| quote | Originally posted by FIER086: Junkyard is the cheapest option. You will also want to grab a MAF off of a 5.3 2002-2006 Chevy truck/tahoe/ suburban. Other years may work too but not 100 percent sure |
My swap use the LS1 MAF. Its larger, flows better and will raise boost but be advised many changes to the MAF table in the program will need to be made. You can start the process by importing the MAF airflow vs output frequency values from the LS1 into your PCM.
