  The Mall
  3.4L V6
3.4L V6 by Leeloo88
Started on: 10-06-2022 11:20 AM
Replies: 0 (329 views)
Last post by: Leeloo88 on 10-06-2022 11:20 AM
Leeloo88
Report this Post10-06-2022 11:20 AM Click Here to See the Profile for Leeloo88Send a Private Message to Leeloo88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Been storing a Camaro 3.4L in my garage for a few years now, planned to swap into my Formula but decided against it. Donor is fine but I now live overseas most of the year and just don't have the time. Engine is located in Peoria AZ.
Please see the photos below. It's has the OEM crank, pistons, cam, hydraulic tappets, flywheel, pulley / timing wheel. Oil filter and dipstick were left on to keep the oil sealed up in the sump and crank, pulled a tappet to have a look inside and its still oily and bright. Was purchased from a Tucson auto recycler and the story is that it was pulled from a '95 Camaro which was seized in a police drug raid... car was fine but not allowed to be re-sold... not sure why but that's what the man said. Actual age is uknown, the true mileage is unknown, the top speed the drug dealer achieved wit it is sort of known... can reasonably say it was less than a radio and crown vic. I've inspected it for bullet holes and found none of any kind. If any drugs are found within please don't hold me accountable but I would like to see a 25% kickback on the street value. Otherwise It does turn by hand, I don't turn it much farther than a few degrees because the cylinders do have some surface rust at the top. Also a critter did store a few nuts in the water jacket, while I didn't find any nests or fluff balls inside I did tip and blow the nuts out as best I could. Probably wouldn't fire it up without a little bit of a clean.
Will come with the pictured engine stand since I've no need for that anymore.
Reasonable offers considered and offered here first before it goes to fleabay.
Four Fans of Freedom
"Fiero Fugit"
[This message has been edited by Leeloo88 (edited 10-06-2022).]
