  The Mall
  Alternator for 85 GT
Alternator for 85 GT by Greentruck
Started on: 09-07-2023 07:34 PM
Replies: 12 (225 views)
Last post by: Patrick on 09-10-2023 11:54 PM
Greentruck
Report this Post09-07-2023 07:34 PM Click Here to See the Profile for GreentruckSend a Private Message to GreentruckEdit/Delete MessageReply w/QuoteDirect Link to This Post
My son bought an 85 GT 4 speed car earlier this summer. We found that the previous owner replaced the alternator with one with an incorrect pulley, which is shredding the belt. Does anyone have a V6 alternator, or alternator pulley for sale?
Thank you
wannav8
Report this Post09-08-2023 09:32 AM Click Here to See the Profile for wannav8Send a Private Message to wannav8Edit/Delete MessageReply w/QuoteDirect Link to This Post
I do text me at 817 202 7258
steve308
Total ratings: 58
Report this Post09-08-2023 02:02 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Rock Auto....get a new one for an 88. About 60 bucks...the Remy comes with the correct pulley. Why 88? 105 amps, smaller unit. Also order the conversion plug from Rodney Dickman and the alternator reinforcement bracket. To complete the upgrade either the Rodney Dickman Alternator belt idler Or the Dodge runner self adjusting idler pulley.
Greentruck
Report this Post09-08-2023 02:28 PM Click Here to See the Profile for GreentruckSend a Private Message to GreentruckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you both!
Report this Post09-08-2023 07:43 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Agree 100%... except I'd say with the Dodgerunner auto tensioner, the alternator reinforcement bracket is no longer necessary.
steve308
Total ratings: 58
Report this Post09-09-2023 09:08 AM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Don't ask me how I know.... but the reinforcement bracket is nice to have just in case you happen to 'ncorrectly tap' the 30+ year old pot metal bracket with a wrench while removing the alternator snapping off about an inch from the end.
Vintage-Nut
Report this Post09-09-2023 03:23 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
I went with Rodney Dickman 2.8 V-6 Idler Pulley because the Dodgerunner auto tensioner instructions.....Rodney's was easy to install.
http://rodneydickman.com/pr...o.php?products_id=71
Original Owner of a '88 GT and under 'Production Refurbishment'
Report this Post09-09-2023 06:19 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
What's that supposed to mean?
Rodney's idler pulley may be slightly easier to install, but it isn't the same device. Dodgerunner's auto tensioner is a superior product for keeping the alternator belt snug. Once it's installed (and it's not a big deal), the belt never needs further attention. Yes, I promote it every chance I get... because it's that good... and no, I receive no commission from Dodgerunner.
Report this Post09-09-2023 06:35 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Apr 99
Steve, how do you know?
Even if a person wanted to use Rodney's reinforcement bracket, it appears that it wouldn't work with Dodgerunner's auto tensioner. They'd both be trying to occupy the same area on the alternator bracket.
The Fiero 2.8 alternator mount is definitely a weak spot... but it can be seen in this photo (from the installation instructions) that Dodgerunner's bracket very effectively reinforces it.
[This message has been edited by Patrick (edited 09-09-2023).]
steve308
Total ratings: 58
Report this Post09-09-2023 09:10 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Unfortunately I snapped off enough of the brackets mounting 'ear' that the dodge runner unit has nothing to bolt to. It is a set and forget install. Oh, you will need a different length belt either way you go.
Report this Post09-10-2023 06:26 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is becoming a tech thread ... but Steve, if a spacer (the same thickness as the missing broken off "ear") was used to position the bottom of the alternator the correct distance from Dodgerunner's bracket, wouldn't that have worked when all bolted up?
steve308
Total ratings: 58
Report this Post09-10-2023 09:31 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
It might have but I found the RD idler and recommended belt rotated the lower alternator bolt mount back to where I could use the remaining bracket to secure the alternator with the extra strength of the brace helping. I'd be concerned about the alternator becoming a stressed mounting point using a spacer without the beef of some of the original bracket sharing the stress. I'm probably wrong.
Report this Post09-10-2023 11:54 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Heh heh... well, it's all hypothetical. You found a solution that worked, that's the important thing.
