  The Mall
  WTB 87-88 Under (Front) Hood Wiring Harness
WTB 87-88 Under (Front) Hood Wiring Harness by 88FormulaDuke
Started on: 09-25-2024 06:21 PM
Replies: 8 (172 views)
Last post by: hercimer01 on 09-30-2024 08:29 AM
88FormulaDuke
Report this Post09-25-2024 06:21 PM Click Here to See the Profile for 88FormulaDukeSend a Private Message to 88FormulaDukeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Greetings!!
I’m looking for a complete (and as uncut as possible) underhood wiring harness. Including all the lighting, washer pump… etc.
It appears these are basically in two sections, one for the blower/wipers and such, and another for the lighting. I’m needing both, but if anyone only has one, I’ll get that from ya and keep looking for the other half.
Thanks all!
Eric
Report this Post09-25-2024 08:18 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
If no one responds, reach out to Mike from Mike's Fiero Parts "Boysatt1@gmail.com"
... I've been buying a bunch of stuff off of him lately, he has a lot of Fiero parts stashed away... including harnesses.
88FormulaDuke
Report this Post09-25-2024 08:33 PM Click Here to See the Profile for 88FormulaDukeSend a Private Message to 88FormulaDukeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cool, thanks for the tip! I’ll keep his info filed away for when I need other parts as well for my daily driver.
hercimer01
Report this Post09-26-2024 11:52 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have a complete harness with the module and motors. I think the motors need new gears. Not hard to rebuild. One of the headlight connectors has a poor repair and it looks like the horn connector was spliced into. This harness only has one horn. Earlier Fieros have two horns. You will have to reuse the green wire to the passenger side horn and splice it into the 88 harness. I have tested the module it does work. The motors need gears i'm pretty sure.
Project Genisis Lo Budget 3800SC swap SOLD
88 Coupe under construction SOLD
88 formula 3.4L 4t60 swap SOLD
1988 Fiero GT Medium Red Metallic Paint Job Maybe HOK Brandy Brandywine SOLD
88GT resurrection in progress.
88FormulaDuke
Report this Post09-27-2024 07:49 PM Click Here to See the Profile for 88FormulaDukeSend a Private Message to 88FormulaDukeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sweet!! I’ll send you a pm. Thanks!
hercimer01
Report this Post09-27-2024 10:40 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got your PM. Call if you like.
hercimer01
Report this Post09-27-2024 10:41 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
Member since Mar 2008
dbl post.
[This message has been edited by hercimer01 (edited 09-27-2024).]
hercimer01
Report this Post09-30-2024 08:13 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
Report this Post09-30-2024 08:29 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
