| quote | Originally posted by TVS:
Thanks Dennis, I build custom cars for a living so the swap won't be a big deal. Just figured since I am pulling things for the trans swap might as well swap the cradle. |
Such being the case then the F23 and F40 5 speeds may be for you. They will bolt up but you will have to do some mods to the shifter and shift levers. Rodney Dickman makes a conversion parts kit for the F23. The F40 will be a fab job but it has been done before.
If you go with the F40 that box will provide more strength for a more powerful engine swap later on. If you look in the archives you should find some build threads.
