 3B
LUG WRENCH MOUNT BRKTS $10 3B
JACK MOUNTING BRACKET $20 3B 2EA
WIPER MOTOR $30 2EA 3B
HOOD LATCH $10 3B
STEERING SHAFT BOOT $10 3B
ENGINE/TRANS
REAR HEADER REPAIRED $15 1B
FRONT HEADER HEAT SHIELD BETWEEN HEADER AND HEAD $20 1B
FRONT HEADER OUTER HEAT SHIELD $25 1B 2EA
FUEL INJECTOR MANIFOLD $20 2A
V6 ENGINE PLASTIC VAC HARNESS $25 2A
V6 PCV PLASTIC TUBE W/ELBOWS $10 2A
V6 STARTER $20 2A 2EA
V6 THROTTLE BODY $25 2A
V6 THROTTLE BODY COOLANT TUBES $10 2A 2EA
V6 T/B VAC ELBOW TUBE $5 2EA 2A
V6 SPARKPLUG HEAT SHIELDS $10 SET 2 SETS 2A
V6 OIL PSI TUBE/SENSOR $10 2A
V6 EXH Y-PIPE W/EGR VALVE $40 2B
TRANS MOUNT HEAT SHIELD MANUAL $10 3A
REAR MANUAL TRANS MOUNT 4SPD BRKT $10 3A
FRONT ENGINE MOUNT BRACKET V6 $15 3A
WISHBONE UPPER MOTOR MOUNT GOOD BUSHINGS $25 3A
ALTERNATOR BRACKET V6 $25 3A
ENGINE MOUNT UPPER WISHBONE BRACKET $20 3A 2EA
V6 ALTERNATOR WORKS W/HEAT SHEILD $40 3A
CRUISE SERVO ASSY $25 2EA 3B
ECM FOR 86 V6 4SPD MANUAL $50 3B
COIL HEAT SHEILD $15 3B
V6 OIL DIPSTICK AND TUBE $20 3B
4 SPD INSPECTION COVER $15 3B 2EA
WIRING
85-86 NOTCHBACK WIRING HARNESSESS FLOOR
UNDERBODY
COOLANT TUBES FULL LENGTH 2B
HEATER CORE TUBES FULL LENGTH 2 SETS $40 2B
AC TUBES FULL LENGTH $50 2B 2PR
AUTO TRANS LINES FULL LENGTH $25 2B
FRONT SUBFRAME TO CORE SUPPORT BRKTS $20PR 2PR 3A
FRONT UNDER BODY STIFFENING BRKT IN FRONT OF FUEL TANK $10 3A 2EA
FUEL TANK MOUNT LOWER SKID PLATE $20 3EA 3B
SUSPENSION AND BRAKES
REAR CALIPERS $100 PR 1B 2PR
84-87 FRONT SUB FRAME WITH UPPER CONTROL ARMS $100 1B
LOWER CONTROL ARM REAR PASS SIDE $40 2A
BRAKE LINES W/PROP VALVE VARIOUS LENGTHS 2B
POWER BRAKE BOOSTER METAL VAC TUBE FULL LENGTH $15 2B
REAR HUB/SPINDLE STRUT ASSY R/L SIDE $75EA 3B
FRONT SWAYBAR $20 3B 2EA
84-87 FRONT HUB ROTOR ASSY L&R $40 EACH 3B
