I have had these for a while and realize I am not going to use them. Bought them years ago and here is the description from the seller,
"These are all the brackets you need along with new rubber mounts for a 3800/SC & 4T65E swap. The trans brackets are from a Trans Sport Van and the motor mount is from West Coast Fiero. When using the Transport mounts you will need to notch the cradle slightly as these mount the transmission lower than most aftermarket brackets."
I have not used them or even have anything to check fitment with right now. Perhaps someone that has used something similar can chime in.
$200 plus shipping for all of the mounts.
