  The Mall
  15lb fuel injectors
15lb fuel injectors by XxdjxX89
Started on: 09-04-2024 03:41 PM
Replies: 7 (132 views)
Last post by: XxdjxX89 on 09-19-2024 06:59 PM
XxdjxX89
Report this Post09-04-2024 03:41 PM Click Here to See the Profile for XxdjxX89Send a Private Message to XxdjxX89Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have a couple of refurbished sets of 15lb factory Rochester fuel injectors for 2.8 Fiero
Looking to get $80 for the set of 6 or $100 if you want the cold start injector with it
Fuel injectors will get another quality checked before mailing out
XxdjxX89
Report this Post09-04-2024 03:43 PM Click Here to See the Profile for XxdjxX89Send a Private Message to XxdjxX89Edit/Delete MessageReply w/QuoteDirect Link to This Post
jpeeler
Report this Post09-08-2024 07:00 PM Click Here to See the Profile for jpeelerSend a Private Message to jpeelerEdit/Delete MessageReply w/QuoteDirect Link to This Post
So this would be the same as if I had some OEM injectors sent off for cleaning and testing? My wifes GT has a hard to start issue when hot. Pretty sure it's injectors leaking down. Cold start no problem. Holding the pedal down seems to help.
XxdjxX89
Report this Post09-09-2024 01:24 PM Click Here to See the Profile for XxdjxX89Send a Private Message to XxdjxX89Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes as these are oems refurbished and tested by me
If you send your old ones as a cores I’ll take $20 bucks off
I only have 2 sets in my on hands so once gone they gone
Until I can get more cores to refurbish
I will send you a flow chart and video proof if needed
Total ratings: 329
Report this Post09-14-2024 04:50 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
"Refurbished injectors" are made exactly using the process that the OP has; continuity test, flow test, new O rings, and a thorough cleaning. Occasionally the cone filter is replaced. The selling price here is good. If needed, I would not hesitate to buy these.
jpeeler
Report this Post09-15-2024 08:03 PM Click Here to See the Profile for jpeelerSend a Private Message to jpeelerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I sent you a PM a couple days ago. Not sure if you saw it.
XxdjxX89
Report this Post09-19-2024 06:39 PM Click Here to See the Profile for XxdjxX89Send a Private Message to XxdjxX89Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry I haven’t been on line for a week
XxdjxX89
Report this Post09-19-2024 06:59 PM Click Here to See the Profile for XxdjxX89Send a Private Message to XxdjxX89Edit/Delete MessageReply w/QuoteDirect Link to This Post
XxdjxX89
Member since Feb 2015
Thanks Dennis lagrua for the kind words
It’s definitely a process And time we’ll spent it’s my way of giving back to this awesome Fiero community cliff has done for us
