  The Mall
  84 Iron Duke HEI
84 Iron Duke HEI by Aaron B
Started on: 09-19-2024 07:32 PM
Replies: 2 (64 views)
Last post by: Aaron B on 09-20-2024 12:53 PM
Aaron B
Report this Post09-19-2024 07:32 PM Click Here to See the Profile for Aaron BSend a Private Message to Aaron BEdit/Delete MessageReply w/QuoteDirect Link to This Post
Would anyone have, or know what model of hei distributor would fit in my 84 iron duke 4 cylinder engine? I am trying to migrate away from the factory ecm. I've successfully replaced the stock throttle body with a Holley Sniper unit, and it's working great. Now I'd like to remove the old computer controlled distributor, and install something like a 74 to 82 hei distributor that has the mechanical, and vacuum timing advance mechanics. I think my timing is jumping around, and I'd like to just set it, and eliminate that from my tuning. I'm thinking something like an 82 Sunbird, or the like might be what I'm looking for. Just seeing if anyone else has explored this.
Thanks for the read,
Aaron
Vintage-Nut
Report this Post09-19-2024 10:04 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
To me, you posted your thread in the incorrect section on the forum....
Can I suggest that you re-post it in the 'Technical Discussion & Questions' section?
Aaron B
Report this Post09-20-2024 12:53 PM Click Here to See the Profile for Aaron BSend a Private Message to Aaron BEdit/Delete MessageReply w/QuoteDirect Link to This Post
Will move, thank you.
Aaron
